Unable to get water to drain from washer - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,466 Answers
Clear out filter..
Posted on Oct 03, 2009
My GE front load washer stopped draining
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water
Dec 30, 2016 | GE Washing Machines
Fahe1011mwo Frigidaire washer won't drain
Read more:
Dec 29, 2016 | Frigidaire Washing Machines
WHAT DOES IT NEED DONE WHEN ERROR MESSAGE SAYS 0E
An OE error code indicates that the washer was unable to drain the water. The main causes for this error code are a kinked drain hose, a clogged drain pump filter, or a problem with the drain pump itself.
Oct 24, 2015 | LG WM2301HW Front Load Washer
Door will not unlock and water will not drain also get an err.code oE
Hello & Welcome to FixYa
Correct, OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter located inside the bottom front panel for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Aug 10, 2011 | LG WM-2277HW Front Load Washer
Washer will stop after rinse cycle and says OE. Then is will not drain rinse water.
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | LG Washing Machines
My washer has stopped it still has water and soap in it OE is flashing on the screen
Kevin
Apr 05, 2011 | LG WM2277H Front Load Washer
WF328 AAG OE error code...how do reset this? or can I reset this?
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code.
  1. Locate your drain pump access door on the front of the machine.
  2. Clean out the filter area.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
Jan 24, 2011 | Samsung WF328AA Front Load Washer
Ld signal won't drain
For the LD error please check for the following:
  • Check for kinked or clogged Drain Hose: Remove any obstructions in the drain hose / stand pipe / utility sink. Straighten the hose to remove any kinks. If the washer is unable to drain due to a kinked or restricted drain hose, the washer may not spin.
  • Check for Standpipe higher than 8 feet above the floor:The pump is not powerful enough to pump water to heights greater than 8ft. The water will remain in the basket.
  • Check for excessive suds in the washer: Drain pumps cannot drain suds out of the washer.
To clear the suds condition: Check the drain hose and make sure the hose is not plugged or kinked Press pause/cancel twice to clear the display Run the machine through a Rinse/Spin cycle using cold water, then a Normal cycle using cold water.
Note: Do NOT add any additional detergent. This will remove much of the remaining detergent held in the fabric. This step may have to be repeated to remove all the detergent.
Jan 16, 2011 | Maytag Bravos MTW6600T Top Load Washer
It won't drain...keeps stopping and says OE
Kevin
Dec 11, 2010 | LG WM-2277HW Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
