Installing new wireless g business ethernet bridge my problem is i cant connect to ip address for set up 198.168.1.1 does not connect neither does192.168.1.226 what now. i have internet conection on 2 desktops and no conection on laptop. i am using linksys quick installation guide
  • 339 Answers
You need to manully assign your computer an address in the 12.168.1.x range with a subnet mask of 255.255.255.0 rather than whatever is currently being used(most likely assigned by DHCP),
Once you do this and connect to the device, it is best to normally give it an address in your norml ip range, reset your computer back to normal, and then re-connect using the newly assigned address to verify it has been done correctly.
Depending on the model, you may also have the option of making the initial connection with a serial cable and then make any desired changes including device IP address by this method.
Posted on Oct 04, 2009
I have the wireless -G music bridge (model WMB54G) - I had forgotten the password so I reset it - Now, my computer will not recognize it - any suggestions?
The Linksys Wireless-G Music Bridge (WMB54G) has a web-based setup page that allows the user to customize settings and set up advanced properties.
Step 1:
Open a web browser.
Step 2:
Go to the Address bar and enter your router's IP Address, then press [Enter].
NOTE: The default IP Address of a WMB54G is 192.168.1.210.
NOTE: If the IP address of the WMB54G has been changed, type the WMB54G's new IP address in the Address bar instead.
The WMB54G's IP address can be changed by:
    • Running the WMB54G's setup CD.
    • Changing it on the WMB54G's web-based setup page.
If you forgot the WMB54G's IP address you can:
  • Press the Reset button underneath the antenna for 30 seconds.
NOTE: This procedure will reset the WMB54G to factory defaults. Any settings on the Music Bridge will be erased. The Music Bridge's IP address will be 192.168.1.210and the password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank, type "admin" in the Password field, then click OK.
NOTE: If the password of the WMB54G has been changed, type the Music Bridge's new password in the Password field instead.
Feb 28, 2011 | Linksys Wireless-G Music Bridge (WMB54G)
Tip
Do you have a Tivo Premier and are you experiencing wireless communication...
Recenty, I discovered that devices were dropping off of my wireless network (Netgear N300 wireless N with DSL modem). After trial and error, the solution to the wireless communication problems was to create a wireless N bridge using the Tivo Wireless N adapters.
To use this feature, you will need two Tivo wireless N adapters. One wireless N adapter should be set to bridge and plugged into an available ethernet port into your router. The second adapter should be set to client and plugged into the ethernet port in the back of the Tivo Premier. Once the power has been applied to both wireless adapters and the Wireless adapter (connected to the router) has connected to an available address on your router, press and hold the button (on top of each adapter) to establish a secure wireless connection between both adapters.
Once each adapter has established communication, you will have a separate 5Ghz Wi Fi signal (as well as a channel )dedicated to you Tivo devices throughout the house. Each Tivo Premier added to the house should have the wireless N adapter and connected using the secure connection to the wireless bridge by pressing the button on each adapter (the one on the router as well as the one on the Tivo to install).
If sucessfully installed, you should be able to connect to all Tivos on the network for management as well as streaming. If communication between the Tivos isn't successful, you will have to restart each Tivo and establish a new connection to the Tivo service.
Another suggestion when using the wireless N adapters is to setup a static IP address on each Tivo that is higher than the IP address assigned to the wireless adapter. Each Tivo utilized two IP addresses for each device (one for the adapter and one for the Tivo). You may have to check the router administration screen to determine the IP addresses used for the wireless adapters before establishing a static IP address for the Tivos. If you assign static IP addresses to each Tivo, you will have to restart each Tivo and reconnect them to the Tivo service to establish proper network mapping.
With this wireless network configuration, you will ensure that your Tivos are connected to the service using high speed, dedicated wireless N communication for streaming purposes between the services offered while not impacting other computers, servers, video game machines, and tablets that are connected into your house.
Since the Roamio uses a built in wireless adapter, you may not have success in adding a Roamio to the wireless bridge created on your router unless you disable the built in wireless adapter and purchase the external wireless N model from Tivo.
Instructions on setting up wireless bridge can be found at this location:
http://support.tivo.com/app/answers/detail/a_id/1590/kw/wireless%20n%20adapter
on Oct 02, 2013 | Tivo Premiere 4
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
Configuration:
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type 192.168.0.1 on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to 192.168.0.5 & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
How do i set up the wireless bridge without a
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 30, 2010 | Linksys Wireless-G Music Bridge (WMB54G)
I bought a dlink n router 655 yesterday to replace my old belkin router. When i connect the modem to the n router and try to setup with the cd, it wont detect the internet. The modem i'm using is westell...
I Think you ISP must be DSL.
Your internet is working with the old router when it is in bridge mode.
Check the IP address of your computer when it is connected directly to the modem and NOT in the bridge mode. Suppose the IP address is 192.168.X.Y. After that connect your computer to the ethernet port of the router. DO NOT connect the modem to the router. check the IP address of the computer again. Suppose the IP address of the computer is 192.168.A.B. Now make sure that both the IP addresses are not in the same range that means X is NOT equal to A. If they are same, then open the set up interface of your router and change the Local IP address of the router. that will help.
For More information Click Here
Oct 05, 2009 | Computers & Internet
Ip address for xbox live
ok, firstly i hate these problems.
first things first, switch your hub off (leave for 2 mins) switch back on, this may refresh the ip address, also switch your xbox off.. then try agian.
Get back to me and let me know what happens from here.
oh also are you connecting your xbox to the pc? or directly to your broadband hub? if you can connect it directly to your hub, this should solve any problems
Aug 07, 2008 | Microsoft Xbox 360 Elite Console
Wireless internet hookup
What seems to be the problem of your wireless internet?
Mar 27, 2008 | Computers & Internet
Laptop (Averatec Model #3150
Hi
I am try to take a stab at answering your query.
Internet Protocol (IP) Address preceeding with "169" means your PC is not receiving IP Address "generally" from your Boradband Modem or Internet Service Provider (ISP). The PC through Automatic Private Internet Protocol Addressing (APIPA) is assigning itself a temporal IP address.
This conditions means either
1. Dynamic Host Configuration Protocol (DHCP) Client service is not running properly on your PC (Unlikely)
2. There is no connection between your PC and Broadband Device or ISP wired or wirelessly (very likely)
3. DHCP Server Service is not configured or not running on Boardband device (likely) or ISP (unlikely)
4. Some firewall software when improperly configured are known to block all ports and services. This can block TCP Ports 67 and 68 used by DHCP Client/Server communication (quite likely)
Some pointers for more info;
1. Your query suggest your issues are limited to Wireless connection. Can you access Internet through wired connection? If so;
a) What Wired connection is in use? USB or Ethernet?
b) Is wired connection through same Broadband device?
c) What IP is assigned to your PC in wired connection?
d) If wired connection works, is IP assignment static or by DHCP?
e) What Boardband device is in use? In which mode is the device set to? Router/Bridge
2. If you can't connect both wired and wireless, then it is unlikely your PC hardware is at fault. Call your Broadband Provider for further help and configuration. Try entily disabling your firwall software (if installed) and test conection.
3. If you can connect through wired connection and your IP Address does not proceed with "192.168" or "172.16" then your boadband device is likely in a bridge mode. In bridge mode, the DHCP Server Service on your boardband device is disabled. Most ISPs will only assign only one IP address to a user. If an IP address has been assigned to your PC on the wired connection, then the wireless connection will not receive an IP address and therefore your PC will assign itself an IP in the range "169.254"
Regards
Mike
Mar 27, 2008 | Averatec 3150H Notebook
Trying to hook up lap top to wireless internet. Comcast tech says there is problem with IP# 169 which preceeds other numbers and needs to be removed for hookup. How can I accomplish this? Model #3150H
Usually you will have an IP address starting with 169 if the adapter cannot get an ip address from anywhere, it is an autmoatic IP address.
What operating system (Windows XP or 2000 or Vista) are you using?
Unable to get my WET54G up and running
Make sure that you routers IP range is setup to handle the IP address of your PC.
Feb 02, 2008 | Linksys Wireless-G WET54G 802.11g/b...
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
