Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
What are the carb settings on a Ryobi 765R???
  • enwalk Oct 03, 2009
    carb is walbro and there are two sdrews on the top and an i screw
  • Wayne McNeil May 11, 2010
    What type of carburetor does it have? zama, walbro, tillotson, etc. and how many screws does it have in total?
    Scholar:
  • 135 Answers
It should be 1 1/4 turns on the screw with the letter L and 3/4 turns on the screw with the letter H. Off course, both screws need to be lightly seated before backing them out. Good luck
Posted on Oct 03, 2009
How do I adj carb on ryobi bp42 that is too lean
some carbs have a small screw located in the throttle shaft at the lever
there may be a small plastic block that has to be removed first and then a small screw driver to adjust the screw
probably better to get a repair kit or new carby as that setting very seldom changes
Oct 24, 2016 | Ryobi Garden
How do I remove the carburaetor locks on Ryobi ss30 seedeater I am a beginner lady learning to fix my own stuff
Remove carb mounting bolts. Carb obsolete not available. This may help: http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Dec 22, 2015 | Ryobi Garden
What tool can you use to adjust the carburetor on ryobi gas weed eater
depends if u have the export only carb , because if you have the C.A.R.B. model it's not adjustable (other than idle) , if you have the export only version then there are two small plastic caps on side that can be moved aside and screws can be accessed to set HI and low speed jets
C.A.R.B = California air resource Beauru
Apr 18, 2015 | Ryobi Garden
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
How do i set the carb on a ryobi
Initial setting is 1 full turn CCW on both low and high side adjustments.
Feb 25, 2015 | Ryobi Garden
I have been given a ryobi 306rt petrol strimmer. It starts and then cuts out, I'm not sure of the exact settings as to how you start it up and keep it runnng. Any help would be apprciated.
To give the inital fuel needle mixture settings i would need to know the type of carb. on the unit ie. zama,walboro ect. it should say on the carb.,it may take a little hunting for. Second check all the fuel lines running from tank to carb. checking for craks or breaks.
Dec 26, 2009 | Ryobi Garden
MY RYOBI BC 30 WILL NOT RUN WHEN I SET TO C FULL
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 29, 2009 | Ryobi Garden
Ryobi pcn3335 wont start at all. Not a kick???????????
Hmmm could be a clogged muffler,fuel line, the carb might need to be cleaned or rebuilt or dirty fuel filter or if u have on the saw thers a low and high idle screw setting, usally on the side of the carb that might need to be adjusted.
Jun 04, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Unable to start Ryobi 410r cultivator
After starting close the choke , push the lever back in
Vitally
Jun 02, 2009 | Ryobi Cultivator
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
269 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
