Question about Kenmore 73952 Gas Dryer
Kenmore electric dryer series 70, on the inside of my dryer there is a plastic white ring that is cracked and brittle, clothes get stuck on this ring and tear, can I replace this white ring?
  • Kenmore Master
  • 7,482 Answers
Yes, you can replace that ring.
I believe you have a front loading machine, if so then you will need to remove the front of the machine to expose the ring, drum and belt.
Try this website and see if they can supply the part you need.
Good luck, I hope this helped
http://www.partsselect.com/
Posted on Oct 03, 2009
The hard plastic ring inside my Kenmore dryer has broken and it snags and catches clothes, can I remove this piece ?
You can remove but you need to replace the part or unit will get worse.Your clothes will start getting stuck
Sep 04, 2013 | Kenmore Dryers
I have an older Kenmore 70 series dryer. When I push the start button nothing happens. I know its not the electrical outlet.
Your thermal fuse is bad located behind access panel between fan and exhaust. Little white plastic fuse with 2 blue wires connected to it. Rate me if I helped you. Thanks and good luck!
Aug 26, 2010 | Kenmore Dryers
Dry is not heating.
Hi, Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Also on many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Apr 17, 2010 | Kenmore 73952 Gas Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore 70 series electric dryer. Clothes are
most common reason for this would be clogged vent...check all the way in and out!
Mar 16, 2009 | Dryers
My kenmore 70 series dryer will not dry clothes, but it does heat up inside and lets hot air out the dryer vent on the outside of the house.
make sure the dryer vent and the house vent are not clogged with lint this will slow down the drying process-mike
Mar 14, 2009 | Kenmore 62802 Electric Dryer
Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
As the push switch is sitting in its housing, the two red and white wires connect to the top contact (the one that splits into two). You should be able to tell which is top and which is bottom by the way they have routed themselves over time.
The black wire connects to the bottom contact, and the plastic clip connects to the side contacts (the left side as you are looking at the front of the dryer).
You can verify the connections on the diagram on the inside of the rear panel, which you should always do before connecting the wires and turning the dryer on.
Oct 12, 2008 | Kenmore 73952 Gas Dryer
Kenmore heavy duty 70 Series Electric Dryer
If you are using Fabric Softener Sheets than look in the dryer closely for one to be wedged in a fin or anywhere inside .They will make the streaks you mention. Please rate this !!!
Jul 03, 2008 | Kenmore 63942 Dryer
Dryer putting black smears on clothes
The white plastic pieces just inside the font of the drum are the front bearings there are aboutfour of these, you will need to take the front of the machine to put them in, your clothes are probably picking up black smeres from where the plastis bearings have worn.
Oct 18, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Kenmore 73952 Gas Dryer Logo
101 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
