Question about Delta Faucet DELTA/PEERLESS FAUCET CO. 25901 TWO HANDLE LAVATORY FAUCET - CHROME
The faucet was leaking and nut wouldn't come off
The faucet was leaking and the nut wouldn't come off because it was corroded. How can THAT problem be fixed? Damn thing leaks every couple of years anyway. I'm buying a Moen.
  • Anonymous Mar 27, 2014
    can't get the nuts of to change the taps
  • 334 Answers
There are several tools you can use to remove stripped nuts and bolts, here are pics of two different types. You might also want to try using a good set of chanel lock pipe wrench or vice grips
The faucet was leaking and nut wouldn't come off - 100_2850%20bolt%20out.jpgnut_breaker.jpg
This is a common problem, and often times it is impossible to remove the nut without damaging/destroying the faucet.
You may also want to invest in a basin wrench. It will make removal and installetion MUCH easier.
This is a basin wrench.
You are wise to go with Moen. They make a great product, offer lifetime warranties and have great customer service.
Posted on Oct 03, 2009
Testimonial: "Thanks for your advice and the picts!"
How can I fix a bathroom sink faucet?
THE LINE MAY BE CRIPPED. TIGHTEN THE NUT OR REPLACE THE NUT IF IT WILL NOT TIGHTEN. YOU MAY NEED A LONGER WATER LINE TO GET AROUND THE BUMP.
Oct 04, 2014 | Delta Plumbing
How to stop sink leak
Check whether the faucet is leaking or the drainage is leaking.
If the faucet is leaking, you need tools to loosen the faucet to check whether the hoses are leaking or not. If the drainage is leaking, you can tighten the slip nut.
May 04, 2014 | Kohler Model 10430: Fort® Single-control...
Leaking faucet
Remove the handles. See if the chrome slip nuts holding the stems in are corroded. If they are, the cartridges may not be fully seated or the o -rings that seal around the cartridges may need to be replaced. If either of these is the case you can tell for sure by turning the stems to the on position with the handles removed and looking for water seeping around the cartridge. If none of the above is the cause then check to see if the aerator (screen on the spout) is loose or corroded sending a light spray back towards the faucet body that looks like a leak. If this is the case remove and clean the aerator, then reinstall it making sure not to cross thread it. If none of the above, replace the faucet. Be sure to call Delta first before replacing because they have a lifetime warranty and you just might get your faucet for free!
Apr 05, 2013 | Delta Faucet Delta 2530-24 Innovations...
How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
These faucets can leak in three different places:
  1. Internally at the valve seat
    You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
  2. Around the handle
    If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
  3. Between a pivoting spout and the body
    The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
Reassemble the faucet according to directions.
Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
Sep 10, 2011 | Moen Plumbing
On off handle on outdoor faucet very hard to turn, can I take it apart and lube??
If it is a brass faucet there should be a nut just where the handle goes into the tap,loosen this nut a small bit and try turn then,it should loosen it up.do not loosen this nut to much or it will cause a leak
Mar 30, 2011 | B&K Plumbing
I have a 2 handle bath faucet and am trying to remove valve. Can't turn nut either way. Any recomendations to help loosen nut? Which way does the nut turn? The brass nut and stem are pretty green. Been...
righty tighty, lefty loosey. if its too tight for wrench youll need a deep socket wrench that will fit it.my hats off to you. kohler makes a good faucet,if stem is shot you can find new ones at lowes.seat is also replaceble
Jan 26, 2011 | Kohler Forte Two Handle Centerset Lavatory...
Moen two-handle kitchen faucet, 1990's model installed new a few years ago, is leaking underneath at the center where the spray hose would connect. I didn't use the hose, though. The nut was tight. It...
The nuts used for capping off the sprayer attachment will bottom out and not seal. Unless there is tape or thread compound on the nut, it can spray a tiny jet up under the faucet when the faucet is activated. If there is clearly water leaking from above that, then the o ring for the spigot may be failing and need replacing. If this is the case, it will only leak when the faucet is activated. There is always the possibility of a crack in the casting of the faucet body; hope not:)
Aug 22, 2010 | Moen 7910 Chateau Two-Handle Kitchen...
I have an american standard single control faucet. I realized water was leaking down the pipes. When i turned of the hot water valve, water stopped leaking. How do i go about fixing this.
Chances are your supply line is leaking. One of three things (easy fixes).
1) There is a "packing nut" on the shut off which holds the handle on - this could be leaking (just tighten with pliers while open).
2) There is a nut directly above the shut off (3/8 inch) which goes directly to the faucet. Simply thighten this nut.
3) There is yet another nut above the last (very near the faucet). This is a 5/8 nut and you will most likely need a "crescent wrench" to tighten this as you cannot get pliers up there. You can purchase a crescent wrench at any hardware store for about 10 bucks. Good luck!
Dec 30, 2009 | American Standard Kitchen Faucet 6310 020...
Delta Faucet DELTA/PEERLESS FAUCET CO. 25901 TWO HANDLE LAVATORY FAUCET - CHROME Logo
377 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
