Question about Poulan Pro Chain Saw 46cc 20"
Chain was binding; started to smocke; took of the chainbrake part & found the inside was melted
  • 1 more comment
  • dontbother10
    dontbother10 May 11, 2010
    I have one additional thought... is your saw under warranty?
  • dontbother10
    You can still respond to the clarification request below. If you give us the model number we can assist you to finding any parts that werre destroyed.
  • dontbother10
    How can we help you? What melted? What model is your saw?
Why does the chain brake not work?
1. What is the make and model of the saw?
2. Does it make any sound when you push the chainbrake handle towards the front (the bar and chain direction)?
3. The idea, and the way it works is that as the bar and chain get jerked upwards towards your face, your left wrist catches the chainbrake handle and pushes it forward thus engaging the chainbrake.
May 10, 2014 | Stihl Garden
What caused splattering oil leaks.
Tow guy probably correct
If it has a chain and you have not been paying attention to regular services, it is possible for a badly worn chain to wear through the timing cover and let oil escape
The mechanic you took it to was probably not properly qualified as he should have seen the oil spray , found the problem and gave you a report on what he found
Jan 10, 2018 | Dodge Stratus Cars & Trucks
My chain on my 371XP husqvarna chain saw quit rotating the moter starts up and run but the chain will not turn
Sounds like the chainbrake has activated, grab the hand guard and pull it firmly fully back to the top handle, it should click when it has re set.
Oct 04, 2011 | Garden
It starts but no output
If it starts but there is a sound of resistance when you throttle up and no chain movement, then the chain brake system where it circles around the centrifugal clutch has fine sawdust accumulation. This acts as a brake even though you click the chainbrake to the run position. You have to remove the two bolts, the side cover, the chainbrake unit itself and get all that dust out so that the centrifugal clutch with the sprocket on it will spin while the chainbrake ban has just a bit of clearance. This has to be a fine clearance because it has to stop the saw in an instant, usually saving your lower leg from getting chopped into when walking along (and slipping off) a log while limbing.
Mar 26, 2011 | Garden
My Ryobi 40cc chainsaw saw runs strong, but the chain binds and will not turn. The safety break is not engaged and the chain is not tighten to tight. I think it maybe the sprocket but it does not look...
If your chain has recently jumped off the bar while running, your chain may have "burs" on the drive links (part of the chain that rides in the bar groove). These burs will make the chain rub the inside of the rails and thus bind the chain in the groove. You can file these off with a flat file if there aren't very many, but you may need to just replace the chain. You can find files, bars, chains & sprockets for your saw at PartsBuggy.com.
Jan 18, 2011 | Ryobi Factory Reconditioned 18" 40cc...
For a Poulaln P3314 what position should the movable safety bar be for starting, forward toward the chain/bar, or rearward toward grip. Ted
the safety bar is chainbrake and should be in off position so the chain is free to move on the bar,,, that should be to the rear youdoit
Jul 27, 2009 | Garden
Poulan 2600 chainsaw
Sounds like the chain brake may be causing it.
Oct 15, 2008 | Garden
18" husqvarna chainsaw
It sounds like your chainbrake was on when you took off side cover .To get brake off place cover against saw with bar off so cover fits into brake lever and pull back on lever
Oct 14, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna chain brake
You'll have to release the brake with the cover off the saw. You just need to find a way to brace it well enough.
If you really can't do this, then it suggests your chainbrake is faulty, of ath the very least not adjusted right.
Sep 18, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan Pro Chain Saw 46cc 20" Logo
55 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
