Question about Hitachi 42PD6600 42 in. HD-Ready Plasma Television
No power - have checked fuses, power leads and master switch
The power lead works, the plug works. when you plug lead into tv yu do not get that "crackle" - you get absolutely nothing. Power switch on TV does nothing - its completely dead
help!
  • 767 Answers
Well yes, there a problem in the power supply modual.
It does sound like a failing power supply , becuse of the
fact you don't get charge up spark from the plug , wich is normal
affter it's been off /unpluged for 20 min or so .
check the resistance of the plug coming from the set with a volt meter if you have 10 meg ohms or higher,
it's an open circuit and more than likely a 1.50 fuse in the power
supply. If the fuse blows instantly then it's a shorted output transistor or rectifier diode in the switching power supply.
Be a shame to pay 300.00 plus for a stupid fuse.
hope that helps a little . if you have any questions just comment
an i'll respond
Rob
Posted on Oct 04, 2009
  • Hitachi Master
  • 8,457 Answers
Ur power supply board,it dead.Must be replace the board.
Posted on Oct 03, 2009
  • ericaniu Sep 26, 2010
    my hitachi is dead after i moved it to another room. somebody told me to check the master switch but i couldn't even find it ? where is the master switch ?
Can you help with power windows?
What type of vehicle? Does the drivers window work?
May 01, 2015 | Cars & Trucks
Electric windows not working
Check the fuses first and then the window switches themselves. You will have to remove them and put a meter on them. You can cross the wires to see if the window will go up or down. If you can do it by crossing the wires then the switch is bad.
May 14, 2014 | Subaru Impreza Cars & Trucks
All power windows don't work
Dealers-hmmph.
You may have to keep looking for another broken wire. To the driver's master switch, a tan wire looks like the hot wire (feed) for the switch. And a black wire is ground, originating at the master switch and going back into the cabin with the wire harness, and then to a nearby ground source, probably behind the left kick panel. If you pull the master switch off, key on,, check for power on the tan wire terminal of the switch connector. Use a test light or a voltmeter. Now if you have a hot wire on the connector, put one volt meter lead on the hot wire terminal and the negative lead onto the black wire terminal. If ground is good, voltmeter will read battery voltage. If ground is lost, voltmeter will show nothing. Same with test light-check for a hot wire with key on. If yes, put test light lead on hot wire and use probe to touch ground-if ground is good, tester will light up. Alternatively, you could remove the left kick panel and check the security of the ground to frame there.
The only place I know for a wiring diagram would be a repair manual. Haynes manuals are about the best (about $25 at parts stores), short of a factory service manual for big bucks.
If still no luck with windows, and no hot wire with key on, pull the circuit breaker for the windows on the fuse panel under dash. With key on,. one of those terminals for the circuit breaker should show power. Ground a test light and probe both terminals to check for power. If no power there, check under hood fuses or fuse links that feed the fuse box. If CB has power available, well, that's the feed for the tan wire-sounds like either the tan wire or the black ground wire may have a break. If power to switch, check ground wire.
As a last resort, try a new circuit breaker if powered at CB terminal but nothing at driver's switch. If power is to switch on tan wire, and ground is working, consider that you may have gotten a defective master switch-not likely, but known to happen.
May 09, 2013 | 2003 Jeep Grand Cherokee
1996 suzuki sidekick sport jlx all four power windows and door locks quit at the same time
Look for broken wires leading into the driver's door. Have you already checked for a fuse problem? The windows and locks may be fused, or they may be on a circuit breaker. Sounds like power is not getting to the master switch, or the ground for it is lost. If you have a voltmeter, you can check for power and ground right at the master switch. The switch will have one hot wire to it with the key on, and one ground wire from the switch back into the cabin and then to ground somewhere, probably close by.
Ground a voltmeter or test light, pull the master switch connector apart, turn key on, and probe the connector for one hot wire. If you have it, good. If no power, again check for broken wires at the door. To check the ground wire, put positive lead on the hot wire, and the negative lead into the ground terminal source at the connector. If the ground is good, the meter will show battery voltage, or the testlight will light up. If the ground is lost, you will get nothing on the meter or testlight.
Nov 24, 2012 | 1996 Suzuki Sidekick
Wharfedale LCD2710HDAF no power to tv, checked cable and changed fuse a few times, new power lead? or is this a common problem?
Hi.
The power cord must be checked using a multimeter. The test is done reading impedance (ohms) between plug's prongs and contacts to TV power board.
If the power cord is OK and there is no power, then the problem is the power board inside the TV.
Regards.
Ginko.
Dec 04, 2011 | Televison & Video
C21T7BA TV will not power up.
check the internal mains fuse usually connected to the mains lead via the on/off switch .good luck farr64
May 02, 2009 | Mitsubishi VS-60607 TV
Rear side windows
This may be just a case of inadvertently hitting the window lock out n th driver door window switch by mistake. Check that first. Here's some background on window operation
Principles of Operation
The driver power window regulator motor is controlled directly by the master window/door lock/unlock switch (and its integrated "auto down" module). Power is supplied to the power window relay and the master window/door lock/unlock switch, and the passenger power window switch when the SEC/timer module grounds the coil side of the power window relay. The SEC/timer module will ground this relay when the ignition is in the ON position and will remain energized for approximately 15 minutes or until the driver or passenger door is opened.
The driver power window regulator motor is a reversible motor that is operated by applying power and ground to the motor leads to lower the window, and then reversing polarity on those leads to raise the window.
The passenger power window regulator motor is controlled directly by the passenger power window switch and can also be controlled by the master window/door lock/unlock switch. Power is supplied to the power window relay and the master window/door lock/unlock switch, and the passenger power window switch when the SEC/timer module grounds the coil side of the power window relay. The SEC/timer module will ground this relay when the ignition is in the ON position and will remain energized for approximately 15 minutes or until the driver or passenger door is opened.
The passenger power window regulator motor is a reversible motor, which is operated by applying power and ground to the motor leads to lower the window, and then reversing polarity on those leads to raise the window.
The power rear quarter glass is also directly controlled by the master window/door lock/unlock switch. The power rear quarter glass power latches also utilize reversible motors. The power rear quarter glass power latches are operated by applying power and ground to the motor leads to open the window, and then reversing polarity on those same leads to close the window.
Symptom Chart Condition Possible Sources Action
  • All windows are inoperative
  • BJB Fuse:
    • F20.
  • Circuit.
  • Power window relay.
  • Front door power window switch.
  • GO to Pinpoint Test A .
  • Single power window is inoperative
  • Front door power window regulator.
  • Circuit.
  • Driver door power window switch.
  • GO to Pinpoint Test B .
  • Vent power window is inoperative — quarter window glass power latch
  • Circuit.
  • Quarter window glass switch.
  • Quarter window glass power latch.
  • GO to Pinpoint Test C .
  • The one touch down feature is inoperative
  • Master window regulator and door lock switch.
  • INSTALL a new master window/door lock/unlock switch. REFER to Switch—Master Window Door Lock/Unlock .
  • The back window will not defrost
  • CJB Fuses:
    • F30 (10A).
    • F32 (20A).
    • F34 (20A).
  • BJB Fuse:
    • F27 (45A)
  • Circuit.
  • Heated back window switch.
  • SEC/timer module.
  • Rear window defrost relay.
  • GO to Pinpoint Test D .
  • The back window defrost will not shut off automatically
  • SEC/timer module.
  • Circuit.
  • GO to Pinpoint Test E .
Jan 28, 2009 | 1999 Mercury Villager
Needing instructions to set up
If I remember correctly the master system only has one lead that looks a bit like an antenna connection, one goes into the back of the console and the other goes into the antenna input on the tv.
Then you need to plug the console in to mains outlet turn it on and tune in your tv to pick it up. I normally plug it into the antenna outlet and switch my channel on to the same channel that picks up the vcr, and it works
Nov 18, 2008 | Sega Master System Console
BOX THINGY
the box is a RF switching box
the lead you require is a phono to ariel lead (megadrive, master system or any old computer will do)
or if you get an old video lead and cut of one end and wire a phono plug to it it will also work.
or you try ebay
http://shop.ebay.co.uk/items/_W0QQ_dmptZUKQ5fVideoGamesQ5fVideoGameAccessoriesQ5fVideoGameAccessoriesQ5fJN?_nkw=sega+rf++Master+System++&_sacat=0&_fromfsb=&_trksid=m270.l1313&_odkw=sega+rf&_osacat=0
a basic lead for £2.50
replacments upto £10
both work
Oct 15, 2008 | Sega Master System Console
Sega master system
You need an RF Switch. Any kind will do. Sega model 3035 came with your console. Sega model 1603 or Nintendo NES-003 will also work. The RCA plug goes in the back of the console and the lead that looks like cable tv goes on the tv. If your tv does not have the right connection you can purchase an a/v cable that will work.
Oct 20, 2007 | Sega Master System Console
Hitachi 42PD6600 42 in. HD-Ready Plasma Television Logo
604 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
