Question about Kenmore 98702 Stacked Washer/Dryer
Water won't drain
I have a Kenmore stacked Laundry center, my washer will not drain, this just started this morning. I'm hoping something is stuck in one of the pipes. If not what could it be??
    Genius:
  • Kenmore Master
  • 1,466 Answers
Check filter or pump. Clean as required..
Posted on Oct 03, 2009
Washer Dryer Stacked Combo won't start and didn't drain properly.
Hello Joshua, thank you for your post!
From my understanding your Frigidaire laundry center is not starting and did not drain properly. It is possible that this could be a miscommunication within the laundry center and a reset may help clear that out for you. In order to reset your laundry center you would need to disconnect power from it for at least ten minutes. If that does not help your laundry center you may need to seek assistance from a professional technician for proper repairs. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Apr 11, 2016 | Frigidaire Washing Machines
Washer won't drain and spin
Drain pump is cloged. What kind of washer is it . and you said stacked and laundry center. stacked is 2 seperate units and laundry center is one whole unit with both so whatcha got?
Feb 17, 2013 | Frigidaire Washing Machines
The pump on my kenmore laundry center washer is not pumping the water out of the machine...any suggestions?
check power to pump during drain cycle with meter. if power is good then it is probrobly the pump as the culpret.
Aug 18, 2012 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore laundry center model 92702 burning smell during spin and water doesnt drain
mine does this regular easy job if your desent at diy are you missing socks or wires from bra's as it probably the pump blocked take the pipe of the pump and see if there is any thing stuck in the pump remove it as long as pump not damaged should be fine probably get some loose change as well lol
Aug 17, 2012 | Kenmore 92702
My washer has water in the bottom of it. I pressed drain and spin it did then it filled back up with water.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Dec 01, 2010 | Kenmore Washing Machines
Kenmore 417.99980120 stack washer/dryer won't drain.
Check for a kinked drain hose. Also, if it is an older machine it could have something stuck in the drain pump. The usually culprit is an under wire bra
Mar 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Kenmore 98702 Stacked Washer/Dryer Logo
250 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
