Question about Rule 1800 Pool Cover Pump With Leaf Protector 110v
When i plug my pool cover pump in the the gfi outlet trips
    President:
  • Rule Master
  • 1,378 Answers
The pump motor is likely grounded causing the GFI to trip. Once the seal inside a submersible pump fails, water enters the unit and the motor will fail. The low cost of those pumps makes them not worth fixing and you will most likely need to replace it.
Posted on Oct 03, 2009
3 Suggested Answers
  • 10865 Answers
SOURCE: I have a Rule 1800 H53SP-24 Swimming Pool Cover
Hello. There are several possible issues here which are all fairly easy to investigate. Begin by bringing your pump, cord and hose into a warm space for 24 hours to thaw everything out, warm it up and dry it out. Then try it. If it works, you know you have one of the problems described below:
1. Sometimes a circuit breaker wears out and needs to be replaced. Try your pump on a different circuit, insuring that you are using a different circuit breaker. IF it works there, the solution is to replace that worn circuit breaker. 2. Check the impeller and remove any clog, blockage, debris or residue. 3. The 24 foot cord on your pump might have a cut, or a scrape on it. If it does, water is getting into the insulation and causing the circuit breaker to kick. Check your cord thoroughly and if you do have a break in it replace the cord or repair it with a waterproof repair. 4. Your pump motor may be worn or faulty or have a water intrusion. In that case the only fix is to replace the pump. 5. The drain hose could be frozen. If it is, that blockage could cause the breaker to kick. Always ensure that the hose runs consistently downhill.
If you would like to contact Rule, you may do so at the following link: http://www.rule-industries.com/
Regards, Joe. Please rate my answer. Thank you and happy holidays.
Posted on Dec 26, 2009
SOURCE: Rule H53sp-24 pool cover pump trips GFI breaker
GFI devices are prone to degrade over time. Also, when used outdoors there are additional moisture issues that may cause sufficient current leakage to trip the breaker.
I had a similar problem this Spring. I was using a 20 amp GFI "master" outlet that protected two additional outlets 'downstream' of it (wired to the 'load' terminals on the GFI outlet- I'd have the check the doc. to see what terminology was used here). The pump was plugged into one of the downstream outlets.
Replacing the GFI seemed to solve the problem. I did ante up $20 for an 'outdoor' model of the 20 amp GFI unit, several bucks more than the standard 'indoor' unit - have no ideal if that represented additional value or not.
Note also, that this is the third such pump I have used for my pool cover. The other two failed to come on at all after about a year's use. The mfg replaced them under warranty (I may have had to send back the old pump - I forget!).
Curtis
Posted on Apr 19, 2009
Gfci trips heater not turned on
GFI is Ground Fault Interrupter (or GFCI - Ground Fault Circuit Interrupter) It is doing its job, telling you that there is a short in the unit or wiring. Have a certified electrician check the wiring and unit.
May 17, 2014 | Pentiar Pentair MiniMax 100 BTU Natural...
Hot gfi keeps tripping
You didn't specify how your pool is set up, but the GFI tripping means you have too much power, too many devices plugged into it. I think you need an electrician, just to be safe.
Apr 27, 2014 | Pool & Spa
I have a Hayward 1081 pool pump. We have been receiving alot of rain and i went to turn pump on and it keeps tripping the GFI at the breaker panel. Pump was working good until I shut it off prior to...
I've had a problem like this. Can you safely power the pump from a non gfi outlet for a while? Once it runs and whatever is causing this condition dries out, you can plug it back into the gfi.
Gary
May 19, 2011 | Pool & Spa
Have electric out at pool equipment pad. Use Pool Cover pump to syphon water off the cover. I put a new plug on the electrical cord of the pump this past August and it worked great. Just noticed that the...
Sorry to read about your problem, I hope this helps you out.
1. GFI's dont like pumps.
2. you may have defective motor.
3. run a ext cord to a another outlet and see what happens.
4. GFI maybe defective..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Heating & Cooling
WAS ACID WASHING POOL...LITTLE GIANT PUMP MODEL 8E-CIA-RFS STOPPED PUMPING...TRIPS GFI WHEN PLUGGED INTO OUTLET...TOOK OFF TOP OF UNIT...CAN SEE NO SIGNS OF SHORTING OUT...
With a megger or a decent multimeter you should be able to check the cord and motor for grounds. It is tripping a GFI though so testing at this point is redundant. The bad news is that a grounded submersible pump motor is never worth fixing. A new unit is about $200 and even a cheap shop at $50/hr would take at least a couple of hours to disassemble, clean and re-insulate the winding. That assumes re-insulating it will fix the ground which is often not the case. In short, your best bet for a unit that is no longer covered under warranty is to replace it once the electrical system goes to ground.
John
Nov 04, 2010 | Garden
Are pump keeps tripping the mains electric it only works for a few minutes until this happens
Do you have the pump plugged to a GFI outlet (with the "reset button"). If not, you should. If you do, that circuit must be overloaded, try using an outlet that is on a different circuit or moving other things off of that one, depending which is easier.
Jun 28, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Curtis
Mar 22, 2009 | Rule H53sp 24mgra Swimming Pool Cover Pump...
Rule 1800 Pool Cover Pump With Leaf Protector 110v Logo
663 people viewed this question
Top Rule Pool & Spa Experts
Bill Jordan
Robco Water
Robco Water
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
