Question about Kenmore Washing Machines
We Cleaned out the drain filter, it had a ninja, and coins - then we still got the error. We then pulled out the washer and cleaned to water hose, alot of **** - but then it was still making a grinding noise and flashing F02 error code. Please tell me there is an alternative
  • 71 Answers
Unfortunately if you got everything out of the pump for sure and you're still getting the grinding noise then the coins and the ninja must have broken the fins on the propeller inside the pump. That would be the only explanation....sorry it's not better news. If i had the model number i could get you a part number and close price on the pump. Good luck!!
Posted on Oct 03, 2009
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Front Load Washer will not drain. Frigidaire Gallexy Washer Model # GLTF2940FS0. Get Error Code "E20".
This is an error code for a slow drain or no drain at all problem. It can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Aug 21, 2011 | Frigidaire Washing Machines
The machine wont empty water gives a code of 03 I have cleaned the drain filter and check the drain hose still wont drain water unit is 1 1/2 years old
03 is drain error, as you know. The machine is sensing that the water isnt draining enough in 5 minutes...Unless there is an electronic problem the main reasons for the error code is because the drain hose is blocked, or the pump has something preventing it from turning, like a coin jammed in the impeller, or the pump motor itself needs to be replaced....These pump motors tend to get detritis in behind the impeller shaft seal and this often causes the pump to fail.....Good luck....Nomess
Jun 16, 2010 | LG WM2233H Front Load Stacked Washer /...
UE Error, maching will not spin the clothes dry. Tried all regular methods for resetting, moving around the load in the machine etc. Nothing works
Remove the front cover at the bottom of the washer. Your drain hose and/or drain may be filled with sediment. I just cleaned mine and it fixed my no spin problem......also directions for doing so are in your manual. I used a large dog bowl to catch the water. If no water comes out of the drain hose after you unscrew the cap, squeeze it and see if gook comes out. Then remove the other cap (use a coin) and pull it out. Mine had years of dog hair, sand, coins in it. After I cleaned them, replaced them, spinning returned.
Mar 27, 2010 | LG WM-2277HW Front Load Washer
Getting error F 02 and a beeping from washing machine.
F 02 Is a slow or long drain.
Things to look for kinked drain hose, Plugged or obstructed drain hose, Possible pump filter screen clogged, Least unlikely is a drain pump failure.
The pump filter screen is the most common it gets plugged with lint, coins, hair etc. It can be cleaned by the owner however is is a very dirty messy job and if you are not very careful you can end up with water everywhere. If you want to attempt it let me know. If there is anything else I can do to help please let me know.
Mar 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to clean pump filter on lg wm2688hwm
No, probably have a bad water pump, very common for this washer. I would pull the washer out, lean it against your wall, brace or block it up so you can crawl under it. You will see where the drain hose comes out of the bottom left of the drum and enters the drain filter. Remove the hoses and check for debris or clothes in the hoses or where the drum outlet is. If no restrictions then replace your water pump. Good Luck, Appliance Specialists
Dec 20, 2009 | LG WM2688HWM TROMM SteamWasher
F2 error code
check your drain hose for kink,,when you cleaned filter did you check for coins in the impeller..also check drain pipe for slow drain problem,,check the pump connection and make sure its not slipping off..onthejob
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
0E error
Product Laundry Washer
Symptom Error Codes
Sub Symptom OE error
Question Drain Problem Error.
Answer
Make sure that drain hose and drain filter are not bent or clogged. In case of there are objects in the drain filter, It might drain to slow or not at all. HOW TO CLEAN THE DRAIN FILTER 1. Allow the washer to cool down before cleaning the drain pump filter. 2. Open the lower cover cap with a tool such as coin. 3. At this time use a catch pan to prevent water from flowing onto the floor. Unplug the drain plug, allowing the water to flow out. When water does not flow any more, turn the pump filter open to the left. 4. Remove any foreign objects from the pump filter. After cleaning, turn the pump filter clockwise and insert the drain plug to the original place. Close the lower cover cap. If the drain filter is not clogged, you will need to call LG Customer Service at 800-243-0000.
Aug 18, 2008 | LG Washing Machines
F2 error code on my Kenmore Elite HE3 washer
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Jul 04, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Squire
