Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Where are the mirrors located on my mitsubshi wd-62327 tv
Here is a procedure for cleaning accessing and the mirrors:
Take the front speaker panel off and you will see two screws on the left and right top corners that hold the tabs for the screen, loosen them then go behind the tv and remove the screws around the perimeter of the back of the screen, 10 total, then remove the front center panel 4 screws and unplug the screen (easy to see which one) then just lift the screen straight up. Onced removed you can clean both mirrors. Dont use chemical cleaners, just a soft rag.
Posted on Dec 09, 2009
My tv was caught in a flood in the basement. IT is moded number WD 62327. For insurance purposes, can you please tell me when that model was last made and if I were to replace it today, what would the...
12 Jul 2006 ... Prices from $2145 ' Pros and Cons, Videos, Amazon Reviews, and Support. Read the full unbiased report on the Mitsubishi WD-62327.
www.productwiki.com/mitsubishi-wd-62327/ - United States - Cached
Hope that helps.
Feb 16, 2011 | Mitsubishi WD62327 TV
Where is the lamp located in a 62" mitsubushi tv dlp wd-62327? am trying to install the lamp and can't find it.
Some of their models require taking off the lower front panel. Some are in the back to the lower right corner. There is a cover about 6x6 that is removed usually with two screws and the same for the front except it will be the lower left after the cover is off.
Nov 17, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Where is the Lamp located in the Mitsubishi 2004 model the number is WD-62327
Turn unit around facing you, either on right rear side or left rear side, generally looks as though it is a vent cover with one to three screws holding cover in place. UNPLUG TV BEFORE YOU WORK ON IT AS ELECTRICITY CAN KILL YOU.
Oct 09, 2009 | Mitsubishi WD-62327 62" Rear Projection...
I just replaced the lamp on my Mitsubishi WD-62327 picture is dim
TAKE THE FRONT SPEAKER PANEL OFF AND YOU WILL SEE TWO SCREWS ON THE LEFT AND RIGHT TOP CORNERS THAT HOLD THE TABS FOR THE SCREEN LOOSEN THEM THEN GO BEHIND THE TV AND REMOVE THE SCREWS AROUND THE PARIMETER OF THE BACK OF THE SCREEN 10 TOTAL THEN REMOVE THE FRONT CENTER PANEL 4 SCREWS AND UNPLUG THE SCREEN EASY TO SEE WHICH ONE THEN JUST LIFT THE SREEN STRAIT UP ONCED REMOVED YOU CAN CLEAN BOTH MIRRORS DONT USE CHEMICAL CLEANERS JUST A SOFT RAG HOPE THIS HELPS
Jan 23, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 Screen is very dim
I tooked the front screen off the TV set. I fallowed the instructions from another wrighter. The Bottom mirror was clouded with dust. I used a cleaner made for cleaning ipods and put it back together with instant success. I had not cleaned it since I got it almost four years ago. I just thought it was getting dim.
As far as the VCR playing black and white it also an easy fix. The Satalite Service man was swapping out my receiver and inadvertaly put the device on componite side of the TV. I put them back on Inpute 1 and 2 and they also work just fine. Thank you for your help.
reading other people porblems I was able to repair it on my own.
Dec 26, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Replacement lamp on mitsubshi tv
That model can have two 3300uf capacitors that go bad on the PWB which will cause the set to detect a lamp abnormality and trigger a red light on the lamp. You can find out more info on it by going to the following link and leaving them a email with your model number and symptom.
http://servicemanuals.vstore.ca/
Jun 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mirror
There is black insulating foam that surrounds the projector and it may be displaced to one side.This leaves about an 1 inch opening around the projector lens and that could be the source of the problem,dust being blown into the compartment with the mirrors.
Cleaned the mirrors really well and used double stick tape to reattach the foam to the plastic frame and this will closed off the opening that maybe letting the dust into the mirrored area of the TV.
Nov 12, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Replacing the lamp wd-62327
Did you get correct lamp:lamp part # 915P020010 ?
Sep 07, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
237 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
