Olevia hd 42 tv no signal on vga from pc was working good 12 hrs ago .swap cables from tv to moniter from spliter moniter works ..still no signal two years and about 8monts old never used vga till three weeks ago..
  • 1 more comment
  • cadillacserv Oct 03, 2009
    wtried propities got to settings did not get box only screen looks like hard drives
    ps.did not get display option .
  • cadillacserv Oct 05, 2009
    PLEASE GET ME OUT OF THIS SERVICE TO HARD TO GET IN NO WAY OF TALKING WITH LIVE PERSON I WANT OUT ...SAM LUSCO 205\781-2318 EMAIL CADILLACSERVI400@BELLSOUTH.NET
  • 4,924 Answers
First check the cable for damages..if possible try a cable without spliter to see if the driver its set and working with it ...if it does not ..it means that a settings was changed or so ...and the driver is the problem ...either reinstall it ..and redo the settings for it ...or ...just restore the computer to an earlier stage ...a date when you know for sure that both worked fine ...this will exclude from your equation the driver problem ...after that if it still not working ..it only means that is a cable problem or ..a setting from the device that does not work ...
I hope you know how to restore setting into a computer to an earlier date ...look into control panel ( switched on a category view) ..when you press maintenance you will have the task into the left bar
Posted on Oct 06, 2009
  • 13,433 Answers
Check the cables and make sure the right channel (or input) is turned on from the tv, if you use the splitter, make sure its switched to the right setting if it has a button/lever/switch.
Then after those are set properly get on your computer and right click on the desktop, select properties from the bottom, then take the last tab - settings as shown on this picture ::
you should see 1 and 2 boxes.
1 is your main display 2 is the other display or tv.
right click on 2 and select attach.
you should get picture on the tv now.
Posted on Oct 03, 2009
  • Ekse Oct 03, 2009
    what kind of computer you have? does it have WINDOWS XP or WINDOWS VISTA?
I have an RCA Remote that turns on Olevia tv but won't find a signal and neither does the tv remote. I'm on cable.
perhaps you need to set it on channel 3 for the cable to work .. the cable box must be on when doing any searching also
Jan 19, 2015 | Olevia LT42HVi 42 in. LCD Television
Olevia HD tv with no signal. Tried troubleshooting with cable provider, no results. Help!
If this is a problem you had while continuously using the same cable TV and provider, check whether the TV works well with any other input device. Look for any loose contacts in RC Jack, cable and connectors.
Aug 22, 2012 | Televison & Video
I have a del latitude E6410 laptop and would like to know how to connect it to a pansonic 42 flatscreen hdtv to use it as a moniter
Dell Latitude E6410 does not offer HDMI or DV. Only VGA Port is available. Therefore in order to connect the laptop with the TV, you can use VGA cable.
But if the VGA input is not available on the TV, you need to get VGA-to-DVI or VGA-to-HDMI Adapter, depending upon the type of port available on the TV.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Aug 18, 2011 | Panasonic Computers & Internet
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
47 inch Olevia plugged directly into cable no box and will not program. All other old cable ready tv sets work without box
Diffrent tv,diffrent signals,deffrent frequencies.Talk to ur cable company for the box,to many pay tv signals in one area this day,that why need a box.
Nov 05, 2009 | Olevia LT42HVi 42 in. LCD Television
I have an Olevia 23t lct hd tv. I am plugged in
you said you are using composite cables..? that means you have some kind of cable box ? if you want to get HD channels you have to use a HD box that is supplied by the cable company.. the HD cable box then has to connect to the tv with component cables (green,blue, red cables) or HDMI cable.. to send the HD signal to the television.
May 13, 2009 | Olevia 237T 37 in. LCD TV
Using a vga cable to hook up my pc to the tv and doesnt work
did you change the imput --use the remote--push imput, change to component
Mar 12, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Ilo 42'' says no signal on VGA when connected to a computer
Snap off/fully remove pins 11, 12, and 15 from a spare VGA cable and use this to connect the ILO tv. These pins are used for identification of the monitor by the PC. The video signal is now displayed perfectly on my ILO tv, in all supported resolutions.
Mar 11, 2009 | Televison & Video
Cant connect to pc
It high definition digital signal. You will need a HD cable not a vga (that is analog).
Check in you tv manual. It should give you options of what cable to use. May need the HDMI cable.
enov8
Mar 08, 2009 | LG 42LG30 42 in. LCD HDTV
Connection for tv cable to hitachi 42" plasma Tv
there is no cable slot. the monitor is not a receiver. it has no tuner in it. it will need a signal from a tuner box. and that must be fed to the tv with an hdmi cable or a dvid cable for hd to work. see your manual for further information on cables. see your cable supplier for information on hd boxes available in your area. if you do not buy hd service, you will not get an hd signal. so you will see little difference from a non hd device. your dvd player may have hd capabilities, but will also need the same cable to deliver true hd signal.
the good news is that its fixable by using the right equipment.
good luck
mark
Dec 07, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
