Question about Fasco Bradford White Hot Water Heater Exhaust Draft Inducer Blower # 239-42133-00
Blowe motor inop. Ran out of gas 10/1, ordered gas 9/22. gas in tanks 10/2 but still no hot water. Blower motor buzzes but not working. 14 year old unit. Please help !!!. Could running out of gas caused problem?
    Champion:
  • 248 Answers
You may have pusge the air out the gas line best of luck
Posted on Nov 02, 2009
Noise blower motor
leave unplugged... water will stay hot.
Plug in for 1 hour to make tank of hot water
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
Jan 18, 2014 | Water Heaters
I have a paloma ptg2-42pvn tank less water heater. I recently installed the remote as the unit quit making hot water. I wanted to see if it was producing a code. The remote is flashing 76 repeatedly. I...
Bad remote control. Bad wire to remote control. Bad PC board.
Copy following link for resources, including older service manual and error codes and rheem chat for ordering replacement motherboard for your tankless computer.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If tankless computer is 5 years old, then compare that to your 5-year old cell phone or 5-year old laptop, and ask if the chipware still functions or can be repaired to function back to factory fresh expectation.
Later today, install tank type water heater and solve all tankless computer problems with one ez step. Have hot water for shower same day with less maintenance and fewer long-term problems and expense.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 24, 2013 | Water Heaters
Rheem powervent 42vp40f does not provide water to all faucets
Feb 2013
1) Copy following links for Intellivent gas control service manual, low hot water pressure, and crossover:
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/Crossover.html
2) Unknown if tank has hot water > that is first thing to check.
3) Unknown if air intake screen located under burner is clogged with dust that cause combustion chamber to overheat, tripping FV lockout and breaker TRD glass vial.
Requires removal of combustion parts, replacement of TRD, blow out air intake screen, reset intellivent
4) Unknown if there is error code.
5) Rheem does not post service manuals.
However this unit can probably be repaired.
Feb 05, 2013 | Water Heaters
Does the vent motor come on when you turn on a powervent hot water heater
`1) Copy following link to troubleshoot by type of gas control valve, blower motor links, pressure switch testing, and other professional resources:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) Power-vent blower motor can go bad.
Plug motor directly into outlet, or turn on-off switch on, and see if motor works.
Check outlet for correct polarity, and for at least 80% of rated voltage.
Check vacuum switch. Blower creates vacuum, and the vacuum switch detect vacuum, and signals gas control valve that burner sequence can continue.
Gas control valve can also go bad. Wiring etc can go bad.
Feb 04, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 06, 2012 | Rheem Water Heaters
Our 18 year old hot water tank has been "putting
Install a new water heater,it should have failed 10 years ago
Feb 26, 2011 | Water Heaters
Bradford White hot water heater - burner lights only 30 seconds
The slightly warm water makes me think of a thermostat problem. The fact that the heater is 10 years old I wonder how hard your water is. Calcium build up kills water heaters. But the yellow flame you mention could be the results of dirty orfices. May want to have a Pro look at that.
May 03, 2010 | Water Heaters
Rheem power vent motor doesn't shut off
There could be blockage in your water heaters venting on the outside of the home. It sound like the high limit switch has been tripped. Try unplugging the tank and plugging it back in. this will reset the tank. if the problem persists you will want to call your provider for service.
Oct 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
Rheem 50 Gal Hot Water Heater will not stay lit
On the back of the gas valve (where you turn the temp up) there is a stem that actually goes into the tank that senses the temprature of the water it could be dirty or buried in sediment depending on how old the tank is, or just bad. if the tank is over 10 years old i wouldn't bother replacing the gas valve, the tank is probably not far behind. A new valve will run around $100.00 maybe a little less. You wont find it at menards or home depot in stock but they may be able to order it for you. Menards sells rheem products or try you local plumbing supply house. REMEMBER TO RELIEVE THE PRESSURE ON THE TANK BEFORE YOU WORK ON IT. IF YOU CHANGE THE VALVE DRAIN IT FIRST!
Feb 10, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Fasco Bradford White Hot Water Heater Exhaust Draft Inducer Blower # 239-42133-00 Logo
161 people viewed this question
Top Fasco Water Heaters Experts
Gil Shultz
Gene Haynes
Are you a Fasco Water Heater Expert? Answer questions, earn points and help others
