Question about Denon AVR-1907 Receiver
How do I hook up a turntable - Denon AVR-1907 Receiver
  • Denon Master
  • 5,568 Answers
You may have two possibilities depending on the configuration of the turntable.
Your Denon should have inputs marked for 'Aux,' 'Line' and possibly, if it is built with the expectation of use with a turntable, 'Mag' or 'Magnetic.'
Your turntable may have a 'Line' output or only a shielded cable carrying a very small voltage from the magnetic head. I assume the pickup is magnetic and not crystal which has a much higher output level but also a higher impedance that requires a matching input.
You should have any of the above outputs in pairs and if the color coding conforms to current standards, there should be in- and outputs marked with red (right channel) and white (left channel).
I would first try connecting the turntable's leads to the 'Line' input since most later turntables have a small amplifier circuit built in that will take the signal from the pickup, amplify it, and match it to the levels and impedance of the line input on the Denon.
There isn't any danger of making a fatal mistake and you should hear right away if there is excessive distortion or a loudness even when the level is set to a low setting; this implies that the output from the turntable is higher than that input wants to see.
Posted on Oct 03, 2009
I'm trying to hook up turntable to my laptop. I do not have the box, can I get a step by step hook up?
Hi, you want an rca to 3.5 mm stereo jack. Go into yur pc via the mic input. styluscity@gmail.com
Aug 31, 2010 | ION Audio TTUSB05 Turntable
PS-LX300USB Turntable: I have hooked up the sony turntable to laptop, but...
Have you though of using a pre-amp? You'll probably need to go turntable --> pre-amp --> soundcard input to get acceptable sound
May 11, 2010 | Sony PS-LX300USB Turntable
Hooking a turntable with it's own pre amp to a computer and/or a home theather system gemcquaid mcquaid@northlink.com .
Check your inbox.
Hook the output to Aux. As for your PC, that would depend on your sound card. Basically, the same.
Mar 01, 2010 | Sony PS-LX250 Turntable
Sounds from turntable
There will be some feedback from the turntable, and this is totally normal. Ive actually heard the music from the needle itself, and is nothing to worry about
Dec 28, 2009 | RCA ION-ITTUSB05 Turntable
Old turntable works but is too quiet to hear
It sound like you may have to hook your turntable up to a phono input. Turntables have low level outputs. The phono input is designed to amplify this low level more than the cd/dvd inputs do. If you do not have a phono input, you can buy an external "phono preamp" online. Hope this helps.
Aug 04, 2009 | Audio Players & Recorders
I have Pioneer Amplifier with Phono Inputs. Also I have an Akai stereo Equalizer. I want to connect my Turntable to the pioneer amplifier through Akai stereo Equalizer to have a better sound quality. Is it...
hook the turntable "directly" up to the "phono" inputs. if it sounds normal this way, and not loud and distorted, then you have to plug the turntable up that way, directly to the reciever's phono input.
you can hook the eq up through the "tape in/out" jacks.
take the tape record out jacks, and hook them up to the input of the eq, and take the tape play input jacks and hook them up to the output of the eq. then, to use toe eq, select whatever input you want eq'ed, while also selecting "tape monitor"
Mar 07, 2009 | Kenwood Audio Players & Recorders
Hook up
You need an amplifier to connect a turntable as the output is much lower than that of other electronic components. The amplifier will need to have PHONO inputs which will connect to your turntable, then you connect the speakers to the output of the amplifier.
Aug 03, 2008 | Audio Players & Recorders
Denon AVR-1907 Receiver Logo
257 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
