Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Colman fernace blinking code 9 what is this - Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
  • 146 Answers
There should be a trouble code index on the panel that shows the wireing diagram good luck
Posted on Oct 03, 2009
My Colman furnace is not igniting. A one blink code (Ignition failure). What is wrong with it.
Clean the flame sensor and igniter , reseat all grounds.
clear the induced draft sensors tubing connector at the induced motor housing, the connecter plugs and is tough to clear, try a paper clip unfolded and ream it out well.
Apr 11, 2016 | Heating & Cooling
I have a 1984 Colman propane furnace that is short cycling
Why does the gas furnace short cycle - YouTube
? 11:07
https://www.youtube.com/watch?v=3LBut8fWcw8
Apr 23, 2012 - Uploaded by grayfurnaceman
When the gas furnace short cycles, and it does not bring the structure up ... have a frazier Johnson furnace with 9 blinks on diagnostic light. just ...
Mobile Home Furnace Troubleshooting - Mobile Home Repair
www.mobilehomerepair.com/articlefurnace.php
Jan 17, 2016 | Heating & Cooling
46 Colman Street - waht is post code?
There are many streets around the world named Colman Street. When you ask a question like this on the World Wide Web, you need to be a little more specific.
Jun 23, 2014 | Computers & Internet
6 year old colman furnace codes 1 blink ignition failure. Turn heater off at thermostat it cycles and heatsd house restarts a few times. alot of clicking noises and codes again a few cycles later. works...
I had the exact same issue and replaced the control circuit board, igniter, flame sensor, and thermostat just to discover the real problem was a rusted out Roof Jack. (The exhaust pipe that goes through the roof. The inner fresh air pipe was rotted out so the furnace was sucking exhaust gases in which would not support combustion. Have your's checked.
Oct 24, 2013 | Coleman Propane Forced Air Heater...
Carrier fernace light on board not comming on
check high voltage going to board and transformer then check low voltage from transformer to board. If you have voltage on these board is bad. Correct voltage that is.high 110v-120v low 24v-28v
Aug 28, 2012 | Carrier Heating & Cooling
My 40" toshiba tv nexxtech
Please let me know if this works for you! would love positive feedback! if this doesnt work let me know as well will continue to help
toshiba codes are 0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
an to reprogram it you have to follow these directions if found from an online manual for this model
Turn on the device you wish to program the remote to, point the remote at the device and press the key for that particular device (TV, etc.) on the Nexxtech remote. For TVs combined with a VCR or DVD player, use the "TV" key, and for VCR/DVD combination units, both "VCR" and "DVD" will need to be set up if your particular remote offers both.
  • 2 Locate the code (or possible codes) for your brand and type of device in the list supplied with your remote. Press and hold "P" until the display light blinks twice and then enter the first code. The display light will blink with each digit and blink twice if the code was accepted; repeat using the next code if it was not. Press "Power" once the code was accepted to see if the device responds by shutting off. Repeat the steps for all the codes listed under that brand name.
  • 3 Search for a code if none of the listed codes were accepted or if you do not have the list by pressing the appropriate device key, pressing and holding "P" until the display light blinks twice and pressing "9-9-1." Press "Power" to see if the device responds, and press "CH+" to try more codes if it does not. Press "P" again to lock in the code when successful.
  • 4 Point the remote at a programmed device, press the device key, press and hold "P" until the light blinks twice and enter "9-9-0" to learn the code for that device. Press "1" to see the code for the first digit; count the number of blinks on the display light and write down that number. If the number is 0, the light will not blink at all. Repeat for the next three digits by pressing the number key for that digit (2 through 4).
  • 5 Press "9-9-2" after pressing "P" to reassign a device key if, for example, you have two DVD players and no VCR and want to program the "VCR" setting to the second DVD player. In this example, follow "9-9-2" by pressing "DVD" and then "VCR", and then program in the code for that device.
  • Mar 17, 2011 | Toshiba Televison & Video
    Remote codes
    the 4220 does have SAT code 1377 on board, and will work with the following Directv sat receiver models: D10, D11, R15, H10, H20, and HR20.
    Try code: SAT1377
    What address is the D10 set to, DTV (00001) or AV1/AV2 (00002)? SAT code 1377 is for receivers set to white remote native code 00001.
    to blink back the code on the white remote:
    1. dtv
    2. press and hold MUTE & SELECT for two blinks
    3. enter 9-9-0
    4. press #1 key, it won't blink because the numeral is zero
    5. press #2 key, same as a above, zero blinks
    6. press #3 key, zero blinks
    7, press #4 key, zero blinks
    8. press #5 key, this should be 1 or 2 or 3 blinks
    Mar 31, 2010 | One For All URC4220 Remote Control
    My fan is always on on my colman model eb12a furnace and i dont have much heat comeing out of the vents
    If the room air fan is always on you could have the thermostat in the On position rather than in the Auto position, You could have a bad fan relay or the furnace is a "Lock-out" mode. A Lock-out occurs when the furnace attempted to start but could not for some reason. The computer board logs an error code and blinks a number of times. There should be an error code chart where ever the wiring diagram is located in the furnace. It may give you an idea where to start looking if in Lock-out. Good luck.
    Dec 02, 2009 | Coleman Heating & Cooling
    Heating & Cooling Logo
    65 people viewed this question
    Top Coleman Heating & Cooling Experts
    Bill Long
    Paul Carew
    vance jones
    Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
