Question about Toys
What does the ''obey me'' card mean in family guy uno
How to build a clothing web site
Expressing frustrations and worries openly together with a trusted friend, family member or a clergy member can provide instant to reduce anxiety. Holding things in
http://topmuscleuptips.com/super-brain-pill/
Jan 21, 2016 | Obey Clothing OBEY - Vintage Mens...
What does the hand in uno flash mean?
The "slap" card replaces the "reverse" card from traditional Uno. After playing a "slap" card, the player hits the big yellow button; other players race to hit their own red buttons, and the slowest draws two cards.
May 02, 2015 | Toys
I need the instructions for Uno Reflex
Instructions Things You'll Need
  • Nintendo Game Boys
  • Card Tables
  • Chairs
  • Nintendo Game Boy Game Link Cables
  • Snacks
  • Beverages
  • Spiral Notebooks
  • Game Boys (Color)
  • UNO Card Decks
  • Pencils
    • 1 Use a deck of UNO cards. The deck has 108 cards consisting of four suits, wild cards, and word cards with directions on them.
    • 2 Choose a dealer by having each player pick one card. The person with the highest number is the dealer. Word cards count as zero.
    • 3 Deal each player seven cards and place the remaining cards face down in the middle of the table. This is the draw pile.
    • 4 Turn the top card of the draw pile over to form the discard pile.
    • 5 Take turns beginning with the player to the dealer's left and go clockwise around the table.
    • 6 Place one of your cards on the discard pile when it's your turn. Your card must have the same number, color or wording as the top card of the discard pile - or be a wild card.
    • 7 Draw a card if you cannot discard. Play the drawn card if you can. If you can't, it's the next person's turn.
    • 8 Announce a suit when you place a wild card on the discard pile. You can play a wild card any time it's your turn and can name any suit you wish.
    • 9 Announce a suit when you place a Draw Four card on the discard pile.
    • 10 Follow the directions of a word card that is played on the discard pile by the player preceding you. This may mean that you have to draw two cards, skip a turn or even draw four cards.
    • 11 Say "UNO" when you have one card left in your hand. If you forget to say UNO and another player catches you, you must draw two cards.
    • 12 Tally all the points when one player is out of cards. (See related eHow "How to Keep Score in UNO.")
Read more: How to Play UNO ' eHow.com http://www.ehow.com/how_16919_play-uno.html#ixzz1jxXQAJrS
Jan 20, 2012 | Toys
How do you play uno i forgot
Each player is dealt 7 cards with the remaining ones placed face down to form a DRAW pile. The top card of the DRAW pile is turned over to begin a DISCARD pile.
The first player has to match the card in the DISCARD pile either by number, color or word. For example, if the card is a red 7, player must throw down a red card or any color 7. Or the player can throw down a Wild Card. If the player doesn't have anything to match, he must pick a card from the DRAW pile. If he can play what is drawn, great. Otherwise play moves to the next person.
When you have one card left, you must yell "UNO" (meaning one). Failure to do this results in you having to pick two cards from the DRAW pile. That is, of course if you get caught by the other players.
Once a player has no cards left, the hand is over.
Hope that helps.
Good luck! :)
Jun 20, 2011 | UNO Brailled Uno Cards
I have uno attack the game but i lost the instructions so i dont know what the cards mean. can u help
The object of the game is the same as the original Uno game with an unpredictable twist. Players still need to get rid of all playing cards before other opponents and reach 500 points and you still must scream "Uno" when you have only one card left. But this Uno has an extra twist. Instead of picking a card when you have nothing that matches the discard pile, you must press the fire button that disperses none, one or many cards when pressed. Read on to learn more.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions
    Starting the Game
  1. Step 1 Get a pad of paper, pencil and calculator handy to keep score. The winner is crowned when they reach 500 hundred points. Have winners after every round for younger players, the scoring math will take too long and they will lose interest.
  2. Step 2 Remove all contents from the Uno Attack box and lay out on the table. Unscrew the battery cover with a Phillips screwdriver and place 3 C size batteries to the slot. Reattach the cover and press the button to check if the batteries were put in correctly. It should make a buzzing noise if correctly installed.
  3. Step 3 Combine the top part and the bottom part of the Launcher by pushing the red top onto the purple base in an angle, with the exiting slot facing the same way as the UNO fire button on the base. Listen for the snap as it connects.
  4. Step 4 Decide on the dealer by choosing cards from the deck. Highest numbered card gets to deal first and then the deal goes around clockwise. If you pick a command card, it counts as a zero. The player to the left of the dealer gets to discard first.
  5. Step 5 Shuffle cards and pass out 7 to each player. Place the rest of the cards into the launcher, and use the top card from the launcher as the first card in the discard pile. The person to the dealers left must follow the directions of the command card if it happens to be picked.
    Playing
  6. Step 1 Match the color or the number of the top card in the discard pile when it is your turn. Place your matching card on the top of the pile. Save command cards till your opponents are low on cards unless you don't have any cards that match the discard pile. This practice is a good strategy but can fail miserably because command cards left in your hand at the end of each round are more points for that rounds winner.
  7. Step 2 Choose to save a playable card for later in the game and take your chances by hitting the Uno fire button instead. This is called reneging.
  8. Step 3 Follow the directions of special card. If you do not have what it is asking for then you must press the Uno button on the Launcher. Most cards are like original Uno or self descriptive.
  9. Step 4 Say "Uno" loud enough that all players can hear as soon as you have one card left in your hand.
  10. Step 5 Call out "Uno" only after another player lays their second to last card on the discard pile but before the next person takes their turn and that player must hit the Uno fire button twice. You can go out with any card including a command card except the Trade Hands Card.
  11. Step 6 Add the cards left in the losers hands at then end of each round, this will be the winners score. Each face card through 9 is scored by its value. "Reverse," "Skip" and "Hit 2" are each worth 20 points.
Hope it helps you.......... do not forget to rate me on FIXYA :)
Jul 28, 2010 | Mattel Uno Attack! Card Game
Lost instructions to uno attack game
About:
Uno Attack is a popular adaption of the original Uno game that involves a electric card shooter. The shooter has a launch button and when pressed 0-12 cards can be shot out.
Differences:
Uno Attack rules are very simular to the original Uno rules with several differences. Instead of a Wild Draw Four card, there is a card named “Wild Hit Fire”. When played, the next player must hit the launch button.
Instead of drawing a card when a player no longer has a card to play, they press the launcher button.
Players must yell “Uno” when they first place down their second to last card. If an opponent catches them not saying “Uno”, the player has to press the launch button.
Cards:
Besides the number cards there are several other cards that helps mix up the game.
“Reverse” – If going clockwise, switch to counterclockwise or vice versa.
“Skip” – When a player places this card, the next player has to skip their turn.
“Draw Two” – When a person places this card, the next player will have to pick up two cards.
” Wild” – This card represents all four colors, and can be placed on any card. The player has to state which color it will represent for the next player. It can be played regardless of whether another card is available.
“Wild Hit Fire” – When played, the next player must hit the launch button.
Jun 23, 2010 | Mattel Uno Attack! Card Game
I do not know to play uno
heres the rules and how to play info:
May 17, 2010 | UNO Skipbo/ Freefall Compilation for DS
What does the cross mean on the colour cards
it means to skip the person that has a shot after you
Apr 16, 2010 | UNO Skipbo/ Freefall Compilation for DS
Toys Logo
274 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
