Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
I have a Hoover SteamVac SpinScrub. The brushes
I have a Hoover SteamVac SpinScrub. The brushes have stop rotating. I have cleaned the screen Made sure that the tab is on. I have cleaned the brushes. They have a green pin on top that fits into a square hold. They turn freely by hand. I cannot find anything else wrong. Should I just purchase another shampooer?
    Scholar:
  • 190 Answers
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Posted on Oct 05, 2009
How to change the belt?
There is no belt on a Hoover SteamVac. The brushes are rotated by an air driven turbine. If the brushes aren't spinning, you most likely need to replace the turbine assembly.
Jul 05, 2011 | Hoover SteamVac F5914-900 SpinScrub...
SteamVac F5914-900 SpinScrub Upright Vacuum: Is it ok to use the hoover steamvac on tile floors...
Yes, your Steam VAc will work on tile floors. You'll want to remove the rotating brushes and install the Bare Floor Tool attachment - Hoover part number 48417003
May 16, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover carpet cleaner - Model # f7441-980. My brushes do not rotate.
There is a plastic piece on the back of the block brush (spin scrubbers) these wear out or break. You may need to replace the block brush. You can find the parts and a schematic below follow the link. Please don't forget to give positive feedback.
F7441 Link
http://www.usavacuum.com/Hoover-Steamvac-s/109.htm
Jan 29, 2010 | Hoover SteamVac F5914-900 SpinScrub...
How do you change the belt on a f7441-980 hoover carpet cleaner
There are no belts on the SteamVac series. If you have a brush rotation problem, please check this:
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4)Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen
Oct 06, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Why did the brushes stop rotating?
Please check two things:
(1) The shutoff switch on the hood is NOT set to OFF for brush speed.
(2) Remove the red filter panel from under the cleaner, behind the brushes, and clean the hair/debris from the screen filter. Squeeze the two panels together, and pull down to remove from the pocket.
Sep 29, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover F745 900 steamvac brushes will not spin.
If you are handy with a screwdriver undo the casing to access the roller. Once open usually about 4-5 screws you will see that the drivebelt ( rubber band ) has broken. This is the piece you need to replace. Usually most electrical store selling cleaners have these. Take the piece along or get the part number from the manual and replace it yourself. Cheaper than having a tech do it at $90 an hr plus the $5 part
Jul 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How to clean my Hoover steamvac brushes? or
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Press all four latches (B) and pull brush
block out. The brushes can be cleaned
under running water
Godbless
Jun 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
Mar 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
713 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
