Question about Avanti 2.2 cu. ft. Chest Freezer CF61
Water leaking from under the unit - Avanti 2.2 cu. ft. Chest Freezer CF61
SOLD IT. NOW I HAVE NO PROBLEM.
Posted on Oct 05, 2009
Why does oil leak at the bottom of the Gibson refrigerator door
Hello Susan;
My name is Peter. I am a retired field service refrigeration technician.
You do not have any oil in your system with the exception of a few ounces in the bottom of your compressor. This is not your problem.
You have a water leak. The water will run across the bottom coils and the floor. By the time it reaches the front of your unit it looks oily.
Pull you unit out. Make sure you raise the leveling screws in the front first.
Remove the lower back cover. There are a few screws holing it on.
1.) Inspect the drain pan. Is it leaking?
2.) Inspect the water shut off valve. Is it leaking.
3.) Inspect the plastic tubing to your water filter, ice maker and water dispenser. Plastic tubing will dry rot and crack over time due to the heat.
4.) Have someone press your water dispenser while you observe for leaks in the back.
Feb 26, 2015 | Electrolux Frigidaire Tappan Gibson...
Why would condensation be running down the sides,or water dripping from bottom?
should be a small plastic tray funnelling from under the fins in back to a small hole n hose out the back of unit check owners manual if possible,..
Jul 08, 2014 | Delfield Freezer 6125XL-S
It's leaking water from underneath the unit
Hi there, I know that most units have a drip tray at the back or under the unit itself. well the older ones anyway, not sure with really new ones, but they shoukd. these trays hod water condensation and any drainage from the fridge itself. These trays sometimes have a coil in them which heats and help to evaporate the waterso that it does not overfill and spill out. these trays can become overfilled, the heating elemet can stopworking or
Jun 01, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My frost free freezer has had a small puddle of water under the front right corner several times now. I unplugged it and let it defrost completely thinking that would stop the problem but it hasn't. Can...
There is a chance the water is coming from the drip tray and or the drain hose to the tray.
when the unit goes into a defrost cycle it is leaking from one of those places check and make sure the hose is in the drip pan correctly and that the pan is also mounted properly and level.
If there is is a lot of water in the pan you may need to check the door seals on you unit and make sure they are sealing properly.
If there is an air leak then the unit could have excessive ice build up and also be defrosting more than usual amounts of water.
Jan 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Is a Kenmore Elite Upright Frost-Free Freezer supposed to have water leaking from underneath it? Would this be the water accumulating from the "defrost cycle" on it?
Is the drain pan underneath overflowing? If so the water filter may be clogged and the water leaking past it to the pan. The normal amount of water from the defrost cycle shouldn't fill it up. The condenser fan usually evaporates the water by blowing the warm air on the pan.
There could be a leak because or the defrost drain being stopped up but this usually comes out the bottom of the freezer door.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 16, 2009 | Freezers
I have a mr.freeze sa-12863 that is leaking water under the machine.help
If the water is actually coming from under the ice maker, I can't help you.
However, I just discovered water leaking from around the top of the lid on mine. I took the lid off [by first removing both side panels and then the screws for the top] and discovered that there is a metal plate under the water spout that causes water to splash up around the lid. In mine, this led to water running out aall the way around the lid, down the sides, and all over the counter. You can't remove the spout without messing up the water level sensor, but I bent the plate a bit flatter and no longer have splashing water everywhere.
Aug 21, 2009 | Freezers
It's my mother's Side by side Kenmore (4 yrs old). Iciles appear to form UNDER the icemaker unit. Filter has been changed and temp adjusted. What could be the problem?
it is possible that the tray itself has a crack in it. The icicles tend to make me beleive that you have a cracked tray because ice accumulates in the form of a cicle by consistantly dripping, running downward and over time the freezing occures . You might take food coloring and mix with water. Pour this mixture into yhe icemaker tray with the unit off and let it sit. If the tray is leaking the food coloring will let you know, if no leaks then it has too much water being allowed into the unit or too much water pressure. Good Luck
Dave
Jul 17, 2009 | Freezers
GE top freezer refrigerator automatic ice cube maker leaks water into the freezer, and eventually on the floor. Water seems to be coming from the area that fill up to make more ice cubes.
If it is leaking water in the freezer it will more than likely freeze amongst the ice cubes causing a block of ice.
It is more than likely leaking at the rear of the unit, near the valve or fill tube for the ice, this will run up the rear wall of the unit.
Mar 12, 2009 | GE Freezers
Water leaking from underneath the unit
hi thanks for the question is there water inside the fridge or freezer if not then the leak is coming from the drain tray at the back make sure the drain hose is located in the tray not outside the drain tray thanks the appliance doc
Sep 27, 2008 | Freezers
Avanti 2.2 cu. ft. Chest Freezer CF61 Logo
85 people viewed this question
Top Avanti Freezers Experts
Dennis Boxerman
richie46
mike cooper
Are you an Avanti Freezer Expert? Answer questions, earn points and help others
