Question about Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher
Soap dispenser doesn't open?????
Mt soap dispenser will not open I think. It will go through the entire cycle, we will open the door and the electrasol 3 in 1 is still unused on a dish. What is the problem?
  • Anonymous Dec 23, 2007
    I have the same problem, the soap dispenser wont open during the washing cycle
  • Anonymous Mar 26, 2014
    Next to soap dispenser
Take the front panel off ( screws at the bottom ) check to see if one of the wires came loose.
Posted on Jun 30, 2008
Have the same issue were you able to find a solution?
Posted on Feb 27, 2008
The soap dispenser door will not open during the washing cycle. What could be my problem? I have a Lg dishwasher model #ldf7561st
If you don't want to disassemble the dispenser to replace a part, you can replace the entire dispenser. Additionally, if the dispenser isn't working and the entire dispenser is worn out, replace the dispenser.
Sep 26, 2015 | LG Dishwashers
The soap door does not open during the wash cycle
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
Apr 18, 2011 | KitchenAid 24 in. KUDI02CR Built-in...
The soap is not opening during the cycle. We have tried new soap, hot water running before the cycle, little soap, you name it we do it. The only way my dishes get clean is not to shut the soap dispenser.
I have the same problem! Just in the past few days -- UGH! I am highly disappointed in this dishwasher. I read that the failure to release the door is due to soap and hard water build-up. So, I've sprayed the entire soap dispenser unit with vinegar. Hopefully that will help!
Jan 13, 2011 | Bosch SHE4AM16UC 24 in. Built-in...
The soap compartment will not open during the wash cycle.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn’t allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work. Please check the voltage to the wax motor/Bi-metal strip, also inspect the connections to these.
Please revert for any further assistance.
Daniel
Aug 28, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Soap dispenser door will not open during operation
Hi
Hope this helps... Please revert for any further assistance.
Daniel
Aug 26, 2010 | KitchenAid Dishwashers
Soap dispenser will not open in dishwasher
depending on the model and make of the dishwasher you're going to have to determine if it the control which actiavtes the soleinod of the wax motor that springs the dispenser door open and later in the cycle it also dipenseces the rinse aid
Dec 19, 2008 | Dishwashers
Tried to replace bosch soap dispenser model shu3036uc/u12
Wire positioning doesn’t matter to soap dispenser. If water is leaking from the door then the dispenser is not pressed in properly against its seal. As far as the door not opening if wires are connected perhaps the problem is in the control module. Voltage meter on wiring to dispenser should indicate this while machine is running at start of quick wash cycle. (First 5 minutes of cycle on heating)
Dec 28, 2017 | Bosch 24 in. SHY66C02 / SHY66C06 Built-in...
Soap dispenser doesn't open for wash cycle
I noticed you didn't rate out chat and saw that your problem was posted. I'm happy to continue to help you if you encountered problems or were not happy with the solution in your chat session.
Jul 07, 2008 | Frigidaire FDS251RJ Free-standing...
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher Logo
196 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
