Question about McCulloch Garden
I need to remove the fly wheel is it right or left hand thread? What is the best way to remove?
    President:
  • 2,220 Answers
The fly wheel is right handed the clutch is left handed.
Please watch this it will help. It explains how to stop crankshaft rotation.
R² Drive Link Outboard Clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
Lou
Posted on Oct 03, 2009
  • dontbother10
    dontbother10 Oct 03, 2009
    Some run the nut out to just beyond the end of threads and rap it with a mallet. Some try to pry it off. Chainsaw mechanics use a puller (purchase at autostore). If my saw, I'd purchase a puller.
How do you remove flywheel from a chainsaw
Remove side cover, remove nut holding fly wheel on (normally right hand thread so you would turn ccw to loosen but some have a left hand thread.) now remove the flywheel with a bearing puller or have someone hold the flywheel with gloves while you strike the bolt in center of flywheel with a copper or brass hammer (be sure nut is on bolt to keep from disfiguring).
Sep 13, 2017 | Garden
How do I change a grinding wheel to a Wire wheel on my new grinder # 37823
There is a left handed thread and a right handed thread on the arbors.
Removal
Right Hand Side (RH)
Wrap a piece of rubber or leather around the threads on the LH side of the arbor & hold with pliers, while turning the RH nut CCW.
Left Hand Side (LH)
Wrap a piece of rubber or leather around the threads on the RH side of the arbor & hold with pliers, while turning the LH nut CW.
Installation
Note: Hand tighten the nut, then 1/4 turn.
Wrap a piece of rubber or leather around the threads on the LH side of the arbor & hold with pliers, while turning the RH nut CW.
Left Hand Side (LH)
Wrap a piece of rubber or leather around the threads on the RH side of the arbor & hold with pliers, while turning the LH nut CWW.
For grinding stones:
  • ring test the stone
  • discard the stone if it has been dropped
  • be sure the paper washers are installed on the wheel
GRINDER SAFETY 101 (graphic injury video so be warned)
http://www.garagejournal.com/forum/showthread.php?t=263083
Feb 14, 2015 | Grinders
Need to put bobin in a merritt 4530
Flip the presser switch up to raise the presser foot. Turn the hand wheel counterclockwise until the needle is in its highest position.
  • 2Hold the hand wheel in place with your left hand while turning the hand wheel knob counterclockwise with your right hand to loosen the hand wheel knob.
  • 3Place the desired spool of thread on the spool pin so that the pin fits all the way through the hole in the center of the spool. Put the spool holder onto the end of the spool pin that is sticking through the spool of thread and press firmly to ensure that the spool holder keeps the spool in place.
  • 4Grasp the end of the thread and hold it taut between the thumb and index fingers of both hands. Snap the taut section of thread into the thread guide post located to the left of the spool pin.
  • 5Pull the end of the thread gently. Wrap the thread around the bobbin winder tension disk near the left front on top of the machine, starting at the side of the tension disk facing you and wrapping around in a clockwise direction.
  • 6Poke the end of the thread through the small hole in the bobbin from the inside out so that the loose end of the thread sticks through the top of the bobbin. Put the bobbin on the spindle, or bobbin winder, and gently slide the bobbin winder to the right.
  • 7Hold the loose end of the thread in place while pressing down on the foot pedal to start the machine. Hold the foot pedal down until the bobbin is as full as desired. The machine will automatically stop once the bobbin has reached capacity.
  • 8Cut the loose end of the thread using scissors. Slide the bobbin winder to the left and remove the bobbin. Hold the hand wheel in your left hand and tighten the hand wheel knob with your right hand by turning it clockwise
  • Apr 05, 2012 | Singer 6510 Sewing Machine
    Removing front wheel on 2002 honda magna is the axle threaded and which thread right hand or left hand
    it will be right hand thread, so turn anticlockwise to loosen, if there is no axle nut, they can be threaded into the opposite fork leg.
    Make sure any pinch bolts are loosened
    Mar 15, 2011 | 2002 Honda VF 750 C Magna
    Have tried everything, can't get one of the grinding wheels off.
    On a bench grinder the wheels turn towards you. This means the grinding wheel on the right side, has a right and nut, and the left side has a left handed nut. If you're trying to remove the left side turn the nut counter-clockwise
    Aug 16, 2010 | Delta Grinders
    Are the threads on the nut for the crankshaft pulley left or right handed?
    Hi they are normal nuts so will undo anticlockwise, but to undo this nut/bolt your going to need to lock the flywheel you can do this by either removing the starter motor and jamming a big screw driver in the teeth of the fly wheel so that it lock on the casing of the gearbox or you can undo an inspection panel on the gearbox to give you access to the fly wheel and then jam it that way other than doing this you would need air tools to undo this nut without jamming the fly wheel
    May 22, 2010 | 2000 Nissan Frontier
    I am converting a coaster into a motorhome, slowly. I need a handbook to complete the conversion with confidence. I don't even know how to remove the rear wheels, LH or RH thread? I would be grateful for...
    one side is left the other is right handed, look at the wheel studs, the left handed thread has "L" on it. iam 4 months into my conversion. huge job!
    Feb 01, 2010 | 1985 Toyota Passenger
    I cant get the bolt out of the fly wheel is it a left handed thread
    Very possible it is left threaded. so try the other directon.
    Oct 06, 2009 | 1998 Honda VT 1100 C3 Shadow Aero
    Fly wheel removal ?
    View this; the piston rotation must be stopped to allow removal of the flywheel nut. This illustrates how. The nut is a normal right handed thread.
    1. Check at the IPL for your saw to see if any special tools are needed.
    2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
    3. It is probably a left handed thread (tighten it to loosen it).
      Let us know how it worked for you. GL
    Lou
    Oct 02, 2009 | Garden
    4d56 with 5 speed im trying to get the fly wheel off
    there right hand thread. Get some good penitrating oil, and let it soak. Then use abreaker bar, or impact gun.
    Dec 27, 2008 | 1983 Mitsubishi Pickup
    Garden Logo
    97 people viewed this question
    Top McCulloch Garden Experts
    Jim Parker
    Jim Parker
    roeb
    Are you a McCulloch Garden Expert? Answer questions, earn points and help others
