Question about Asko Dryers
Where can I get a parts list for an Asko TL751 dryer?
  • ebretzel Oct 03, 2009
    Thanks but it seems most major parts houses don't carry Asko parts.
  • Asko Master
  • 7,482 Answers
Try this website, I think they may be able to help you.
I hope this helps
http://www.partsselect.com/
Posted on Oct 03, 2009
Can I get a list of error messages for an ASKO TL751 clothes dryer?
I googled: Asko TL751 Electric Dryer Error code HI
You may find a manual in this search that gives you the code
If I had to guess it means the high heat is not working, or the high
temperature protection has opened to protect the dryer from
self distruction.
Your owner's manual should give the error codes.
No manual? manualslib.com may have it. YOu may want it next time anyway.
Mar 31, 2015 | Asko TL751 Electric Dryer
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
We just replaced the heat element still no heat any ideas
Contact asko... did you check the power going to the heating element. Or the control panel. If the unit doesn't know to work it won't I would check everything form the heating unit back
Sep 03, 2014 | Asko TL751 Electric Dryer
Is there a theromostat reset button on an Asko TL751 Electric Dryer
Have you clean the air vent out the one leading to the outside? One time we had one do the same thing because the vet was blocked it heated up to quick and sent the the message that the clothes was dry. I hope this helps
Sep 16, 2012 | Asko TL751 Electric Dryer
Dryer makes a grinding sound when stopping
I would try to listen to where the noise and smoke is coming from and get back. look here for some likely parts
Maybe the front bearing or rear bearing.
Apr 16, 2012 | Asko TL751 Electric Dryer
TL751 is two years old. Heating element burned
You did clean out the dryer before turning it back on?
May 10, 2010 | Asko TL751 Electric Dryer
Asko dryer: room temp air, is not heating
first try the reset button .. a black rubber button at the back panel about middle...
Hope it helps if NOT let me know more about your problem... and I will help
Jul 02, 2009 | Asko TL751 Electric Dryer
My Asko dryer shut off and my clothes are still wet. It won't start and the light on the pannel will not come on. I know I probably have lint in the system that escaped the lint trap or maybe something...
YOUR DRYER Has a fuse in it look for it probably somewhere close to where the main power comes in at. if it's good check the heat relay contactor assembly. www.repairclinic.com has the model you have and it may even be as simple as the door switch
Apr 09, 2009 | Asko T701 Electric Dryer
Replacement part for Asko Dryer T700
Call Asko and order it there. Cant imagine that it is a expencive part. I only have the Norwegian partnumber.
Dec 24, 2007 | Asko T700 Electric Commercial Dryer
Dryers Logo
116 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
