Question about SanDisk Sansa c140 MP3 Player
San disk player repair
I am getting error " no space for db free more than 4 mb"
I have tried using repair tool from Sandisk...it fails and tells me to contact customer service.
Driver update also fails...
Infact now there are colors, but i cannot see any meny like settings or radio etc ,,,, i can still see picture of radio ..i hope i am making sense
please help me
  • Anonymous Dec 25, 2007
    my sansa disk mp3 player says mtp db mismatch please delete more than 4mg and i deleted every song off of it and is still saying the same thing
I'm having the same difficulties, but I can't even find my mp3 player on my computer. I went under my computer and it's not there. Can anyone help me....
Posted on Jan 15, 2008
    Problem Solver:
  • 19 Answers
I don't know if this will help but you can try this:
If you can, open your mp3 player and go to settings. Under the USB menu change it to MSC.
If you can't don't worry, but either way try this:
Plug in the mp3 player to the computer. Open the My Computer on your desktop, right click on the Sansa mp3 player and click Format. Make sure Fat32 is checked and Quick format is UNchecked. Then format the mp3 player. After that it should be clean and work just like a USB drive.
Posted on Dec 23, 2007
Not enough space for music db.Please free 6 mb.But I have no music on it.
There is a factory reset option in the menu somewhere. Use that, or you can format the disk in the settings menu as well.
Oct 09, 2009 | SanDisk Sansa e250 MP3 Player
NOT ENOUGH SPACE FOR MUSIC DB
if it detects in your computer then you can try formatting it....if not,try sliding the hold key to off position then connecting to PC...it must get detected as a removable disk...format the disk...
Sep 11, 2009 | SanDisk Sansa c240 MP3 Player
The player tells me there's not enough free space for music DB and I need to free 30 mb. At that time the player was empty. I've erased the disc and it still gives me the same message. What's the deal.
try formatting the disk and then if that doesnt work run a scandisk check on it.if even that doesnt work,use sansa updater that may have come in the CD provided alongwith the player.
Sep 06, 2009 | SanDisk Sansa Clip MP3 Player
Unable to play music
hey :
sir you ned to upgrade ur device using this tool
click here
to download it
dont forget rating this post if this is not helping u tell me so i can help u further .
Jul 23, 2008 | SanDisk Sansa m250 MP3 Player
Sansa C150 No Space for DB. Please free more than 4.0 MB
are you able to format the player while in msc mode?
right-click on it while in my computer and select the format option, make sure your selecting your mp3 as this will delete all the files off the device. It if says failed to format, try doing it thorugh disk management. To get there you can right-click on my computer and select manage from the drop down menu. From here you will see disk management on the left hand side. Then a larger rectangular box with the drive letter that represents your player, you can right click on this and select format.
Or just try a different computer, if its the same everywhere then youll probably have to end up emailing sandisk, stating everything you tried. They will probably ask you to do a couple more things, but if you keep at it, youll end up with an RMA*.
*RMA = Return Merchandice Authorization
Jun 21, 2008 | SanDisk Sansa c150 MP3 Player
E260 shows 0 MB memory and 0 MB free space after recovery
Look, I think the best thing to do is to return the product. Normally, they gave you a new one. My old one broke with a blank screen. So the bestbuy guy talked to his manager and gave me a new one.
Apr 24, 2008 | SanDisk Sansa e260 MP3 Player
Music DB?
You have put too many songs on the device.
It needs some free space to create the Music Database or the Artist, Album, Song information.Generally between 6 - 10 MB for each GB of music on the device is sufficient.
If it shows up in My Computer, you can manually delete some files from the MUSIC folder.
If not, you can use the following software to erase everything and start over.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Nov 27, 2007 | SanDisk Sansa e260 MP3 Player
Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Aug 20, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa c140 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
