Question about Technics SL-1200MK2 Turntable
When I click stop the patter turns backwards a couple times?
Mostly only on 45 (i guess since its faster) but when the patter is on and turning then click stop its goes revers while slowing down? Is this a simple part fix?
    President:
  • 4,402 Answers
There is sensors underneath are going or the motor is going .
Posted on Jan 04, 2008
When i turn my 1210s on both 33/45 switces come on and platter spins too fast
Couple of options , but first cleanen the pithfader and variable resistor pitch vr3 i thought, it's an open one , he needs allways to be replaced, even technics says so and first clean the board, inside and on youtube and this side there enough movies and text how to do it, and check the pitchfader cables very good.
Apr 12, 2014 | Technics SL-1200MK2 Turntable
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
A loud rythmic clicking under the dash behind glove box when ignition turned on, once car has started, clicking is faster, but same loudness. Any ideas on the cause? Otherwise, the car rund great.
If I would have to guess, I would say it might be some debris in your blower motor. (usually located behind the glove box on a lot of vehicles). Try turning your heater fan off, or increase the speed, does the "clicking" stop or get faster? If so, you may just have some debris (leaf, twig, etc) in there. The problem may work itself out if thats the case.
Aug 07, 2011 | 2004 Chevrolet Cavalier
Go in reverse
The steering levers control all movement on a zero-turn mower. Just slowly pull both handles back evenly and you'll go backwards in a straight line. The farther you pull back the levers the faster it goes backwards.
May 17, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Drove over a snow bank. mostly left side of my wrangler was on the bank, about 45 minutes later there was, i guess it could be best described as a scraping noise coming from below my front passager seat....
Jack the front end and try a twisting motion on the wheel. There should be almost no play in it at all.
Take a look at the suspension and see if there is anything noticeably different between the two sides...this will let you know if you have bent something.
Dec 01, 2009 | 2009 Jeep Wrangler
Irobot scooba 5800 spins quickly then sets off backwards
Remove and clean all of the wheels, and make sure the cliff sensors under the bumper are clean. Tap the bumper with your hand-- really smack it a couple of times. It sounds like the Scooba believes it's stuck against an obstacle.
May 10, 2009 | iRobot 5800 Scooba Vacuum
1994 Subaru Legacy Lsi has intermittent problem starting
With it not wanting to turn over, my guess would be a bad starter solenoid. I would get a second opinion on the engine cylinders. I have never heard of an engine that could not be bored out to some extent, and I would be very surprised if the grooves were deeper than .030'.
Mar 19, 2009 | 1994 Subaru Legacy Outdoor
I bought a razor from a friend who just got a blackberry, I put my sim in and it worked fine for aweek. Then a couple of days ago it just stopped everything when I turn it on and press any key it says Wait...
This is caused by a bad flex cable. More specifically the upper ear flex. It has malfunctioned (mostly due to water damage) and keeps recording memo notes (as if you are pushing the side button). This can be serviced easily. Usually $30-$45
Mar 10, 2009 | Motorola Mobility RAZR V3
Dryer turns off after 30 seconds and beeps six times (over and over.....)
other than a good lint cleaning by dissasemble and if not then replace the motor
Jun 23, 2008 | Frigidaire FEQ1442ES Electric Dryer
Turntable spinning backwards
Defective control PC board. take in for service
May 06, 2008 | Audio Players & Recorders
Technics SL-1200MK2 Turntable Logo
207 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
