Question about Frigidaire ATF6000ES Front Load Washer
How do I properly remove the top control panel in order to remove the front cover of the machine?
    President:
  • 1,304 Answers
There should be two screws holding the top down on the back wall
remove those and slide the top backwards
you will now see how to remove the control panal
Posted on Oct 05, 2009
I need to replace door seal on this machine but i dont know how to remove the front of the machine i have the top cover off
If it is Whirlpool / Maytag try parts diagrams at
www.whirlpoolparts.ca
Normal procedure to open front door panel on a front load.
1. Remove top cover.
2. Remove Control panel.
3. Remove bottom kick plate cover
4. You will see the door panel screws. Two on top corners and two on bottom corner.
5. Keep in mind, you have to remove the door lock (latch) from door panel before removing door panel.
Apr 25, 2015 | Washing Machines
Need to remove pump on LG WM2701H washer
To get to the pump you need to remove the top plate, control panel and front cover in that order. for the front cover open the lid at the bottom left side and remove screws.
May 01, 2014 | LG WM-2277HW Front Load Washer
How do youu get the front off
Apr 30, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
How to replace wm2487hrm tub wieghts?
remove the top plate, control panel and front cover in that order. for the front cover open the lid at the bottom left side and remove screws. The weights are held by a few screws remove them and the weights come off.
Apr 29, 2014 | LG Washing Machines
HOW DO YOU REPLACE THE DOOR LOCK I NEED TO KNOW HOW TO GET AT THE LOCK THE WASHER ONLY LOCKS IF YOU HOLD IN ON THE TOP OF THE DOOR
Disconnect power then open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. The top cover with the dispenser bezel off can be lifted to the rear of the machine to access the door locking mechanism, but you have to remove the front panel first.
Open the machine door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel then move it away and set it aside.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the machine. The door locking mechanism can now be removed and replaced.. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Jan 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
How do remove front seal on my ultima wf865
Remove top cover, unclip the control board, and unplug the lead to the board, remove screws holding board and remove same.
Remove front panel screws, remove screws holding door lock,remove clamp securing front seal ,remove seal, slide panel up and remove.
Change seal.
Re-assemble in reverse order.
Thanks.
Jul 29, 2009 | Hotpoint Ultima WF865 Front Load Washer
I need to replace a door seal, Hotpoint Ultima WF860
Push the top cover to the rear and lift at the same time, then ease the control panel to the right, you will not get control panel off with the top cover in place.
This will then give you access to the front panel scews, located at the top and bottom of the panel. remove the door seal ,and door lock, then lift the front panel away.
Nov 25, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Wf 541 how to remove top and front facia
To remove the Top you need to pop small torx covers on each side at the top (near to front). Then unscrew the torx each side. the top will then slide back about 5mm.
Once the top is opened you will have a major task of removing all cables from control unity behind facia and the holding screws. Depending on the damage to the button/plastic you may be able to pop the button into place. It is also possible you may need to order a new control unit from hotpoint. I believe you can order online for minimum hassle.
Feb 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
214 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
