VCR taping & playback
I recently bought a Sony flat panel HDTV. I hooked up my EmersonVCR to it. When I try to record one channel while watchinganother, the tape is not viewable later and the TV goes blackintermittently. I can tape clearly with the TV off. Can youhelp? Thanks.
  • Youknowwho Jan 02, 2008
    The antenna goes to a splitter, then one cable goes to the
    TV and the other to the VCR. The VCR is hooked up to the TV using composite cables. Thanks for your help.
  • 579 Answers
Can you describe exactly how you have the cables hooked up?
Posted on Dec 29, 2007
How to hook up vcr when using a cable box
That will depend upon what you want to do. If you plan to record to the VCR from the cable box, then the cable box will need to directly connect to the VCR, then the output of the VCR is connected to the TV. Unfortunately, most VCRs are analog, not digital, so you will lose HD capability (if you have it) trying to connect this way. You also cannot record one show while watching something else (you will need to be tuned to the channel you are recording). If you want to simply use the VCR to view recorded tapes, then connect the cable box to the TV as per the cable company recommendations, and then make a second connection for the VCR. Of course, your TV will need appropriate and available jacks on the rear to do this. It is difficult to give specifics without knowing the models of the cable box, VCR, and TV.
Sep 15, 2015 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
Recording from TV to VCR
You can record by hooking-up video cables from TV video out or Cable/SAT box video out to VCR or DVD video inputs.
Apr 19, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Can't get my sony dvd/vcr model rdr-vx560 to record from my tv
I just gave up. I was told this tv didn't have a video input. Just decided to recford on my old vcr and just use the dvd/vcr to dub tapes to dvds. thanks anyway. JoElla
Jan 11, 2009 | Televison & Video
TV/vcr
VCRs are usually connected in Audio-Video inputs of TVs.
Please check what input is being used in TV for VCR cable hook up at rear of TV. Select that AV input in TV by remote and enjoy.
Oct 03, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Sony SLV 678HF
This is a VHS VCR and should be like any standard vcr to hookup. Did you obtain this VCR recently; and was it used? What are you calling the 'monitor'? Is it a standard TV. Since you said pre-recorded tapes work OK, I think your cable connections are fine. With that in mind, if this is a used VCR, I think your 'recording/playback' heads need to be cleaned. This is not a big deal to someone who can look inside with some competence if they are careful. But the heads are very delicate and can be damaged quite easily. If you want to give it a try or discuss this in more detail, I can guide you (but no guarantees).
Jul 10, 2017 | Televison & Video
Recording from camera to VCR
1st setup ur VCD with TV and playback it to view on TV. If picture is coming, thats OK.
2nd plug ur camcorder in VCR input and select VCR input according to plug in and monitor the camcorder picture on TV through VCR. If its ok, now u r ready to record the picture from camcorder to VCR.
Jun 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
Hooking updta800 converter
Hopefully, your HDTV has a 'Video out' RCA jack on the back-some don't. You could try connecting from these video/audio out jacks to the RCA video/audio in jacks on your VCR. If it works, remember it will be recording EVERYTHING on the tv screen(Time, channel,etc.) that you see while watching. So if you change the channels on the tv-it will be on the tape.
May 25, 2008 | Televison & Video
Sony slv 715ub no stereo sound on tape playback
Hi, i have a Panasonic dmr-es30veb DVD ram recorder/VCR and i cant record one channel while watching another, as you can tell i am not at all technically minded and if you can help i would be grateful many thanks Eileen.
May 13, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Problems hooking up a VCRplayer
Hello..try to turn on the test signal generator switch it is marked test at rear of vcr...and chose av¨rf channel on your tv i.e the 0 or 9 channel than search for the vcr and memorize on tv...alt you can playback a tape ..pre-recorded without the test signal and make the search...alt 2...use a direct av-cable between vcr and tv..which is best and put tv in av mode...good luck...Ron
Mar 11, 2008 | Televison & Video
VCR won't tape and get no playback
First check how good / bad are your recordings. Take a current / recent recording done after this problem cropped up, and play it back on another VCR - maybe a friend's. If the recording plays back badly- showing the symptoms you described, then the problem is still dirty or worn out Video Heads. If the Recording plays back perfectly on the friend's machine, but plays back badly on your machine, I still suggest that you try cleaning the Heads one more time, and if the problem is not resolved, it is time to trash the VCR. One last question, you say that you have reset the channels. Are the reception channels' images clear? I may be able to give some more suggestions, based on this response.
Apr 17, 2007 | Goldstar GVR-E435 VHS VCR
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
