Question about Bose Wave Radio
Bose Wave Clock Radio
The screen is completely scrambled; on it are displayed all the features that it used to do. The off/on button doesn't work. The cleaning lady said she didn't drop it and doesn't know what happened to it. Help! lebenbaum355@gmail.com
  • Poko Jan 02, 2008
    I had the same problem for a little while. Now the display is completely blank. My Bose Wave is an older unit, manufactured in 1998. I believe it is a Series I or Series II. Any assistance would be appreciated. I don't want to spend $125 sending it in to Bose for repair because I understand the problem is a relatively inexpensive component to replace.
  • TimoLipping Oct 06, 2008
    I also had the exact same problem with an early Bose Clock Radio. It seem to fix itself the last few times by just leaving it plugged in, but this latest time when I had to unplug it, it's remained with all the function LEDs illuminated. Everything else is great and an electrician friend told me that the LED issue should be an easy fix but he happens to be in another state and the idea of shipping it out when a little jiggle on something on a board might fix it.
  • 52 Answers
Considering all power is good, check for broken or fractured solder joints at interconnects between display and main PCB on BWR-I.
Check cold solder joints on U302 and U301(IC302, IC301).
Good Luck.
Posted on Jan 03, 2008
Any update on this? I just had the same thing happen the other night. It completely powered off, and then 2 days later I plugged it into a different outlet and it came up all jumbled. Was it a cold solder joint or cracked joint? There was no traumatic event to the unit.
Posted on Oct 10, 2008
Capacitors to fix dim display wave radio AWR1-1W
Vacuum fluorescent display is worn out .. there is no repair. Replacement is the only cure.
Don Miller, CET
Bose Wave Radio Repair
don.miller60@outlook.com
Nov 30, 2015 | Bose Wave Radio
Need to replace plastic lens over digital clock display on bose wave radio II
Sorry, that's a job for the Bose service department. I doubt anyone else has that part.
Jul 09, 2014 | Bose Wave Radio II
Display not bright enough on Bose AWR1-1W clock radio
Yes...within a range. The display will automatically lighten and darken depending on the amount of light in the room. During the day or when there are bright lights in the room, the display will go to full brightness. When the lights go off or the room is otherwise darkened, the display will shift down to a lower brightness. You can make the "lower brightness" a bit brighter by holding down the CLOCK SET button and pressing the 'volume up' button.
Dec 26, 2013 | Bose Wave Am Fm Radio Awr1-1w Not Working...
The display is suddenly filled with information (sometimes unreadable). Everything has now stopped working.
From the sounds of it the microprocessor is scrambled, this can be caused by a power surge or thunderstorm, unplug unit, press and hold power button for 60 seconds in an attempt to clear the processor, if this fails this will be a job for a Bose factory trained technician.
Sep 16, 2012 | Bose Wave Radio
My 10+ year old Bose wave radio/alarm on fritz
Replace the 3 AA batteries that maintain memory & backup alarm function. That just may do the trick.
Apr 10, 2010 | Bose Wave Radio
The display on my Bose Wave radio does not light up.
try pressing the CD mode button while you press the on/off button. that should work!
Dec 25, 2008 | Bose Wave Radio
Bose wave radio
Bose does not release their parts lists or schematics, effectively creating a monopoly for parts and repairs. In fact, their web site says that the Bose factory is the only option for service or repair. They used to list a flat rate repair charge on the web site, but removed it - probably because it scared too many people. Their troubleshooting guide (below) might help, but it's very simplistic.
Before you invest in expensive factory repair on one of these trouble prone sets, you might want to investigate the new HD radios -- better sound at a MUCH lower price.
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/troubleshoot/index.jsp
Oct 20, 2008 | Bose Wave Radio
Bose wave does'nt display light ' can't see the time, Help
Hi
I read that if you hold down the Clock Set button and use the volume adjust you can change the display brightness.
Hope this helps with your rpoblem
Aug 09, 2008 | Bose Wave Radio
Bose Wave Radio - clock display turns off after 1 minute
Hold down CD Mode button and press On/Off button to set display to always on.
Apr 09, 2008 | Bose Wave Radio
Clock on Bose Radio
Push & hold Clock Set Button. While holding, push On/Off button,
Thank You, FixYa Community! Thank you! Thank you! Boy, that one was not obvious.
Nov 06, 2007 | Bose Wave Radio
Bose Wave Radio Logo
230 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
