Question about LG LHD65EBL Dehumidifier
How does the unit collect water?
My unit runs will turn on; however, the fan does not spin consistently. It will "hum" spin a rotation then stop spinning and then repeat. I feel like the fan should keep running if it is going to collect water (just not sure). The unit gets hot on top as does the black canister in the back (inside, believe that is where the coolant is but not sure).
Thanks for any help you can offer me.
Jed
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 161 Answers
Your fan motor is going out. You can remove the screws from the back cover and gently pry it off. After that, look into the unit and you will see the screws holding the front cover. Take the bucket out and remove the screws at the top. All the screws around the entire metal shroud need to come out. Then with the covers off you can see the fan mount screws. You have to move the evaporator very gently out of the way to get to these screws. Remove the fan motor replace it and re assemble the unit.
Posted on Jan 23, 2010
First the dehumidifier Gold AD35USS1 stopped collecting water. Cleaned the filter. Tried it again and it stilled did not collect water. Plugged it in and was Off but made a humming sound. Then when turned...
Brisy, you have an electrical problem within the unit, which may require the help of Whirlpool Technical Service to solve. That is, unless you have a multimeter and want to dismantle the unit to find the electrical problem. Could simply be a shorted wire or something more serious, which could require replacement parts. Also, consider the age of the unit and would it be cost effective to repair it, as opposed to replacing it. Quite honestly, repairs, sometimes can cost almost as much as a new unit.
Hope this helped you. Please let me know.
Jun 26, 2011 | Whirlpool AD35USS Dehumidifier
How do i check if its working correctly
If you want to give it the ultimate in-home test. Put the dehumidifier in the bathroom with the door closed and a hot shower running, but do not turn on the bathroom exhaust fan. Set the dehumidifier's controls as low as possible and let it run for 20 minutes. After 20 minutes, return to the bathroom, turn the shower OFF and check the water collection bucket for water. The unit will probably be running anyway, when you return to the bathroom.
Remember, the lower the setting, the more the unit will run and collect water. Until it either reaches the humidity level you have it set for or the bucket is full and the unit automatically turns OFF
That's the best way to test a dehumidifier at home. Hope it helps you.
Please let me know.
May 16, 2011 | Maytag M7DH45B2A Dehumidifier
Our Challenge 4151319 Dehumidifier has ceased to collect water. The fan operates perfectly. Can I get it serviced in Devon?
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue.
This situation will have to be addressed by a qualified technician.
Good luck
Aug 19, 2010 | Maytag M7DH65B2A Dehumidifier
No condensation. The fan blows but no water in the bucket?
Take care.
Aug 19, 2010 | Whirlpool Dehumidifiers
DEM 10 Delonghi Dehumidifier has Stopped collecting water but still seams to be working
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 14, 2010 | DeLonghi Dehumidifiers
Can you please help me find out what makes my fan motor slowly stops running after about 30 minutes. The unit runs fine but after about 30 minutes the motor sounds like it slowing down and wants to trip....
mcdevito75 here, It could be the capacitor if you can replace with same size do so. The Armature or communtator in the motor could be shorting also, do the capacitor the change the motor.
Jun 23, 2010 | Dehumidifiers
The dehumidifier's fan does not turn and makes a humming noise
first,make sure the fan blade hasn't gotten stuck on the shroud and cannot turn,then shut off machine and by-hand rotate fan and see if it spins to a stop after several rotations,if it stops quickly there is a bearing problem with the motor,this is normal after many years of service,then replace the motor
Jan 26, 2010 | Dehumidifiers
LG Dehumidifier Fan
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jul 10, 2009 | LG Goldstar LD65EL Dehumidifier
Fan runs, no water collected
It appears that these units have a history of defectiveness. I bought one in late 2010 and it pooped early 2012. If the model is still made, buy a new one, return the defective one in the new unit's packing materials for a refund. Or keep the second (new) unit as a back-up, because the new (first) one may just fail again a short while later.
Oct 05, 2008 | Soleus CFM-40 Dehumidifier
Unit Runs (fan and condenser) but no water?
By condenser I assume you mean the compressor is running. Is there ice forming on the front coil?
Jan 08, 2008 | Comfort-Aire BHD-651 Dehumidifier
LG LHD65EBL Dehumidifier Logo
148 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
