Question about Yamaha DV-C6480 Multi-disc DVD Player
Ho2 error on the yamaha DVC6480
I keep getting an H02 error message. I did clean the DVD player
  • 2 more comments
  • phudson May 16, 2008
    ho2 for me too, any ideas?
  • hoangnongt Jun 24, 2008
    it always bop up ho2 when loading, please help me
  • NNJGMAN06 Aug 22, 2008
    SAME THING HAS HAPPENED TO ME, HO2.
    WHAT DO I DO TO FIX THIS ???
  • viking70 Sep 17, 2008
    ho2 error code too. dvc6480 will not read dvd's.
3 Suggested Answers
SOURCE: Error H02
I had the same problem and found that the motor that spins the cd so it can be read would start and stop. I opened the case removed the assembly with the motor and placed a drop of 3in1 lightweight oil on the shaft of the motor ran it a few times and now it works perfectly fine. Good luck hope this helps you as well.
Posted on Dec 24, 2007
SOURCE: HO2 error code at screen
In line with the other Panansonic DVD players, the error seems to relate to the internal drive machanism getting stuck.
To fix you just need to carefully take the back off (disconnect power source first!), locate the drive cogs for the lens machanism and give the a couple of turns. Also a blast from a air can will help get rid of any dust build up. Pop the back cover back on and you should be working.
Looking at the other Panasonic threads on the site, this may happen on a regular basis especially as the unit gets older (and the crud builds up).
Posted on Jan 04, 2009
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you https://www.ifixit.com/Guide/Repairing+a+Panasonic+SA-HT810V+with+the+H02-H07+error/2708
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
Dec 03, 2017 | Panasonic Dmr-es35vs DVD Recorder / Vcr...
Problem playing dvd with panasonic sa-pt660 keep getting an H02 error message?
Thousands of annoyed customers of Panasonic, Yamaha, and Denon DVD Player owners have encountered the infamous H02 / H07 /H03 erors and many others on thier players or maybe the "No disk" error even though a disk is in the drive. Well many people have spent hundreds on repair or bought a new unit. But i am here to tell you that it is okay to open up your dvd player and mess around in side. If your DVD player comes up with one of these errors the first thing you might want to try is to open up your DVD player by removing the screws on the side and the back (depending on the model), then plug the dvd player into power outlet with cover removed. Stick a disk in and press play and give the disk a little push. Most of the time the Spindle motor is dieing out when you get a H02 error. In this case that little push may get your spindle motor to rev back up back into action. And if your as succesful as me then hopefully you have just fixed your H02 error for free without doing much work. I just got a Panasonic HT95 Reciever/DVD player to play all disks again by giving the motor a little "kick start"
Jan 05, 2011 | Panasonic Televison & Video
H02
The HO2 message means the disc is not spinning,it's not about the lens
or the laser.It is easy to take the lid off.Once you do that,plug it in,open the tray with the remote,put in a DVD,close the tray and then give the white plastic wheel on the top a gentle little nudge to get the disc spinning.
Jan 30, 2010 | Panasonic DVD-LS50 Portable DVD Player
Jul 10, 2008 | Panasonic DVD-LS5 Portable DVD Player with...
HO2 Error???
The problem with your unit is the "Spindle Motor", this motor is the one that spins the disc so the laser can read it. I sugest you to take your player to a shop, or back for service if the unit still under manufacturer warranty.
Apr 14, 2008 | Panasonic DVD-RP56 DVD Player
Panasonic DVD-RP56 Error H02
I read about removing the cover and spinning the motor by hand. It was suggested without power. I found that I had to have the unit powered up when I hand-spun the motor, then everything worked perfectly... we'll see for how long.
Feb 10, 2008 | Panasonic DVD-RP56 DVD Player
HO2 error
That's the spindle motor and it has to be replaced to solve the problem.
Jan 01, 2008 | Panasonic DVD-RV26 DVD Player
Error H02
Dec 21, 2007 | Yamaha DV-C6480 Multi-disc DVD Player
DVD not playing message say H02
There is a solution but it takes a little care because the wrong thing touched will give you a shock. Just stay away from the unit near where the power lead enters the unit. OK. remove the top of the unit, place a disk in the unit press play and gently give the DVD a gentle push in a clockwise direction. This disk should then get up to speed and start playing. It also unlocks the error. No guarantees with this one some work, some don't. I hope yours does. BMW
Jul 28, 2006 | Panasonic DVD-RV31 DVD Player
Yamaha DV-C6480 Multi-disc DVD Player Logo
399 people viewed this question
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
