Question about Whirlpool Duet GHW9150P Front Load Washer
Reinstalling a washer and dryer and i know which line is hot and which one is cold coming out of the washer ing machine but i dont know which line is hot and which is cold when hooking it back up the the house lines the are not labeled is the hot on the left or the right?
  • 334 Answers
If the pipes were installed properly, then the hot is on the left, cold on right.
Hook it up that way, then set it on the smallest load possible, with hot water setting only. If you have hot water filling the basin, you have it hooked up properly.
Posted on Oct 03, 2009
Error f20 w/ water coming out hot inlet (not hooked up)
yeah you need to connect the other hose because the mix valve just below that does not seal one or the other..those switches work with the water pressure..thats why the errror showed up..
Jan 21, 2014 | Kenmore HE2 Plus Front Load Washer
What is the small hose on the back between the washer and dryer for
The hose off your washer will be two fill hoses "Hot" and "Cold" water and a Drain hose. the other things coming off a dryer will be gas line if gas dryer or a vent line for hot air to go outside. If you have a electric dryer you will have a large heavey cord coming off dryer going into over sized plug.
Aug 22, 2011 | Whirlpool Washing Machines
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Cold water won't stop
You need the water valve to be replaced.:)
Mar 09, 2009 | Whirlpool Inglis IP4400 Washer
I purchased a front loader washer and I only have a cold water line no hot,I hooked it up and the machine comes on but no water comes in the machine....can someone please help me figure this out??????
ok no problem where going to try this but your going to have trouble in the end...since you only have a cold tap ,,use a y hose to booth vavle dont cap of the hot,,,now you purchase a unit that has atc,,automatic temperature control..meaning the unit control how hot or cold the water will be in degrees,,,when you start the unit it puts hot in at the start even in a cold wash to break down the soap in the dispencer,,it doent know if you use powder or liquid,,so it just shots hot water though for a few second,,now that comes back to the begging,,if you put clothes like whites and that atc does nt sense that hot water the unit will stop until it do,,and you will get a code,,im here onthejob
Jan 02, 2009 | LG WM1814CW Front Load Washer
Washing machine will not fill w/ hot or cold water
Could be an air lock in the water pipes,turn off the water to the washer, disconnect the hoses, and hold them over the sink or into a bucket, then turn the water taps back on to the washer.
The water should come through at full pressure.,
If it does not , then the problem is with your supply and not the washer.
Hope this helps.
Plz leave feedback.
Ta.
Dec 09, 2008 | GE WBSE2090A Top Load Washer
Should the washer be hot after the rinse cycle?
Try cycling a cold/cold wash and see how that comes out.. if it comes out hot then your water inlet valve is letting hot water in when it shouldn't.. conversely, try cycling a hot/hot wash and see that it does indeed come out hot... ( quick tests to verify performance)..hope this helps.
Sep 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
No hot water to wash
Is the hot water hot that is coming to the washer? Are you using the correct settings on the unit? If yes to both then either the solinoid water valve is bad or the timer switch unit is bad. Try going to a totally hot water setting. While turning on the machine feel of the hot water line at the machine and see if you notice a buzz or feel a click as you turn on the machine. On this setting does water run in and is it hot or cold. If water runs and it is cold try going to a total cold setting and see if you get cold or hot water. Is this a new setup or has it been working and stopped? If new, you could have the hoses connected backward. If you get water in both hot and cold settings but cold both ways then your hot water heater is not working....let me know....
Feb 10, 2008 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool Duet GHW9150P Front Load Washer Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
