Question about Electrolux Epic 6500 Vacuum
I need the little attachment that allows me to attach the little brush and wand
  • 430 Answers
You will need to find an AERUS Electrolux dealer in the yellow pages in your area. they should deliver no charge
Posted on Oct 04, 2009
Remove handle from hose electrolux
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
May 17, 2014 | Electrolux Vacuums
Dyson DC44
Hi Juliet,
I am sorry to hear you are having difficulty with your brush bar. We recommend taking an opportunity to remove your brush bar and ensure it is free from any debris that might obstruct it. It is also helpful to inspect your cleaner head for any damage. Next, we recommend removing your wand from the main body and attaching your cleaner head directly to the main body of your machine to determine if your brush bar spins.
If your brush bar spins when the cleaner head is attached to the main body your wand may need to be replaced. If it does not the issue may be with the cleaner head. We recommend calling our Helpline with your findings so we can provide assistance with next steps.
US - 1-866-693-9766 or UK - 0800 298 0298
Best wishes,
Jessica
Nov 24, 2013 | Dyson DC44 Animal Digital Slim Cordless...
When taking the handle/wand back to use it seems to lose the suction power regardless of what setting I use. Upon several times of standing it back up it seems to engage the suction power correctly is...
When you say taking handle back I assume you mean the action to start rotation of brushes. Had simular problem and found by removing brush from tube and then cleaning "baked on rubbish" in plastic tube (so you can see clearly through tube) Clean with stiff brush and also making sure brush drive belt housing is also clean and allows brush to rotate square to housing did improve the suction power.
I assume you have cleaned all filters by wahing under running water and applying a little pressure to remove water and attached dirt?
Nov 08, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
How do I attach a mini turbine head to my dyson dc07 upright?
Remove the handle / hose / wand assembly like you were going to use the tools. The mini turbo brush will attach to the open end of the wand.
Apr 14, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Cannot remove attachment from proteam super quarter vac
Greetings, The ProTeam backpacks us a 1.5" hose and attachments. The way that the floor tool is removed is by unscrewing the collar of the attachment. Simply turn counter clockwise on the the part of the attachment that is secured to the wand and doesn't rotate. This should loosen the floor attachment, and you may then pull it off. The other floor attachment can be fitted, and then screwed on by rotating the opposite way, clockwise which will secure the attachment to the wand. I really hope that this information was helpful to you. If you ever need parts or supplies for your ProTeam, please be sure to check out GoVacuum dot com. If this was helpful to you, please rate the repair as helpful by clicking the 4 Thumbs up icons in the top part of the repair. Thank you very much, Chris J. GoVacuum
Mar 23, 2010 | Vacuums
Need Hoover cannister vacuum floor brush & filter bags
Hello, if you GOOgle Hoover you will be able to find your nearest Hoover center, they will then be able to help you with parts and bags. We did this last year and it was emensely helpful. Hope this helps.
Nov 04, 2009 | Vacuums
Power brush problem
Check the contacts where the power head attaches to the wands and also where the wnd attaches to the hose. If any of the contacts look burnt, then they will need to be replaced. Unhooking them when power is on is what causes most of these problems. But if they look ok, could be a problem inside the power head, or in the circuit board that is inside the cannister.
Feb 11, 2008 | Samsung Ultra Quiet 9073R Bagged Canister...
Rainbow e series vaccum/scubber
If you are talking about the hard wood floor brush you hook it at the end of the one slightly bent wand. Look at the end of the brush that you would hook to the wand. In the circle opening there are two slits. On the end of the wand there are two bumps. You need to line them up, push the brush on then twist it around so it stays on. then you attach the straight wand to that and the other slightly bent wand at the other end of the straight one. It will go like this Wet hose, slightly bent wand, straight wand, slightly bent wand, and floor brush. I hope I helped. Leave the basin empty. put your water or cleaner on the floor scrub it around then turn machine on and suck it up.
Nov 30, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
24 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
