Question about Volkswagen Golf V Vw Scale Diecast Model
Need to know which fuse is my brake lights on my vw golf and if the fuse is good and I replaced the brake light, why is my right brake light not working
  • dennisnleah Oct 04, 2009
    replaced the bulb and checked the fuse but still not working
  • 571 Answers
Fuses are marked on the fuse box cover. Just follow the numbers.
If the brake lamp is not working, it can be
a) broken (try with another bulb)
b) loose (put the bulb properly in)
Posted on Oct 03, 2009
Ihave a 2001 vw golf 2.0l, the EPC light has come on. I,ve connected a fault code reader and it,s come up with code 16955 does anyone know the problem please.
Code points to "Cruise/Brake Switch (A) Circ Malfunction" which means the switch or connections might be bad. Most VW's of this era had a recall on brake switch, check with dealer to see if your car had it replaced. Stop lights might be out, cruise not working. Replace switch if any of these conditions present.
Feb 18, 2011 | 2004 Volkswagen Golf
How do i change the brake light switch on my vw golf diesel
The brake lights switch is fitted next to steering column under a dashboard.There is plastic cover-just follow the brake pedal and you will see the switch.Disconect the plug and turn the switch anticlock wise.
Apr 22, 2010 | 2002 Volkswagen Golf
Vw golf brake lights stuck on, replaced switch but
either put a return spring on pedal or readjust brake switch to disengage sooner
Aug 14, 2009 | 2004 Volkswagen Golf
Epc light on dash and brake lights not working
I doubt it's the fuse. A very common problem is the brake switch on your brake pedal goes bad. This causes the EPC light and no brake lights. This switch was recalled by VW in 2007. Here is the story from USA Today
http://www.usatoday.com/money/autos/2007-02-26-volkswagen-recall_x.htm
Your VW dealer will replace this switch free...
Jul 18, 2009 | 2001 Volkswagen Golf
Brake lights don't work
there is a brake light switch located on the end of the brake pedel, this will need replacing, quite fiddly job
Apr 05, 2009 | 1999 Ford Explorer
1989 VW Golf
be sure to check the bulbs, usually behind a panel in the boot, twist and turn, push and pull, give a go until the bulb comes out, get someone to press on the foot pedal, and reseat the bulb to see if it glows, look at the fillament in the bulb, just like a household bulb, no filament no glow,watch for the heat of the bulb.
look in under the dash on drivers side, in glovebox, passenger side panel(under dash), under bonnet is an array of fuses and the like, it should say brake or something similar.it won't be far from engine bay or front.
I don't know what the fuse looks like but no matter what fuse type it is you can tell if it is good or not by looking thru the clear panel at the little wire inside if it is broken then it's no good, another place to check is the foot pedal maybe the switch that activates the lights is broken? press the switch in and out, you'll see it right behind the brake pedal,the brake pedal actuates the switch when you depress the pedal. make sure someone is watching the brake lights.
short of buying a car manual or going to the shop but i hope it helps.
Feb 02, 2009 | 1989 Volkswagen Golf
Headlights don't work after replacing brake lights
check the power with a meter at the lights,no power a supply voltage fault,battery voltage at the plug ...new bulbs needed
Jan 19, 2009 | 2001 Volkswagen Golf
Electrical shorting?
check the earths on the rear lights a poor earth causes all sorts of weird problems...
Oct 03, 2008 | 1997 Volkswagen Golf
Volkswagen Golf V Vw Scale Diecast Model Logo
530 people viewed this question
Top Volkswagen Toys Experts
Gary Nitowski
Kulu Criss
Kulu Criss
Bogdan Odwazny
Bogdan Odwazny
Are you a Volkswagen Toy Expert? Answer questions, earn points and help others
