Question about Goodman GMS90703BXA Heater
The fan runs even when the heater shuts off. Someties it comes on for no reason.
    President:
  • 1,304 Answers
Check to see if it is in the auto position on the thermostat
Posted on Oct 03, 2009
Last week told we needed new evaporator. 2nd guy: it was not the evap replaced the tubing, had 2 ob leaks. recharged, fridge worked and then heated up again. notice door center edge is hot.
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
the reason the outer side of the door seal area is getting hot is the compressor is over heating, probably the condenser fan motor to your compressor is bad.
It should be a little warm but not hot. they don't use heaters anymore ( some older models still use heaters) around the doors, instead they use the condenser coils to remove condensation and moister, you might want to check your condenser coils on the bottom or back of fridge to see if they need cleaning
If the condenser coils/condenser fan are all plugged up they need cleaning and/or the condenser may fail or has failed..
The ones that use an electric heater will have an "energy saver" switch that will turn it off.: God is the reason I give you free advice so God is good!
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE.
Dec 20, 2015 | Maytag Refrigerators
Heater still runs after shutting off
Fan will come to dissipate any heat build up in heat exchanger
Apr 13, 2014 | Rinnai Water Heaters
Heater not working in extreme cold weather because fan wont shut off. fan has been replace and the computer has been checked. nobody knows what is wrong
I'm making some assumptions, here.. I've been told I make too many assumptions... but, I'm assuming that you're talking about the engine cooling fan.. If I'm correct in this assumption, my guess is that you've not taken the vehicle to a good, reputable mechanic or repair shop. There are several reasons that an engine fan would not turn off, and each reason would have to come from a qualified mechanic. For example, there is a sending unit for the air conditioning system that might cause continuous running... or a sending unit in the air conditioning system that could cause the same thing. To complicate that issue, quite likely your air conditioning system purposely kicks on the engine fan any time you run your defroster. Also, your inside heater should function correctly, regardless of the engine fan running continuously. If I'm wrong on that score, then your engine has a thermostat problem "to boot"... which, by itself, could cause poor heating of the inside of the vehicle. NOW, backing up a little, if you so happen to be talking about the fan INSIDE the vehicle that is part of your heating OR air conditioning, we have a little different matter on our hands... First, some vehicles legitimately have a fan running on slow speed at ALL times.. for continuous air circulation purposes (sometimes, you can't actually hear this). Also, I might add that THIS fan running all the time should not be a problem for the heater to work properly.
Jan 03, 2014 | Cars & Trucks
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
When Thermostat is satisfied and shuts down the furnace, the furnace fan will not shut off. It is supposed to continue to run but only for a short time. This one will not shut off at all.
Your thermostat has a feature for the fan AUTO or ON. If it is in the AUTO position and still won't shut down then I would check the Fan relay. Newer models have a control board with the relays built into them so the control board would be suspect. Older models use a Fan/limit. The limit has a probe in it. As the heater warms the bi-metal inside it twists around and the fan comes on at about 110f. When the thermostat is satisfied the burner shuts down but the fan still runs till the heater cools down the bi-metal cools off and shuts down that fan. These will hang up with age.
Nov 11, 2010 | Heating & Cooling
Heater won't heat very long
there isnt a pilot if it has jets , it has a Hot surface ignitor. you should see a glow and then the jets light , if its running for a few min it may be overheating, have you changed the filter recently? you should also have a flash code you can locate when the furnace shut off and is no longer doin what its supposed to look thru the bottom door peep hole and watch for a series of red flashes. if you remove the cover after retrieving the flash code there will be a chart on the inside of the cover that will tell you why the furnace is shutting off. by the way the model # you gave is for the A/C coil above the furnace, not the furnace.
Oct 10, 2009 | Heating & Cooling
Flame wont stay lit
Sounds like a flame sensor problem. The board is not getting the proper signal from the flame sensor so it thinks the burner did not light and shuts the gas supply off. It keeps the blower operating to ensure that no gas is accumulated in the burner area. I suggest you contact a local mechanical contractor to service your heater.
Jun 23, 2009 | Pentair Minimax NT Heater
Heater Shuts off at 1500 Watts
Could be a bad element if the heater does not run at all at 1500w.
If it runs a little before stopping, things could just be dirty causing the thermal sensor to shut it off. A good cleaning is needed in that case.
Good Luck,
Denis
Oct 09, 2007 | Marvin W.B. 3150 Convector Heater/Fan
BLOWER FAN WONT SHUT OFF WHEN THERMOSTATE IS OFF
The compressor coming on when the contact is pushed is o.k. they all do that. As for the blower fan not shutting off, some brands (Payne for example) the heating fan relay is a n.c. (normally closed ) relay. so if the time delay relay or thermal link are bad or not connected, the fan will blow even when it is turned off.
Aug 19, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
