Question about Plumbing
Jet pump stuck but not running
My pump runs and then trips off, but the strange thing is when i use my voltmeter on the ternimal board or the start switch i get a reading of 112v, can you tell me whats happening?
    President:
  • 1,378 Answers
The thermal overload device inside the motor is probably shutting it off. Once it cools, the motor will turn back on. If there is a run capacitor, it may be bad. If not, it is likely in the motor winding. Take it to a local electric motor repair shop for inspection to be sure.
Posted on Oct 03, 2009
Testimonial: "I thought that much, you really are a guru. Keep up the great work, thanks a lot. Addison............"
My hot tub has an issue. Only half the display is working, there's no heat and the jets wont turn on. If I trip the curcit, I can get the hot tub jets for 10-30 seconds and that's it. HELp
Almost all hot tubs use 230 volt AC power which comes from the power company in two power wires plus one common common wire. You get common 115 volts between a common and either other wire. "Half way" working could well be an attempt to run on only one of the wires. There is also likely to be a ground fault circuit breaker in the wiring which makes sure current going out to the tub is all returned via the wires and not through someone's legs to ground. If you're comfortable with an AC voltmeter check some voltages but understand that 230 volts is way into the killing range. Two people present and well insulated probes are important.
Apr 15, 2016 | Pool & Spa
Kitchenaid dishwasher kuds30ixssa has pump running but have no lights on control panel with door closed.
Did you have a power outage recently? They are notorious for damaging circuit boards--usually about 3-4 weeks after the power interruption strange things will either start happening or *not* happening with appliances due to damaged computer chips on the boards starting to fail. Your symptoms indicate either a blown user interface(push button panel) or a defective main control board(board with the brains on it) or both!
Aug 11, 2015 | KitchenAid Dishwashers
My power keeps tripping after I frefilled it
check heater sounds like shorted if ok then pump shorted
Jun 09, 2014 | Qca Spas Pool & Spa
Sunlighter hot tub
Sounds like the pump motor is tripping out on thermal overload. Touch that particular motor just after it shuts off. If it is "very" hot to the touch, it probably needs replacement.
Oct 16, 2013 | Electrical Supplies
I have an icetronic ice maker , it runs and works fine but trip out after awhile if i leave it for about 20 mins it will start again without tripping the main fuse
I brought in a icetronic IT120 for repair. The machine and all the jets and filters are perfectly clear of dirt. The only problem is that the spray plume from the jets is not wide enought to hit all the outer cups. Could all the jerts be slightly worn or are the pumps down in pumping pressure?
Aug 22, 2011 | Refrigerators
Can you tell me why everytime i turn the jets on in my hot tub it some times will run and other times it just trips the breaker
mmmmm....is the unit heating? sounds like maybe the heater is causing the GFCI to trip or could be the motor going bad.
Jan 25, 2011 | Flotec Corrosion Resistant Shallow Well...
The circut board was replaced everything powers up lights jets the digital display all program functions to program filtering cycle.while running operation seems normal.after aprox.from start of system to...
Do you have a model and serial number so i can spec components and a diagram?
The reset is a GFCI electrical or a high limit temperature switch?
If its a GFCI you have a leak or a short or the pump is drawing to many amps likely due to something in the impeller or plumbing restricting flow. Potentially its a shaft seal issue.
How hot is the tub when it trips? Try running it cold and see if it trips. If it doesnt and its still cold its the pump. If its hot and you set it to cold its a stuck relay or contactor or triac and therefore tripping a high limit switch.
If this is a hot tub/spa the pressure switch may be an issue. It shuts down the heat typically and keeps the pumps running.
If a reset switch of any type is tripped to many times it will continue to trip at a lower and lower value.
Just some tips, hope they help. Get back to me with some info.
Jan 20, 2011 | Home
Fuel pump runs and dont run at times wont start
First thing would be to either test or replace the relay which is under the hood. Do check the fuse as well. you can test power to the relay and also to the pump with a voltmeter. You can test the relay itself with an ohmmeter.
Jun 08, 2010 | 1988 Mercury Sable
99 corsica-cuts off intermitenly-(with in 5 min.running) of crank
try another relay if still same then bring out voltmeter/start checking wires
Mar 19, 2010 | 1999 Chevrolet Cavalier
Plumbing Logo
60 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
