Question about Cell Phones
Can i put a barr on phone when free mins and tx are used to stop going over
How to scan bar codes on Samsung S5 phone
You need to upload an application and then use it. Go to the Play Store and search for barcode scanner.
Mar 11, 2015 | Samsung Galaxy Cell Phones
Mechanic put bars stop leak in my 1999 grand am se and it is running hot and wany hold coolant
Gm used the Barrs stop leak right from the factory to seal up new blocks. It was the kind made from walnut shells not the metal sealant. He may have used too much if you are overheating. I would do a good flush and go get the bars stop leak in the tablet form, follow directions and see if that helps. I had a persistent leak from my lower intake manifold, already replaced it once, put some Barrs in and now have zero leakage, no overheating either. I would have re-replaced the manifold's gasket but the car is just a beater. Now this stuff is a bandaid not a repair. So if you push the car hard the leak will reemerge.
Jul 13, 2014 | 1999 Pontiac Grand Am GT
I want o update my nokia n70 but where....?
Imagine ur cell battery is very low, u r expecting an important call and u don't have a charger.
Nokia instrument comes with a reserve battery. To activate, key is "*3370#"
Ur cell will restart with this reserve and ur instrument will show a 50% incerase in battery.
This reserve will get charged when u charge ur cell next time.
*3370# Activate Enhanced Full Rate Codec (EFR)-Your phone uses the best sound quality but talk time is reduced by approx. 5%
#3370# Deactivate Enhanced Full Rate Codec( EFR)
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound
but you should gain approx 30% more Talk Time
*#4720# Deactivate Half Rate Codec
2 *#0000# Displays your phones software version,
1st Line :S oftware Version,
2nd Line : Software Release Date,
3rd Line : Compression Type
3 *#9999# Phones software v ersion if *#0000# does not work
4 *#06# For checking the International Mobile Equipment Identity (IMEI Number)
5 #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
6 #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
7 #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
8 #pw+1234567890+4# SIM Card Lock Status.(use the "*" button to obtain the "p,w" and "+" symbols)
9 *#147# (vodafone) this lets you know who called you last *#1471# Last call (Only vodofone)
10 *#21# Allows you to check the number that "All Calls" are diverted To
11 *#2640# Displays security code in use
12 *#30# Lets you see the private number
13 *#43# Allows you to check the "Call Waiting" status of your phone.
14 *#61# Allows you to check the number that "On No Reply" calls are diverted to
15 *#62# Allows you to check the number that "Divert If Unrea chable(no service)" calls are diverted to
16 *#67# Allows you to check the number that "On Busy Calls" are diverted to
17 *#67705646#R emoves operator logo on 3310 & 3330
18 *#73# Reset phone timers and game scores
19 *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it
means you will get the best standby time possible
20 *#7760# Manufactures code
21 *#7780# Restore factory settings
22 *#8110# Software version for the nokia 8110
23 *#92702689# (to rember *#WAR0ANTY#)
Displays -
1.Serial Number,
2.Date Made
3.Purchase Date,
4.Date of last repair (0000 for no repairs),
5.Transfer User Data.
To exit this mode -you need to switch your phone off then on again
24 *#94870345123456789# Deactivate the PWM-Mem
25 **21*number# Turn on "All Calls" diverting to the phone number entered
26 **61*number# Turn on "No Reply" diverting to the phone number entered
27 **67*number# Turn on "On Busy" diverting to the phone number entered
Each command is prefixed with either one or two * or # characters as follows:
** Register and Activate
* Activate
## De-Register (and Deactivate)
# Deactivate
*# Check Status
© Call button
Once each command has been entered, if it is a network command (as opposed to a local handset command) it must be transmitted to the network by pressing the YES (receiver) key which acts as an enter key - this is represented here with the © character. Always enter numbers in full international format +CountryAreaNumber ( e.g. +447712345678).
Command Description Command String
Security
Change call barring code **03*OldCode*NewCode*NewCode#©
Change call barring code **03*330*OldCode*NewCode*NewCode#©
Change PIN code **04*OldPIN*NewPIN*NewPIN#©
Change PIN2 code **042*OldPIN2*NewPIN2*NewPIN2#©
Unlock PIN code (when PIN is entered wrong 3 times) **05*PUK*NewPIN*NewPIN#©
Unlock PIN2 code (when PIN2 is entered wrong 3 times) **052*PUK2*NewPIN2*NewPIN2#©
Display IMEI *#06#
Call Forwarding (Diversions)
De-register all call diversions ##002#©
Set all configured call diversions to number and activate **004*number#©
De-register all configured call diversions (no answer, not reachable, busy) ##004#©
Unconditionally divert all calls to number and activate **21*number#©
Activate unconditionally divert all calls *21#©
De-register unconditionally divert all calls ##21#©
Deactivate unconditionally divert all calls #21#©
Check status of unconditionally divert all calls *#21#©
Divert on no answer to number and activate **61*number#©
Activate divert on no answer *61#©
De-register divert on no answer ##61#©
Deactivate divert on no answer #61#©
Check status of divert on no answer *#61#©
Divert on not reachable to number and activate **62*number#©
Activate divert on not reachable *62#©
De-register divert on not reachable ##62#©
Deactivate divert on not reachable #62#©
Check status of divert on not reachable *#62#©
Divert on busy to number and activate /td> **67*number#©<
Activate divert on busy *67#©
De-register divert on busy ##67#©
Deactivate divert on busy #67#©
Check status of divert on busy *#67#©
Change number of seconds of ringing for the given service before diverting a call (such as on no answer). Seconds must be a value from 5 to 30. De-registering the same divert will also delete this change! **service*number**seconds#© (Service numbers, see below)
Call barring
Activate barr all outgoing calls (see Security to set code) **33*code#©
Deactivate barr all outgoing calls #33*code#©
Check status of barr all outgoing calls *#33#©
Activate barr all calls **330*code#©
Deactivate barr all calls #330*code#©
Check status of barr all calls /td> *#330*code#©<
Activate barr all outgoing international calls **331*code#©
Deactivate barr all outgoing international calls #331*code#©
Check status of barr all outgoing international calls *#331#©
Activate barr all outgoing international calls except to home country **332*code#©
Deactivate barr all outgoing international calls except to home country #332*code#©
Check status of barr all outgoing international calls except to home country *#332#©
Activate barr all outgoing calls **333*code#©
Deactivate barr all outgoing calls #333*code#©
Check status of barr all outgoing calls *#333#©
Activate barr all incoming calls **35*code#©
Deactivate barr all incoming calls #35*code#©
Check status of barr all incoming calls *#35#©
Activate barr all incoming calls when roaming **351*code#©
Deactivate barr all incoming calls when roaming #351*code#©
Check status of barr all incoming calls when roaming *#351#©
Activate barr all incoming calls **353*code#©
Jun 03, 2011 | Nokia N70 Cellular Phone
I want to barr an individual contact/telephone number from my nokia n97
download advanced call manager from nokia ovi app site from mobile, there is a free version and paid version. free version works well you can select number you need to blacklist.
works 100%
please post comment and rep
Dec 22, 2010 | Nokia N97 Cell Phone
Car is overheating--thermostat has been changed--radiator does not leak but it has had barrs stop leak put in--car does not seem to be getting coolant from the resevoir
Barr's Leak can be used to seal leaks, but if they put too much it can make a car overheat, unfortunately for you.
Try to flush out the system and replace any subsequent leaky parts to properly repair the cooling system and engine.
Hopefully, you don't have a blown head gasket, as this is a very expensive repair.
Good luck to you.
Jun 18, 2010 | 1998 Chrysler Sebring
How do you remove barred from a number
You cannot barr or unbarr a single number, you can only barr a group of numbers, for instance all international incoming calls, local incoming calls, etc.
To unbarred a group of call,
Go to your phone menu,
Select your settings,
Select call settings,
Select call barring,
Select unbarred all.
And the call will be unbarred.
take care
Jun 20, 2010 | Samsung B2100 Cell Phone
Motor oil in the radiator didnt see anything on
Unless someone poured it in by accident you have a blown head gasket...that is the only possible way to get oil into the radiator. A mechanic can screw on a cap to the radiator...it has a gas in it...if it is exposed to any exhaust gases through the coolant, th gas will visibly change color...this will tell you 100% you have a blown head gasket...but if it does not change, it does not mean that you do not have a blown head gasket. Oil can get into the coolant and vice versa, sometimes it will do just one of those choices and sometimes it will do both. If it is relatively new (the occurence) drain the cooland and change the oil. When adding the coolant, use 1 gallon of Dexcool, then add two bottles of Barrs stop leak, and then top with water. let the car idle and run until it gets to normal operating temp and then let it run for at least 30 mins at normal temp. Then let it rest overnight to completely cool and set the new material in place. Some folks say never do this...I have done it many times with great success...its not so much what you do but how you do it...If you cannot find Barrs brand...Prestone stop leak is great too...but Barrs is my preference always...both have black tar like pellets and look very distinctive...I have never had any luck with any other brands. To back up a little...has it been overheating, and/or missing, and/or losing water and/or oil...if it is a head gasket it sounds as though the oil is leaking into the coolant jacket of the block and that to me sounds relatively new...Barrs may not work, may last a year or may last forever. If it is a head gasket and you go for the repairs you will spend thousands of dollars...so whats to lose trying this first...NOTHING...Good Luck and let us know what you find and what you do. Also ...is this a 4.3 liter ? and how do you know it is motor oil? What level of oil did you have on the dipstick too...was it low ?
Mar 30, 2010 | 1997 Chevrolet Blazer
Stop a person pestering me.Barr their number?
Set your phone to closed user group, in that way only the ones that you specify there can call you. Hope it helps.
Oct 22, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Cooling issue
I've always had good luck w/MASTER SILVER STOPLEAK by master corp. memphis tenn, silver flakes,use like barrs.yes,the system is pressurized,and pressure can increase slightly when you shut it off.
Sep 22, 2009 | 1998 Oldsmobile Bravada
Inactive sim
Did you buy your phone from someone? secondhand? Your phone is network barred it has been reported lost or stolen and the network has blacklisted the imei (serial Number) from getting onto any UK network, All the sims act differntly when placed in a barred handset some get signal but wont make or recieve a call and just make an error tone and some say "sim card registration failed" either way you phone is as good as a chocolate tea pot as the networks will not reverse the barring and the only other way to get the phone to work in the uk is to un-barr it which is changing the phones imei number which is illegal so that leaves you with one option sell the phone on ebay to someone abroad as the barr is only UK based
Mar 27, 2008 | Sony Ericsson Walkman® W880i Cellular...
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
