Question about Fasco Bradford White Hot Water Heater Exhaust Draft Inducer Blower # 239-42133-00
The blower on my hot water heater just buzzes when plugged in. Unit was to hot to touch so my gas delivery man told me to unplug it for a few hours and it might work. it didn't. is there any way to turn the prop. and would this work? This is a 14 year old unit, but I really can't afford a new one now. Thanks Rick
  • rickmorris58 Oct 03, 2009
    Of course this is Sat. can i get a blower before Mon? And is this something I can do on my own?
    Finally, could running out of gas cause this failure?
  • Fasco Master
  • 15,557 Answers
Depending on the type of motor that is in it, there may be very little that you can do. The fact that it got hot was an after occurrance of the fact that it did not rotate. The reason that it did not start and rotate could be loss of the armature coil connection due to an open in the coil somewhere. It might also be due to a bad phase capacitor if it is that type of motor. The best thing that you can do and I highly recommend it is to get it serviced professionally. Due to the age of the unit and the fact that you are dealing with something that could release carbon monoxide into your livingspace.
Posted on Oct 04, 2009
  • 10,865 Answers
Tick your blower motor is shot. truthfully the fact that you got 14 years out of it is one for the record books. you are going to have to bite the bullet and replace it............
Posted on Oct 03, 2009
Noise blower motor
leave unplugged... water will stay hot.
Plug in for 1 hour to make tank of hot water
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
Jan 18, 2014 | Water Heaters
Does the vent motor come on when you turn on a powervent hot water heater
`1) Copy following link to troubleshoot by type of gas control valve, blower motor links, pressure switch testing, and other professional resources:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) Power-vent blower motor can go bad.
Plug motor directly into outlet, or turn on-off switch on, and see if motor works.
Check outlet for correct polarity, and for at least 80% of rated voltage.
Check vacuum switch. Blower creates vacuum, and the vacuum switch detect vacuum, and signals gas control valve that burner sequence can continue.
Gas control valve can also go bad. Wiring etc can go bad.
Feb 04, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Got hot water for a little while then stop geting hot water
Hello
If you have a gas water heater and its a few years old and it has an electric fan for exhaust unplug the fan motor from out let and plug it in again this will rest your hot water computer and sensors. If the burner comes on which you will hear right away,, then it means your flame sensor needs cleaning its a 3 inch rod its infront of the door opening or water control below,,, slide cover off and one screw is holding the flame sensor rod. also look for a flashing red light down by the cntrols if it is flashing call a service man, in you need a computer board or module replaced if its a rental?,, its free. Please if this is Gas if you are not sure Call service man right away if its electric water heater Call for service likwise dont attempt repairs unless you need to rest your fuse on the electrical panel. Careful please lives could be in danger if you attempt anything you are not sure of Dont touch it!
Joe
Oct 08, 2012 | RELIANCE ELECTRIC WATER HEATER
I have a Rinnai Tankless and I have a problem with the water going from hot to cold so I called to have it serviced, I was told that it needed to be flushed to remove settlement from the unit. Okay we did...
Did service man clean combustion parts and check for loose wires, proper venting etc?
In other words, is the tankless up-to-date on yearly required maintenance?
Did you check outlet for power?
Is the unit properly grounded?
Is the unit vented properly, and set for correct altitude?
Is the thermostat set too high?
What does the manual say about maintenance?
It certainly says to clean water filter frequently, and clean combustion parts yearly, and bleed air from gas line, and delime yearly.
Is your water heater exposed to more than 11 grains hardness in water that will cause failure due to clogged parts?
Does service man have a service manual for your specific water heater?
Does anyone have a service manual for your water heater? Probably not, which means service man will be guessing at one thing and then guessing at the next thing.
Problem could be PC board failure.
Similar to failed motherboard on computer.
Let's be frank:
Do you want the cheapest solution?
Or do you want to chase around trying to find why a complex computer chip connected to electric outlet, electric sensors, gas valve, water valve, water line, gas line, and gas burner with vent to outside has decided to stop working?
Cheap solution, Buy tank-type gas water heater for $350 at local box store. Just get a simple one off the shelf. Don't worry about warranty, because it means nothing.
Select Whirlpool, AO Smith, American, State, Reliance, Craftmaster, Kenmore because these are made by same company and can be repaired and maintained by homeowner, and service manuals are available, and any plumber knows how to fix em..
Avoid Rheem, Ruud, Richmond, GE, for all same reasons except in reverse.
Read the manual, perform the required maintenance.
Keep the air intake clean.
Install water heater yourself same day, turn up the temperature wait, 1/2 hour for tank-full of hot water, and take hot shower.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Oct 05, 2012 | Rinnai Webstone The isolator EXP tankless...
Bradford-white water heater wont heat water.the blower motor hums but wont blow.also,pilot light wont light,is this just a safety feature?
Water heater is not identified and gas valve is not known.
Review options below:
1) Add a comment and describe what gas control valve is on the water heater, and model number from label on side of unit. Include what you have tried so far.
2) Try unplugging water heater and see if water heater resets.
Disconnect blower from gas valve, then plug blower in to see it it operates.
This will eliminate or include blower as suspect.
3) Open following link to download service and product manuals to help troubleshoot exact model.
http://www.bradfordwhite.com/documentation/residential/gas.asp
4) Open following link to identify gas valve.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Oct 04, 2011 | Fasco Bradford White Hot Water Heater...
My family is moving in...how do i increase hot water availability?
large water heater, turn p the themo stat to a higher setting ( watch for burns with young childern and older folks)
or the best install a tempering valve. this valve mixs hot water with cold water before it goes into the building.
Again if you have young ones or old people they can burn faster than any other group.the best is a larger heater for the DIY person.
Thanks Tom
Sep 13, 2011 | Rheem Water Heaters
Pilot liht wont stay lit on hot water heater.
You will need a new thermo coupler to keeep the pilot ight on. It is a probe that touches the pilot flame to sense the the regulator to feed the gas flow. Upon failing it shuts off the gas to the regulator so the unit does not catch on fire. In other words it is a fail safe part that is required
Apr 12, 2010 | Water Heaters
Fasco Bradford White Hot Water Heater Exhaust Draft Inducer Blower # 239-42133-00 Logo
56 people viewed this question
Top Fasco Water Heaters Experts
Gil Shultz
Gene Haynes
Are you a Fasco Water Heater Expert? Answer questions, earn points and help others
