Question about Microsoft Xbox 360 Console
After running console for about 10mins the unit freezes and the lites on console turn red but only the upper and lower lites on the left side turn red
  • 767 Answers
If the fan start to increase in speed rapidly till
it's at full speed with in 3-5 min the G.P.U has lost
it's thermal seal to the heat sink .Some time if
the unit take a fall this can break that seal .
if the seal broke on the C.P.U. your unit would
go to two red almost immediately , so i don't think it's
the C.P.U.
OK the fix is to open it up and press down firmly
and evenly on the heat-sink under the CD drive
that is the G.P.U.s heat-sink .This should re seat and
restore normal operation .
That it
Rob
Posted on Oct 03, 2009
Testimonial: "thank you repairtech99,i just had this console apart and i wonder if your right about that seal not being positioned correctly?THANKS TOM"
Installed new upper & lower elements & thermostats, only top htr works
If original problem was caused by sediment burning out lower element, did you clean sediment out of water heater when changing lower element?
Two element water heaters are 240V.
Thermostats cut power on one hot wire, but 240V circuit has 2 hot wires. So lower element has power at all times coming from the red wire.
1) Use ordinary tester or multimeter set to 240V <> test each screw of lower element to bare metal part of water heater. Each screw should show 120V. If there is no power, then upper thermostat is defective, screw on upper thermostat is loose, or red wire between upper and lower parts of water heater is bad.
2) Remove wires from lower element. Use continuity tester or multimeter set to ohms <> test across both screws of element to see if power travels through element <> if element is bad, then continuity tester will not light up and multimeter will show no ohms. Put wires back on element after test.
3) Start with cold water in tank. Turn on water heater & upper element will turn on. Put ear on side of tank to hear if upper element is heating water. Test #3 screw to #2 screw on low left side of thermostat, should read 240V > Test #3 screw to #4 screw on low right side of thermostat, should read 0V.
Put ear on side of tank. When upper element turns off: Test #3 screw to #2 screw on low left side of thermostat, should read 0V > Test #3 screw to #4 screw on low right side of thermostat, should read 240V. If this test shows 0V and 0V, then upper thermostat is bad. If reading is correct, immediately move to next test.
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
4) Turn temp on lower thermostat to 150. Using ordinary tester or multimeter set to 240V <> Test across both screws of lower element. If there is no reading, and you know element is good from step 2, then lower thermostat is bad, or wire is bad between lower element and lower thermostat, or wire is bad between lower thermostat and top part of heater.
5) Test across both lower thermostat screws, should read 240V.If this test is good, it means wires are good. Put jumper wire across both screws of lower thermostat, and test lower element again. If element finally turns on with jumper wire, then lower thermostat is bad.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If wire is bad between upper and lower parts of water heater, and water heater has tight-fitting 2" foam insulation, it usually indicates water heater replacement.
Sep 20, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
My console is not working. Is there a simple solution?
This unit power supply that plug in the wall, If you have a multi meter. I suggest checking the outlet and work your way back to see if their is DC voltage, assuming 12V if this voltage is not present then replace power supply. If it is present then you my have loose connections inside the the unit or defective upper console or lower electronics. The simple way with out taking the side panels off is to remove the upper console and disconnect the 4 lead connector. Find the usually red and black attach your meter and see if you get 5V DC, if you have this voltage then the upper console will need replacing. If not then I would take the side panels off then check the connector leading to the lower board if I have voltage going in and not out replace lower board.
May 31, 2010 | Bodycraft ® Ect 2500 Elliptical Trainer
Where is L&R button on the DS Lite Console
Shoulder buttons L and R are located on the upper corners of the lower half of the system.
Jun 11, 2009 | Nintendo DS Lite Console
Console freezing in main menu after a min green and red dots
do not perform fan test not good for unit. use vacume to clean out unit. if it was the motherboard it wouldnt turn on at all.
Jun 01, 2009 | Sony PlayStation® 3 (60 GB) Console
Problem with right turn signal of 2005 Jeep Liberty Renegade
the problem is to do with the earthing or ground ,clean the area where the bolts attach a wire to the body work of the car losen bolt and retighten if this does not work run a new earth/ground wire
Jan 20, 2009 | 2005 Jeep Liberty
Wont power on.
to/ Japiering
all you have to do is re-charger them with the plug.
p.s.the re-charger comes with a set.
from hannah .l
Aug 02, 2008 | Nintendo DS Lite Console
Nintendo DS lite
Baakie,
You turn de DS Lite on, the green light flashes and the unit turned of. Is that correct?
The DS Lite checks some things before he starts-up. One of these things are the screens. the DS sends a signal to it and expect an answer back. When this answer is not received, it shuts down.
The most common problem in these cases is the flatcable of the upper screen.
Question is, did you replaced the housing? If so, you might dammaged the flatcable of the upper screen. If not, the flatcable might be defective because of using the DS Lite a lot (open /close the unit).
So first check the flatcable of the upper screen (google and you will find manuals how to open the DS Lite but be carefull!!!!)
Second, on the mainboard are two fuses (F1 and F2) . Check these! One of them might be defective
Success
Jul 19, 2008 | Nintendo DS Lite Console
Recalibration
  1. Remove all games from the Nintendo DS Lite.
  2. Turn the system on by pressing the POWER switch.
  3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
  5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
  6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
    • You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
    • If the above steps did not help, there is a problem with the system and it will need to be repaired. Click here for repair options.
  7. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner.
  8. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Nov 02, 2007 | Nintendo DS Lite Console
Locking up after 10mins
Check both of the Connectors (DS and AGB cartridge). It sounds like there is contamination. If these seem OK then it's sounds like it might be a thermal problem withthe circuit board. Call Nintendo.
Aug 28, 2007 | Nintendo DS Lite Console
Microsoft Xbox 360 Console Logo
64 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
