Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Motor running good but the water isn't coming out of either the bottom or the hand held tool
Make sure your recovery tank is pushed down snug,somtimes it just need to prime itself,I had the same problem with my hand held tool, and that seemed to do the trick,after it pushed down,turn on power then wait about 10 seconds then turn on heater. I hoped this helped.
Posted on Oct 04, 2009
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Hoover steam vac maxx 77 motor suddenly not running?? its almost new
Should still be in warranty. Read the warranty and get in touch with Hoover.
May 07, 2015 | Hoover Vacuums
No spray onto carpet
You might have a clog in the heater. The upholstery tool water does not go through the heater. You will have to access. The heater and remove the cover to clean out the channels in the heater
Mar 04, 2014 | Bissell 25A3 Proheat Upright Deep Heated...
Have water at the hand held but none out the bottom
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jhklui
Nov 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Bissell 1699 not dispensing water
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Jul 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
No suction for the hand held tools
For the attachments, turn the knob on the left to tool setting, that will open the valve at the top to allow suction thru the hose, then squeeze the trigger to spray. Close it when you are done or you won't have suction down below.
If the water is running out, either the valve at the bottom of the tank isn't working right or youy have a water line off, probably have to take off the top cover to check that out.
Jun 26, 2008 | Bissell 1699 ProHeat Clear View Upright...
No water out bottom..
Pump may be bad, also the cap for the flow indictor may be leaking air. Does the automix vale knob turn easily? If it turns real hard, then piston that the knob works may be jammed. Ckeck the seals on the bottom of both tanks to make sure they are on the tank and not sitting in the holes.
Oct 04, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
237 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
