Question about LG enV3 VX9200 Cell Phone
Is it my imagination or is it true my new env3 does not support t9 or preemptive text?
  • 23 Answers
From the front screen and keyboard:
(i.e. with the phone closed)
While entering a message, hit the main "OK" button for "Options".
Item #2 in this menu is "Entry Mode."
T9 is on this list.
Operating from the internal LCD screen and QWERTY keyboard:
Hit OK to get to main menu
Select "Messages"
Once in that menu, the left option key beneath the main LCD screen is "Settings" - hit that
On that menu, item #2 is "Entry Mode" where you can select T9
I have read of difficulties getting the enV3 T9 mode to add new "user" words that you might want to program into the T9 dictionary, so don't be surprised if you have trouble with that.
Posted on Feb 10, 2010
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
I want to save words to use in T9.
Go to quick text and press add new message
Jan 26, 2010 | LG enV3 VX9200 Cell Phone
How to take t9 off boost mobile i570?
There is no option on the i570 to actually " Turn off " T9, but there is the option to switch from "Word" to "Alpha" with eliminates the annoying T9 from interrupting your text message. The way you do this is by creating a new SMS text message or "Reply" to an existing message in you inbox. Either way works. Once in the new message window you want to press the "menu" key you will see "Entry Method", you then just want to select "Alpha" instead of "word" and the T9 will no longer be active.
Nov 16, 2009 | Cell Phones
How do I delete auto text words from dictionery Samsung GT 8300
No, u cannot delete the auto text word from the build-in dictionary function name T9, but u can disable this auto text mode.
When open a new text message, just press the icon ABC to change the mode to ABC, T9 or number.
YBC (/\)
Oct 08, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Krzr won't stay on t9 text
open a new text message go to "options" select "Text Setup" and change the primary text: to iTap English instead of TAP English this will fix ir :]
Mar 07, 2009 | Motorola Mobility KRZR K1m Cellular Phone
Predictive text on Samsung Propel
Well it's not so much a solution as it is an answer.
T9 is 9-key Texting. So it will only predict what you're going to type if you're using the 9-key triple tap mode of texting.
It WILL NOT intelligently select options of what it thinks you are typing on the QWERTY keyboard.
I've had this phone for less then a week & so far that would be my only suggestion for improvement. Otherwise, it's an awesome lil' phone for what I use it for.
Feb 19, 2009 | Samsung Propel A767 Cell Phone
SEtup t9 texting
When in Text mode, press the # button. With each press, you will see the 'Abc' on the screen changing. When you see the 'Abc' with a small book by it, then you are in T9 texting mode.
Nov 10, 2008 | Motorola Mobility W375 Cellular Phone
Predictive Text
To get predictive text on or off on the LG Shine go to:
>Menu
>Messaging
>New Message
>Text
>Options
>T9 languages
>T9 on/off
Sep 01, 2008 | LG Shine KE970 Cellular Phone
Unable to turn off t9 dictionary
try to hold the # button, or press it a few times durring the text message - it should flip from t9 to standard and maybe even symobls.
or else go into your message, being a new message then go to options - you should see some option change from t9 etc.
Dec 23, 2007 | Samsung SGH-D600 Cellular Phone
T9.
To activate T9, undertake the following steps:
Messages
New text Message
Press the first button from the right on the last row
Go in the option T9.
Choose 'On'
Nov 21, 2007 | LG Prada KE850 Cellular Phone
LG enV3 VX9200 Cell Phone Logo
326 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
