Question about Motorola Mobility H700 Wireless Headset
How do i connect my bletooth h350 to my phone
I need help I bought bluetooth b4 the phone & lost instructions. how do i connect my headset to my phone.
  • naldjulie Dec 30, 2007
    my mobile phone is 6230, i really have a hard time connecting h700. i tried many times but notning happened. i even followed all the suggestions given but still i couldn't connect. pls. help me on this matter.
  • feb122008 Jul 25, 2008
    I have a Nokia 6085h and a Motorola 350 h bluetooth, but no instructions for th bluetooth. How do I connect it to my phone?
Thank you was very helpful
Posted on Jul 28, 2008
    Genius:
  • 1,003 Answers
On your phone go into menu look for connectons or bluetooth turn this function on then hold down hook button(big button with phone symbol) on the bluetooth until it stays solid (mic still folded in) then flip out the mic then pair phone phone will usually ask bond or pair with headset select yes enter passcode 0000
Posted on Jan 14, 2008
Here is a link for the manual :
http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
The connection code is 0000
and read the posts here :-(
Posted on Jan 12, 2008
How to disconnect bluetooth headset from a lost phone
I bought a Jabra Bluetooth headset, It worked fine with my phone(nokia). I lost my phone now. Now i want to use the same headset with my new phone (huawi), but i am unable to connect it to my new phone as the phone is already paired with my previous phone. So please help me with the issue and tell me is there any way i can disconnect the bluetooth headset from my previous phone??
Jun 04, 2009 | Jabra BT125 Headset
My bletooth h350 handsfree device needs a pass code for my phone to accecpt
All the motorola bluetooths that i have had that needed a passcode used "0000". See if that that works. Good luck!
May 28, 2009 | Motorola Mobility H350 Wireless Headset
I need to connect a motorola H550 bluetooth with my samsung SGH p207 cel phone i dont have instructions
ok here u go first turn on the bluetooth func in ur mobile, now while ur bluetooth haedset is off press the power centre big button for like 10 sec until the blue light stays on continously not blinking position ok then search for bluetooth devices in the phone bluetooth config ur headset will some up like motorola h550 select it then it will ask u for pairing code input 0000 and press ok ur device is now connected u will see the blue light which was continous b4 now blinking it means ur haedset is connected , u have to complete this process in almost 1 min bcoz there is a timeout for this process , now try any call u will hear it in ur headset
pls rate me fixya if i have fixed ur problem
Feb 24, 2009 | Motorola Mobility H350 Wireless Headset
CAN'T GETHE HEAD SET CONNECTED TO MY RAZOR
Hey Sadie,
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 19, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Motorola Bluetooth® Headset H555
This will vary depending on the model of your phone. First off, you need to ensure that you are using a bluetooth enabled phone.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
Jan 14, 2008 | Motorola Mobility Bluetooth Hands Free...
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Headset setup
http://www.plantronics.com/north_america/en_US/products/cat1150057/cat1150057/prod5560012?prodfind=true&mftr=MOTOROLA Go to this website, and scroll down to Interactive Bluetooth Pairing Guide. (Plantronics 330 - V555 doesn't show 320 and instructions will be similiar). Click on Interactive Bluetooth Pairing Guide and a tutorial will walk you through the steps. Have headset and phone together when you do this and both must be charged. Hope this was helpful. Pam
Jun 11, 2007 | Plantronics Explorer 320 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
196 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
