Question about Apple iMac G4 Desktop
When my imac g4 tries to bootup it shows a folder icon
When my imac g4 boots up it shows a folder icon with a ? mark and then a folder icon with a finder icon and agin and agin and agin
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
It sounds like the system is corrupted. What I would do is to get your instal disk and boot up holding down the c key on your keyboard. Once you have booted up go to the file menu and run disk utility to verify and repair the hard drive. Then go to the instal menu and instal a fresh system remembering to preserve the users data so you do not wipe anything. Hopefully this will work.
Posted on Oct 13, 2009
  • Maddy Strelow Jun 25, 2012
    ive tired this and mine still wont work doesnt get off the screen of the folder with a ? and then a folder icon...
Dleteing programmes on imac g4
go to finder, enter program, it will show ALL items associated with it.
Jan 17, 2014 | Apple iMac G4 Desktop
Ibook g4 won't open just gets a flashing equation mark and the finder icon
Sorry, either your hard drive cable is loose or your hard drive has died.
Mar 10, 2013 | Computers & Internet
I have a Mac G4 desktop. It froze up so I restarted using the power button and when it came up it had a blinking question mark inside a folder. It will not do anything even after restarting several times....
This means the mac can not find the system to start up, you can try holding down the alt key as you start the mac, this may bring up a choice of systems to boot from if not then try holding down the shift key at startup, as this will boot without extensions loading. If none of this works then you need the startup dvd that came with the mac, if you dont have it the you need a retail copy of the mac os that will boot your mac , if its g4 then osx 10.3 or 10 .4 will work.
cheers
tech 240
Sep 13, 2010 | Apple iMac G4 Desktop
Flashing question mark folder
Use you original startup disk to repair your drive and setup the startup drive for booting. If that doesnt work you may have to reinstall the OS.
May 20, 2010 | Apple iMac G4 Desktop
IMac G4 Mac Desktop: imac g4 wont boot up scree's just blue?...
If it only boots to a blue screen, try booting up in Safe Boot mode:
http://support.apple.com/kb/ht1455
If this does not work, boot from your install DVD and use Disk Utility to repair the disk:
http://support.apple.com/kb/ht2956
If this does not resolve the issue you may need to use your isntall disc to perform an Archive and Install:
http://support.apple.com/kb/ht1710
May 18, 2010 | Apple iMac G4 Desktop
IMac G4 Mac Desktop: i have a IMac G4 that when i start it a folder wit...
It can not find the hard drive or the startup folder on the hard drive. Try and fix that by putting in the original boot cd/dvd and repair and choose your hard drive start up folde as boot device. If you can not your hard drive may have died.
May 16, 2010 | Apple iMac G4 Desktop
When you turn the comuter on, it just shows the
--SAFE BOOT MODE--
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X StartupItems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
This should help get your iMac G4 back up
and running.
Regards,
Mactechtrainer
Jan 30, 2010 | Apple iMac G4 Desktop
G4 imac desktop won't boot up to show icons
Are you running OS 9? Are you referring to the loading of extensions at the bottom of the screen on boot?
Jan 09, 2010 | Apple iMac G4 Desktop
The container that hold my dvd disk wont come out when I press the open button on my apple computer?
It may be stuck so what you can try are one of these options:
Option# 1
* Shutdown your iMac G4
* Before you turn on your iMac, hold down your mouse button(s).
* Turn your iMac on still holding the mouse button(s) down.
* You will need to keep holding, until your disc ejects as your iMac starts up. That should do it.
Option# 2
If it does not, try using the Terminal utility to attempt to eject the disc.
* Click anywhere on the blank space of your desktop
and then you should see Finder appear near the Apple menu icon located in the upper left corner of your screen.
* Now from the Finder menu, select Go > Utilities.
* Within the Utilities folder. locate the Terminal application and launch it.
* When the screen prompt appears, type:
drutil tray eject
Option# 3
If that does not work, you can also try ejecting the cd using Open Firmware:
* Restart your Mac and hold these keys:
* Hold Command, Option, O and F keys while booting up.
* Now type: eject cd
To exit the open firmware screen type: mac-boot
One of these 3 methods should eject your disc.
If not, you may have a genuinely stuck CD in your drive and may need to take your iMac in to your local Apple retail store Genius bar or local Apple-authorized service center to have it safely and correctly removed.
Honestly, however, I have this same type of iMacG4- you will probably have the cd out by Option # 2 :)
Regards,
-Mactechtrainer
Jan 04, 2010 | Apple iMac G4 Desktop
Grey screen folder icon flashing and alternating with ?
The computer can't find an operating system. Start up from the OSX disc and check the drive with 'Disk Utility'. The system may have got damaged, or the drive may need to be repaired. Run 'First Aid'.
Apr 10, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
Apple iMac G4 Desktop Logo
334 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
