Question about Vizio VX32L Television
My Vizio screen seemed to Freeze and then the colors seemed to streak vertically and stayed frozen also the sound seemed to get stuck like on one or two notes sort of a beep but I could tell the sound was as if whatever I was listening to at the time just froze.At first I thought something went wrong with my comcast cable box but when I tried to turn the TV off either with the remote or on the TV itself no buttons would respond. I had to unplug the unit in order to turn the TV off. If I plug the unit back in I can turn the power on to the unit with the remote or on the unit itself ,meaning the orange vizio light on the front of the unit turns white but nothing else seems to happen by pressing any other buttons.
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Help my vizio tv, model #e371va is stuck frozen? Help our VIZIO TV is stuck frozen?!My Vizio is froze on the setup screen and Ive tried everything to clear it.. Nor do i have the original remote any...
While the set is on, pull the power plug. Then hold and depress the power button in for about a minute. Then replug set and turn it back on. If that does not reset the tv then you do indeed have a serious issue with the set.
Apr 07, 2017 | Televison & Video
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
When i turn my vizio on is all it does is display vertical lines from top to bottom
mychaelmuch6
Go to menu.
press screen selection
just follow steps on how to clear or reset T.V.
Jul 23, 2012 | Vizio M420VT 42 in. LCD HDTV
Have a Vizio P42HDe purchased in 2005. Right half of screen is fine. Left half is series of small vertical bars (various colors). Sometimes they go away and all of screen is okay. Any ideas?
I bought mine in Jan 2005 and today it did the exact same thing....doesn't go away. Seems like a 5 yr. lifespan on these.
Will try a Panny for Christmas !!
mikebc580
Oct 12, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
We bought a Vizio LCD/HD tv for our daughter and she has had nothing but trouble with it. The current problem is that there is a dark streak that runs vertically around the center of the screen. It doesn't...
You seem to be describing a damaged LCD panel. Parts and service are extremely difficult and expensive for your set if parts and the service information could be found.
Generally speaking, the cost of replacing a defective LCD panel would exceed the total value of your set.
When buying a new TV, stay with the big brand names. Shop around. When you pick out some models you think you like, do a search on the net to know how your choice was rated. I would recommend to stay with the bing brand names.
Jerry G.
Sep 26, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
Dark shadow-like vertical streaks thru LCD screen (Sharp)
Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
VIZIO VS42LFHDTV10A Freeze Up
Just unplug the comcast and see how the tv works, if the TV works fine, then you will now the trouble is not your TV.
It is not likely to have the same issue in the new TV, just unplug everything and use a dvd to see how it handle it.
Jun 19, 2009 | Televison & Video
Vizio, color lines thru plasa screen
it sounds like you possibly have loss of vertical deflection it could be a ic or bad solder connections from your description and you may want to enlist your local servicer to help with this
hope this helps
Jan 17, 2009 | Vizio L32 32 in. LCD HDTV
No picture on 42" plasma TV.
take your tv to a tech the tv is having problem in the color circuit and the vertical circuit.
Apr 13, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Vizio VX32L Television Logo
186 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
