Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Screen says to fill water tank when it is already full.
Either the magnet is too weak in the water bucket or the magnetic internal switch is broken. If you put an alarm type magnet next to where it would be on the actual machine and the add water goes out, then you know it is the one in the water bucket. If it doesn't it is likely the internal switch.
Posted on Oct 19, 2009
SOURCE: Fill Water Tank But Water Tank is Full
Check the little black rectangular box which is in a plastic channel at the back. To work properly, the rectangular box, with the narrower end facing downwards, needs to be floating at the top of that channel. Apparently it's a magnet which signals the circuitry that the water tank is full. Make sure it's floating to the cap of the channel. If not, you can get a replacement one from Gaggia.
Posted on Jun 02, 2009
  • 2039 Answers
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Posted on Jan 15, 2008
  • 2039 Answers
SOURCE: Says "Fill water tank" and the tank is full
did you open the side valve to ventilate the air in the system in our water tank do you have a little magnet its in the water tank maybe it stuck downshake the water tank to move the magnet up pierre
Posted on Jan 10, 2009
  • 1089 Answers
SOURCE: water gtank full telling me to fill water tank
Hi
Check an see if you have the magnet in your water tank. That is your signal to the computer that it is full if it is at the top of its chamber. If you don't have a magnet ( gray cylinder) in the water tank that is your problem. If it is on the bottom the magnet needs to be replaced.
Posted on Nov 22, 2009
espressonist
  • 1711 Answers
SOURCE: keep asking me fill up the water tank even it is
Inside the water tank there is a magnetic float which is causing the problem. This float is moving always on the top of the water tank as you fill it with water and in reverse as the water level goes down then the float is moving down to bottom also. So as the magnetic float is moving up and down is giving the signal for the water level if it is full or empty.
So possibly now the float is stuck in the bottom and even if you have refill the tank this is still on the bottom of the tank. This can happen from many reasons. First could be that the plastic column that the float is moving is full of scale and it can not move up and down freely any more so you can clean it from scale by decaling it and even clean it with a wire brush.
A second possibility could be that float have a tiny hole and some water enter in the float and this make it to stay on the bottom of the tank. You can visually inspect it and if possible you can dry out the water and weld with a super glue the hole if possible, if it can not be fixed then you need a new float.
If you wand to fix it temporary until you find a new float you can a plastic clip or similar to secure it always on the top however you when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid any other problems with the machine.
Good luck
Posted on Apr 02, 2010
Testimonial: "But can't make it works...."
Water system problems
- normally water tanks are mains fed so the auto shut valve for the water tank could be faulty but more often than not, it will overflow the tank through natural wear of the washer. the auto shut valve is normally some kind of ball **** valve.
Aug 22, 2016 | Water Water Heaters
Fill water tank display And its already full
The float in the tank is probably no longer floating. New tank or shove something plastic under the float to lift it up.
Aug 24, 2015 | Coffee Makers & Espresso Machines
DeLonghi (W160B) Portable Air Conditioner "No Water" symbol is still on despite the water tank being full
Tank hols 14 litres water where you fill there is a indicator if that is clear the tank is not full has to be red to be full. The water fill symbol will then go out.
Dec 23, 2012 | Heating & Cooling
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
May 29, 2009 | Gaggia Titanium Espresso Machine
Krups XP9000 won't recognise water tank is full
I have just had the same problem with my Krups XP7240 and I discovered (quite by accident!) that it was the magnetic float inside the water tank which was causing it. I think the float must have let some water in and always stayed on the bottom even when the tank was full. As the float was in an enclosed plastic column it was a bit hard to access, but through sheer desperation I snapped a plastic fork in half and wedged the handle section under the float to keep it off the bottom and this works nicely. It is not professional by any means but I was quite pleased with my innovation :)
The only down side to this 'method' is that the opposite is now true and when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid killing the element completely.
I would imagine that the only professional way to get this sorted out is to replace the tank (or float if it is accessible?). Good luck!!
Feb 04, 2009 | Krups Small Appliances Espresso Machine
Jan 14, 2008 | Gaggia Titanium Espresso Machine
Nespresso Magimix M300 'Fill Water'
it just means that the pump needs primed. Turn on at the wall and on the machine, wait until screen says ready (make sure water tank full), then turn steam handle on RHS to on (do not push the steam button). the pump will prime until water comes out of the steam nozzle. now turn off the steam handle and you are ready to go!
Sep 16, 2007 | Coffee Makers & Espresso Machines
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
116 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
