Question about Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher
Dispenser door I feel that something is wrong with dispenser door. When the cycle is over, we open the main door and the soap is not disolved at all.
    Sergeant:
    Champion:
  • 298 Answers
Link to manual
read the section on detegent dispenser
sounds like too much detergent,or maybe
you should leave the detergent door a
little loose experiment untill you find what
works
Posted on Dec 22, 2007
  • 290 Answers
If the dispenser door is opening, then it is working properly. You have some kind of problem during the wash causing the soap to not wash out of thye dispenser. Either the pump is clogged or not pumping for some reason, there is not enough water coming into the unit or it is draining for some reason, or the water is sudsing up for some reason, usually rinse aid leaking into the water.
Start a wash cycle and let it fill completely with water then open the door and see how much water is in the tub. It should be just under the heater.
If it is ok, let it wash a few minutes then check it again to see if there are a lot of suds. If so, there is usually a leak in the dispenser.
Post back and let me know what you find.
Thanks/Mike
Posted on Dec 21, 2007
  • Michael  Lindley
    Michael Lindley Dec 23, 2007
    Just wanting to follow up on your dishwasher and see if water fill is ok. Water temperature is also very important. You need 120 deg F entering the washer for it to work properly.
    Post back with any questions.
    Mike
Our dishwasher is not dispensing the soap. I have tried using the cubes (stays in wells), tried powder (it turns to a cake of soap) and I have tried liquid but you could see it ran down the door. Some...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Dishes are not clean if water is hard or when more detergent is used than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results. You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine. Hope this helps...
Please post back if more information is required.
Daniel
Jan 10, 2011 | Maytag Dishwashers
The soap does not fully 'dissolve' after running the unit
I believe this is just a matter of dish placement, and not a matter of anything physically wrong with your unit. The way the unit works is when the "computer" tells to open the door, it releases the latch. That is all it is responsible for doing. After that gravity and the splash of the water jets must take over. So simply just make a visual path where you know water jets can hit that area and you should be alright. IF the powered soap is already caked in the dispenser you will have to manually scrape it out with a wood or plastic stick.
Mar 17, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Frigidaire diswasher detergent dispenser
the first thing to make sure is that the incoming water temp is at least 120 degrees.the next thing to do is check your water level and pressure when running if the water pressure is not high enough then you may have to replace the main wash motor.
if you do not think there is enough water in the bottom of the unit after it has stopped fillng add a few more cups to bottom and continue the wash cycle.
if there is no change in the performance replace the main wash motor
Mar 14, 2010 | Frigidaire Dishwashers
Detergent does not dissolve.
Make sure that the water supply going to the dishwasher is HOT. Detergent will not disolve in cold water.
Sep 15, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Dispenser door
Remove the outer door panel and check the actuator for the soap dispenser door it is probably broken. You might also check and make sure you don't have an old soap build up inside the soap dispenser. Sometimes old soap builds up and dries inside the dispenser and causes the door to stick. It should be free. Good luck.
Dec 21, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Soap not dispensed and dishes not washed
water is getting past the gasket during the start up cycle. by the time the door opens, the water has caked up the soap. also, its not clear when in the cycle the door is opening.
try using liquid soap.
also, take a peek just after the machine has finished filling and starts washing to see if the door is opened on the soap disp.
good luck
mark
Dec 19, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher Logo
232 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
