Question about KitchenAid KERA807P Electric Kitchen Range
Oven controls all work but off buton not working. to shut off we trip the main breaker.how to repair? this is a kitchenaid electric range.model ykesa907.
This is the Membrane switch which is faulty. I had mine replaced once already. These units cannot be repaired, they need to be replaced. Apprently it is very common and you should report this to your local ESA (Electrical saftey authority) this is a very dangerous problem. The ESA can have this item recalled if enough people lodge a complaint. The round Stove top knobs on these Ranges also have a tendency to switch on when bumped, very dangerous too.
Posted on Oct 19, 2009
  • madann904 Mar 28, 2011
    I have the membrane, but can't figure out how to exchange it without breaking/bending the face plate. can you advise?
Getting an F15 error code when trying to start Oven.
Error code f15 'Frigidaire FEB30T7FC Stainless Steel ...
www.faqqq.com/.../error-code-f15-frigidaire-feb30t7fc-stainless-steel-ele...
Error code f15 'Frigidaire FEB30T7FC Stainless Steel Electric Double Oven ... I'mtrying to open up a Unity3D game.exe that is on a remote computer through my main desktop. ... How 2016 will be the start of your virtual reality future - CNET.
Kenmore range shows f15 error code - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Range, Oven & Cooktop Repair
Oct 31, 2010 - 10 posts - ‎5 authors
Kenmore range suddenly started flashing f15 error code. With Thanksgiving just around the corner, i need help with this repair. Thanks.
Dec 30, 2015 | KitchenAid Kitchen Ranges
Why doesn't oven work?
Give the repair man the opportunity to make the oven work instead of charging you for parts that probably did not need to be replaced.
Dec 01, 2015 | DCS RGS-366 Professional Gas Kitchen Range
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Trip switch of breaker?
First of all, did you disconnect your Range prior to working on it. This is something that should be a priority when working on your range. Or, you can shut off the breaker, which is located in your house electrical panel. It's most likely a 50amp 2 pole breaker, and could also be in a sub - panel in some houses. Check this out first before continuing. And, if it is tripped, turn the breaker to the off position and leave it off until you replace your heating element. Once completed, then you can turn it back on. Try this, and if it works - great! If not, will try something else.
Mar 13, 2010 | GE Spectra JBP78 Electric Kitchen Range
Kitcheaid electrical Oven
If you go to repairclinic.com click on repair help at the top then "error codes" on the left side in a gray box. you can look up the error code. I found F2-E0 but not FE02 for a KitchenAid range.
What I found means shorted key pad. Some times just unplugging the unit or shutting down the circuit breaker that controls it for half an hour it will reset. not guarunteed but less expensive than replacing if it works. Good luck.
Jan 09, 2009 | KitchenAid KDRP467KSS Dual Fuel (Electric...
HELP! Stovetop elements don't work and oven burner doesn't work
sounds silll but check your circuit breakers make sure both of the 2 breakers fedding this unit ar in the on positoin , itts possible youve tripped half your circuit.
Oct 21, 2008 | KitchenAid KESC307 Electric Kitchen Range
Kitchen aid model# kgri801pbs
On most models, the door stays locked during a self clean, until the temperature returns to normal for safety reasons.
It sounds like your unit may have tripped a breaker during this self clean event. Check your panel for a tripped breaker. If the oven has cooled down, and the lock is still engaged, then we may have a different problem.
Let me know what you find out!
Jan 10, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
KitchenAid KERA807P Electric Kitchen Range Logo
347 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
