Question about Black & Decker Tools & Hardware - Others
Need new orbital sander pad - Black & Decker Tools & Hardware - Others
  • David Ford
    David Ford May 11, 2010
    for what brand and model number?
    Problem Solver:
  • 9 Answers
Makita orbital sander does not orbit with new pad
there is bit more to the pad than just attachment surface, please have look at this page: http://www.ereplacementparts.com/makita-bo5041-random-orbit-sander-parts-c-97_103_119063.html
your description suggest that there is no connection between pad and clutch, i would recommend to study the drawing, dismantle machine again and put it together again. where appropriate, use grease (i would suggest use of ptfe (teflon) dry spray grease on all moving surfaces and bearings), after service, use lowest possible settings, (disconnect filter! it is useless - use external vacuum if possible, connect to the pipe where filter was attached.) increase settings every minute or so till you have maximum.
lower the settings to your operational requirement and use as usual.
hope this will help you solve thsi little problem, if you find this answer helpful - do not forget to say so...
Dec 21, 2014 | Makita Bo5041k 5" Inch Random Orbit Sander...
Where can i obtain a sanding pad for a ryobi HRS115K Orbit sander
The 4 1/2" 8 vac hole Hook & Loop back-up pads for the Ryobi Sander are no longer available, But you can apply a new hook surface to your present pad $3.75 each conversion disc at Supergrit abrasives , Gettysburg, PA 800 822-4003
Jul 03, 2014 | Tools & Hardware - Others
How to Change pad on green Stayer RO 150 orbital
Slim 17mm spanner between dust skirt and backing pad ( might need to jiggle pad about to get spanner to lock shaft ) then simply unscrew pad
Jan 26, 2013 | Festool Ro 150 Random Orbit Sander...
Hi, my BO5010 spins like a grinder if it is not held tightly to the workpiece, can it be fixed? Thanks, Ope.
Just under the sandpaper pad is a bearing that allows the pad to work as an orbital, that is it can turn freely, independently of the armature. If enough sawdust builds up around or inside this bearing the pad will spin like you describe and this is a fairly common problem with orbital sanders. You need Makita part number 211236-8 or a bearing #6002LL. It's fairly easy to replace; remove the screw in the center of the pad and remove it. Depending on which is tighter, the bearing will either be in the back of the pad or it will stay on the armature. Pry it off/out of the sander. Reassemble everything with the new bearing and you'll be back in business.
Dec 30, 2010 | Makita BO5010 5" Random Orbit Sander
I can't find parts for a Craftsman 5" Orbital Palm Sander
a band aid fix, if the hook and loop is wore out, but the pad is ok, is to get a peel and stick hook and loop pad that you can stick on the pad
Jul 22, 2009 | Tools & Hardware - Others
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
Need to convert pad to hook & loop sys. Is product made to fit this sander pad ?
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
May 29, 2009 | Black & Decker Tools & Hardware - Others
Replace velcro pad on rupes random orbital sander need to know how to replace velcro pad please
I have replaced velcro on various sanders , you just take the original velcro off and make sure that the base is very very clean, use turps and metho to clean it with then buy some velcro from a good hardware supplier and really good glue [two pack epoxy is best ] and simply cut to size and then just glue new velcro onto the base of the orbital sander
Apr 11, 2009 | Tools & Hardware - Others
Changing the rubber pad on the Bosch PEX 12 AE
I'm not familiar with that particular model, but they are virtually all replaced the same way. There are a few screws through the pad into the base. Simply remove them and screw the new pad on. You'll see that it's quite simple once you get the new pad in your hands.
Just be careful not to strip the head of the screw: use the right size screwdriver tip.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Feb 01, 2009 | Bosch Power Tools Sanders Orbital Sanders
7336 orbital sander
If you are talking about the actual sanding pad itself it should just pull of .If you are talking about the backing pad it should un screw
Sep 10, 2008 | Porter Cable 7336 6 Inch Variable Speed...
Tools & Hardware - Others Logo
123 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Rabbit Brains
Rabbit Brains
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
