Question about Troy Bilt 5.5hp Self Propelled Mower
I found a big mouse nest on top of the engine and now my mower runs for 30 seconds then stops. Do you think the heat damaged the valves?
    Novelist:
  • 168 Answers
For you to have found a mouse nest on top of the engine, then that tells me that it's been left idle for a long time. Like maybe as long as over the winter.
The 30 seconds is about the time it takes for the engine to run the carburetor dry. If left along for another while then that'll allow time for more gas to reach the carburetor and then run again until it repeats it's cycle.
You may have to remove the carburetor and give it a real good cleaning. No, i don't think the heat has damaged the valves because if it had, then the engine wouldn't start at all because you'd have little or no compression.
Look at the carburetor you may have had a dual problem there and one is not related to the other.
Hope this helps and good luck.
Wayne
Posted on Oct 03, 2009
My Case 224 over heats when I run it for 20/30 minutes! The engine has all its shrouds on, the radiator screen for the hydro is very clean etc. It just heats up to the point that it starts pinging et
you need a valve by SmaartCompare" in job or main i think your valve seats have come out on one or to valves take to shop and get checked before you run it again you could cuase damage
Sep 11, 2014 | Garden
Tip
Lawnmower fuel pop
Does your lawn mower or small engine give a big pop or bang when u shut it off after it has run and heated up for a while? I think this is from the hot exhaust egniting the gas fumes still coming through the engine. This may clean the carbon out of the muffler, but it may shorten the life of the head gasket. Either or it sure does scare bystanders, and wakes up the neighbors. To keep this from happening, just let the engine run at low idle for 30-40 seconds before shutting of the spark. Works for me.
ballping
on Jul 27, 2010 | Garden
Throttle stuck
remove the top cover from the engine and see if a mouse built a nest under the cover and keeping the governor from moving freely
Sep 01, 2012 | Husqvarna 21" Lawn Mower with Honda GCV160...
Briggs statton 375 starts runs very high revs how can i slow it down
remove the top cover from the engine and see if theres a nest stopping the governor from moving
Aug 20, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Craftsman with 190cc only idles
remove the top cover from the engine and see if there is a nest stopping the governor linkage from moving
Aug 10, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
Electrical problem on a john deere 420 lawn tractor
remove the upper engine cover and inspect for a build up of grass and or a mouse nest that would over heat the coil and the engine
Jun 19, 2012 | John Deere 420,1020,2010,2020,2510,2520...
LAWN MOWER STOPS WHEN HOT WILL NOT START UNTIL COOL
heat related problem are more likely to be a bad coil look under the upper engine cover and see if there is a mouse nest stopping air flow threw the cooling fins
Jun 03, 2012 | Garden
2008 Chevy Uplander has 21,000 miles. Nno heat from rear heater at idle. Disconnected hoses and flushed, water flowed good. Reconnected hoses and still no heat. Raised idle to 2000 rpm and got good heat....
Uplanders with the 3.9 engine are prone to no heat at idle speeds. Probably weeping head gasket. Air bubble trapped. Dealers will remove rad cap and let it sit at about 25 deg. angle for a couple hours. Good for awhile.
Nov 15, 2010 | 2008 Chevrolet Uplander
Early 1990's 12 hp tecumseh runs until hot then backfires & dies
Coil failure! The heat is what triggers it. I bet you that if you take the cover off the engine you will find the remains of an mouse nest. The nest blocked the airflow and damaged the coil.
In the spring the shop I work at gets a lot of this kind of problem. Critters love to build nests where they feel safe from weather and predators. Your mowers engine....is just one of those places.
Good news is: You can easily replace the coil yourself. The part for this style mower is available online....even through ebay! You can do the change yourself and make her good as new!
Just as an aside. You may want to check compression on your engine if it ran hot for so long. Make sure the combustion chamber isnt packed with carbon and oil coking! If you have pull start and notice higher than normal effort is needed to start it might be a sign of this problem.
The fix there is also pretty simple. You just need to order a new head gasket. Hey....while youre waiting for a coil why not wait for a head gasket right?
Jul 19, 2010 | Garden
No power to Rayvak heater
You have a bad transformer. Probably shorted out from the mice eating the wiring.
Aug 07, 2009 | Raypak Harness Wire, Mv
Troy Bilt 5.5hp Self Propelled Mower Logo
63 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
