Question about Philips Smart 25TS54C 25" TV
Infrared eye not working on tv
Tv infrared eye stop working on philipsmagnavox 32 in tv.remote control is ok.
2 Suggested Answers
  • 729 Answers
SOURCE: Infrared sensor not working
try changing your remote's battery and look for loose connections inside the remote control
Posted on Dec 05, 2007
SD Tech
  • 14553 Answers
SOURCE: I need a owner's manual for a 2000 32 inch philipsmagnavox television
First is to Google that model number with "manual" as this one should be out there or a remote chance is that Philips might have it available on their site.
Posted on Jun 15, 2012
0 characters
1 Points
Remote not changeing the station
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing each button on it at a time; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
May 25, 2015 | Toshiba 32A33 32" TV
Remote doesn't work for model ewf2702
Check the infrared emission from the remote control. If it is OK, the infrared sensor inside the TV is faulty. To get more details about how to check a remote control, visit the site named 'Electro-help'. You can search for it either by Google or yahoo.
Jun 08, 2012 | Emerson EWF2703 27" TV
Sansui hord rock 21inch eye ctv remot not working
The infrared sensor inside theTV might be faulty. Replace it. This component can be located just behind the infrared window at the front panel of the TV. You have to disassembe the TV to access it.
The component will look someshat like these.
May 08, 2012 | Standard (CRT) Televisions
The remote doesn't work on my toshiba tv zp38
Check the infrared emission from the remote control first. If it is found OK, repalce the infrared sensor inside your tV.
To get more details about how to check the remote control, get into this blog.
Named 'Electro-Help'
Apr 09, 2012 | Toshiba 32AF42 32" TV
I have a sony Bravia KLV-S40A10E 4 years old.Remote controle device is no ore working. Batteries have been changed without solving the problem .. Other Remote device ( DVD-Sony ) is also not working...
You just check your remote control handset for its infrared emission. There is an infrared light emitting diode [LED], in front of your remote control handset from which infrared light rays are send to your TVs infrared sensor, fitted inside it, behind the infrared window on its front panel. Infrared rays are invisible to human eye. We can check if it is there by using a cellphone with camera option.
Put the cellphone in camera mode, and place your remote control's LED side towards its lens, for about a feet away or so, and when you push its each button, you can see an image in the phones' screen. If it is there, and still your TV don't work with remote control, TVs infrared sensor inside is faulty, and needs replacement.
If there is no infrared image from your remote control, you have to buy one new remote control. OK.
Dec 18, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Remote not working
You just check whether the remote control has infrared light emission from it or not. It can't be see with our eye, as infrared rays are invisible to us. Put new cells in the remote handset before you proceed. If you have a cellphone with camera option, the things are easy. Put the cellphone on camera mode, and place your remote control just in front of its lens, at about one feet away or so, press each button on your remote handset, The camera will sense the infrared radiation, and you can see its image on its screen. If there is infrared radiation sign, and still your TV doesn't respond to it, your TVs infrared sensor inside it is faulty. It comes just behind the infrared window ath the front panel of your Tv. It is a three terminal component, and can be resoldered out of the board, and can be replaced. Open your TV, locate it and resolder it from the board. go with that as a sample, and buy a new one with same type and number. its number will be printed [laser markling], on its boady, and should insist on it,a s it is a critical part. Replaceing it will solve your problem. Ok
Dec 16, 2010 | RCA F36673ET 36" TV
I can not switch on my TV by remote control while the indication light is on
Have you checked if there is any infrared rays emitting from your TVs remote control? You cannot see it with naked eyes, because infrared rays are invisible. You can check it, if you have a cellphone with camera option. Put the cellphone in camera mode, and point your TVs remote control's front end [LED] side, towards the lens of your cellphone camera, at about one feet away, press each button on your TVs remote control. If there is any infrared rays comes, the cellphone camera, will detect it, and you can see it on its screen.
If there is Infrared Rays, the fault is inside your TV. Its remote sensor fitted inside the circuit board is damaged. You can replace it with an identical one. Before ensuring that your TVs remote control is damged, just check its cells changed, and look for any dust or rust on the contacts of the cell connections inside the battery campartment of your TVs remote control. OK
Nov 19, 2010 | LG Standard (CRT) Televisions
Cannot get my sky guide to respond on my Loewe Articos 32,i think the kids have scrambled the tv remote! Any ideas?
There are several things that can stop your Sky remote from working.
step one:
get a mobile that has a camera on it. point the remote at the camera and press the TV guide button on the remote you should see a little light by looking through your camera. This is because cameras dont like infrared
if you see the light whilest looking from the camera phone then the remote is working.
Step 2:
There can interfearance from devices like WII's or if your television has a back light you can turn this down and see if this is going to make any difference to the sky box.
If it does you know what is casuing the problem.
Step 3:
There may be another solution to your problem. Go onto Ebay and type in there Magic eye. you can get them from Argos but you will be paying 3 times if not more then you can get them off ebay.
once you've got the magic eye. plug this into the back of your sky box into RF OUT 2 this must be in 2 due to it providing 9v to the eye.
on your sky remote press services, 4, 0 1 select. go to Rf setting and turn this option to ON and then go down to save. you should see a little red light on the magic eye come on this is all done.
Now try your remote as normal.
I fit sky and a lot of the HD sky+ boxes have rubbish IR (infrared) so this sorts out a lot of problems.
Hope this helps
Little Dish Fitter
Sep 01, 2009 | Loewe ARC332 32" TV
Cannot get any remote to work
There is one way to test a remote control. Turn on your pc cam. Face the remote control to it, and as you press any of the buttons you should see blinking lights from the Infrared emmitter diode. Our eyes can't see this but a pc cam can. You can also use a camcorder or a camera phone. If you see light blinking the remote is bad. Just get another remote, maybe a universal one. If the remote blink most likely the problem is the device in which you are using the remote to control whatever it is. In the front there is an infrared recieving module. Try replacing that, you would have to open the device of course, and make sure you don't touch ruin anything in there with static electricity. You would need a soldering iron, a desoldering wick, and some solder to replace it. Other than that it is a job for electronic technician.
Jun 27, 2009 | Panasonic CT-32D12D 32" TV
Dec 05, 2007 | Sharp 25R-S100 25" TV
Standard (CRT) Televisions Logo
79 people viewed this question
Top Philips Standard (CRT) Televisions Experts
Sp Gupta
Jim Evans
Are you a Philips Standard (CRT) Television Expert? Answer questions, earn points and help others
