Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Hitachi 51f510 unit has no picture
I have opened the unit up all the led's on the boards that i can see easily all are lite. also i have checked all of the fuses that i can find and all tested fine. are there any suggestions to what possibly might be the route of the problem or solutions?
  • kentmm Dec 27, 2007
    unit shows that is turned on ie led test points boards come on, but displays no picture nor do the red green or blue lights come on.
  • kentmm Jan 16, 2008
    correct
    Genius:
  • 1,153 Answers
Is set coming on and no pic or not coming on at all.
Posted on Dec 22, 2007
Hitachi LE55A6R9A has sound but no picture. Passes flashlight test. No LED backlights appear visible at all. Trying to determine whether to start replacing boards or LED strips first.
The led driver may be on the main board or on it's own board. Led strips don't fail all at once so if you had a dark area of the picture then I'd suspect a led strip. TV Parts Universal TV Stands DLP Chips ShopJimmy This is the place to get parts.
Feb 13, 2018 | Hitachi Televison & Video
Hitachi 51f510 sound no picture
select hdmi on menu or dvi/component on tv
Jul 05, 2013 | Hitachi 51F510 51" Rear Projection...
HITACHI 51F510 SCREEN ASSEMBLY
The Hitachi site may have this available or you can Google the model number to see if you can locate one for free.
Front screen unit with frame is removed from the front but there are pitfalls to avoid when replacing the screens.
May 20, 2012 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510 has no picture. a RED X is visible after a pair of 'gears' in the middle of the screen appear during a long boot recovery attempt which fails ending in the red X
replace middle power supply broad that has 2 regulators, send to PTS for repair.Also check transistor mounted next to flyback transformer it maybe shorted too!
Dec 01, 2010 | Hitachi 51F510 51" Rear Projection...
Got no picture
The fault can be many but it is in the main board that the fault has come about.
check for power, fault in the convergence IC or failrue of the drivers.check if there is capacitors that have leaked/weakened or shorted.
A good test must be done only if you are familiar with electronics other wise do not tamper the board.
Check the fuses or any open resistors to the board
Aug 29, 2010 | Hitachi 51F510 51" Rear Projection...
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
NO PICTURE MODEL 51F510 HITACHI
hitachi is known for bad solder connections on plug connectors between the two main big boards
Nov 11, 2009 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510 CONVERGENCE ISSUE
Check the Blue CRT drive board for defective solder joints especially at the CRT socket
Feb 03, 2009 | Hitachi 51F510 51" Rear Projection...
Hitachi 51f510 Color problem
for testing, place the green crt board on the red crt and see if the red crt lights up and the green does not. If the green does not light up then check for 200+ volts on the collector or the output transistor. if you have that kind of voltage thee then check for an open resistor. If not then make sure the transistor is not shorted
Dec 28, 2008 | Hitachi 51F510 51" Rear Projection...
Hitachi 50" TV, no picture, blue light flashes
Replacing the board is much more expensive than repairing it, if the repairs can indeed be done...accordianman
Sep 16, 2007 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
85 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
