Question about Plextor PX-760A DVD RW Dual Layer Burner
I have a PX-760A,''Power calibration area error.''
I have a PX-760A, it has been giving me trouble for a while now running very slowly when burning DVDs. Today I got a ''Power calibration area error.'' What does that mean and how can I fix it? Thank you,
Dave
3 Suggested Answers
  • 5 Answers
SOURCE: My dvd burner has trouble burning dvds now.
try
Posted on Jan 24, 2010
  • 55 Answers
SOURCE: At first my Plextor PX-760A can read CD, DVD5, and
this is called aging effect. different-2 wave lengths are required to read and write different type of disc. these different wavelength rays are emitted by a lense iside every dvd player or drive so as the time passes lense weakens its ability and can not emit the required wavelength to read that type of disc.
so no need to panic either u repair ur dvd drive lense or get it replaced with a new one. hope it willl be helpfull.
Posted on Apr 06, 2010
Trying to burn a dvd and i get this error please advise Module sfmmcx.cpp Line 2240 A medium error occurred. A Power Calibration Area error has occurred.
Your software and hardware are conflicting. Need exact problem for an exact answer. What type of burner, what type of program or software is trying to burn.
Feb 18, 2011 | Computers & Internet
At first my Plextor PX-760A can read CD, DVD5, and DVD9. But after couple of years, it reads CD and DVD9 not DVD5 anymore
Apr 06, 2010 | Plextor PX-760A DVD RW Dual Layer Burner
My atapi dvd a dh20a3p dvd writer keeps comming up with same error when i try to burn using nero the error is power calibration error how do i fix this and do i need to update the firmware as driver is...
I found the upgraded firmware for your drive here: http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=153
Disks have a test area on them where the drive can test write to calibrate laser power for the disk. This power calibration error means that this test write has failed for some reason. The most likely causes are bad media, a dead or dying drive, or a bad power supply. Try different media. If it is getting that error on the same drive with different media, check out your power supply fast!!! If it is an oem computer, they tend to use a cheap power supply that is just good enough to run the computer. If your power supply fails, it can other things in the computer. Download something that can monitor voltage. As these are not always accurate but its a starting point. Perhaps try monitoring voltage while you try a burn. You can also try reducing power usage (unhook usb/firewire devices, unplug power to extra hard drives etc. If it is testing with bad voltages and/or if reducing the amount of power fixes it, stop using the computer and replace the power supply fast before you have more damage to your computer.
Hope this helps
Sep 24, 2009 | Computers & Internet
Error power area on CRW-F1E WILL NOT BURN TO DISC
hello, if you are experiencing "power calibration error" all you need to do is click on control panel>administrative tools>services>imapi cd burning> then set start up type to "disable", >apply>ok, try to burn you cd again
Aug 09, 2009 | Yamaha Computers & Internet
Power Calibration error
powe calibration error reffers to lens laser power
in other words the laser doesn't have enough power to write CD/DVD at specified speed
try to clean the lens (there are special CD-s for that)
and try to burn the cd or DVD at slower speed
but slowly your cd writer is dying
Jul 08, 2009 | Sony Computers & Internet
Dvd burning abort everytime because of "power calibration error"
you can try changing power plug or just get your device cleand some times when to much carbon gets into points the currents is effected...
Jun 01, 2009 | Sony DRU 510A DVD±RW Burner
DVD burning very slowly
have you tried reinstalling nero to see if that sorts it out
Mar 15, 2009 | Computers & Internet
Power Calibration Error.
first re install your nero .and
A) Power Calibration is controlled by the recorder. Before any write operation, all recorders must do a 15 step power test to determine the optimum power for writing to the CD; this is called "Optimum Power Calibration"(OPC). And during the write, it continues to do this test to get the best write throughout the whole CD; this is called "Running Optimum Power Calibration" (ROPC). This whole process is controlled by the recorder, though initiated by programs such as Nero. There is an area on the inner part of the CD for the test and test data info to be stored. You can use this area up to 999 times.
So, when you receive the "Power Calibration Error" or "Power Calibration Area full" error message, then the cause will be either poor media, poor Power, or a defective Recorder.
POSSIBLE SOLUTIONS:
1) A might enable the OPC on this medium
2) Try another brand of CDR or CDRW media.
3) Also try different power connectors, and for recorders, do not share power with other devices. It needs its own power connector. If this occurs with an External recorder, the power source in the chassis could be the cause. Take the recorder out of the external chassis, and connect it internal, as a test.
4) Try different configurations, such as taking the CDROM to the Primary IDE bus as Slave, and have only the recorder connected to the Secondary IDE bus as Master.
5) Send the recorder in for Service.
Here is the direct Link: http://www.nero.com/en/632181809668074.html#23
I Hope this helps,
Feb 12, 2008 | Ahead Software Nero 6.0 (60045) for PC
Burnt a few CD-rs but now no burning.
  1. you can see the cd drive icon in your computer ?
  2. if your answer is no, do as follows, if you are little technical minded or consult a service technician
  3. switch off computer and open cpu cover
  4. check the data cable connection loose contact, refix it or replace cable if necessary.
  5. also check the power connection
  6. Can you burn other data or video files ?
Jan 21, 2008 | Plextor PX-760A DVD RW Dual Layer Burner
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
Plextor PX-760A DVD RW Dual Layer Burner Logo
82 people viewed this question
Top Plextor Computers & Internet Experts
Ben Armstrong
xkikbxr
Are you a Plextor Computer and Internet Expert? Answer questions, earn points and help others
