Question about Car Audio & Video
American Pro Amp 1406
I seem to have a short or bad connection where my fuse goes. My amp acyually goes in and out or just doesn't work at all untill I touch the fuse. What could I do to fix this?
  • 631 Answers
The best solution would be to replace the fuse holder.
If the fuse holder is for the push-in fuses, you can tighten the clips. Remove the amplifier from the power source (<VERY important). Use a small flat-bladed screwdriver to push the rounded part of the clip toward the flat part of the clip (these will be visible when you look into the fuse holder).
If that dosen't work, there may be broken connections on the circuit board.
Posted on Dec 21, 2007
99 mercury cougar replaced power window motor and switch window still does not work
That doesn't seem possible does it ?
You remove the inner door panel
You think the motor may be bad,so you unplug it,
knowing it is a DC Motor & can be hooked up either
way & will run in either direction
You put 12 volts to it. Doesn't work ,sounds bad,you
install a new one
Now you need power from the switch to run the new motor,
so you work on that
The switch can be disconnected & tested with an OHM Meter
& if worn,you replace that
You checked the fuse before you started & knew that wasn't an issue,
because all the other windows worked
So what did you mis ,short of having no wiring diagram, to make
things a lot easier?
Aug 04, 2011 | 1999 Mercury Cougar
It goes into protection mode. how do i get out of it?
Check your speaker connections and speaker resistance of each speaker with an OHM METER. Most speakers are marked either with a 4 ohm or 8 ohm impedance. You might have a burned voice coil (shorted out) and the amp senses the short and goes into protection mode to protect the amp from being overloaded and burning itself out.
Sep 03, 2010 | American Pro VS1406 Car Audio Amplifier
Need a wiring diagram for a american pro 1406
Very simple :
12V+ = Red 8 Gauge Wire to positive battery terminal with a 30 Amp fuse
Ground = Black 8 Gauge wire to non painted surface on chassis of car.
Remote Turn on = Blue / white thin wire from radio's blue/white , this will turn on your amp.
A set of RCA cables which are self explanatory. Out to In or In to Out
Radio to Amp under carpet to back of vehicle along with your blue wire.
Then you have your speaker wires, you hook these up to your subwoofers.
Hope this helps, good luck.
Lex..
May 21, 2010 | American Pro VS1406 Car Audio Amplifier
I have a american pro amp and the light inside it is on but the green light on the out side wont come on. and it wont work. i took it out of something else and put it in my truck
sound like it went out durring that uninstallment must have shorted out doesent mean the light on the inside wont work but that if you like that amp take it to a reapair shop and let them work on it chances are it might be cheaper just to buy another since its american pro...
Feb 21, 2010 | American Pro VS1404 Car Audio Amplifier
Prolem with J/L audio 500/1 the amp works(no diag light)but something keeps tripping and the amp goes dead until you toggle the signal swith. the the amp plays for a short period then repeats
YOU GOT A SHORT SOMEWHERE IN UR WIRES OR A BAD CONNECTION I WOULD DIFFIENETLY CHECK THOSE THINGS FIRST THEN LET ME KNOW IF IT STILL DOESNT WORK PROPERLEY
Jan 30, 2010 | Jl Audio 500/1 Car Audio Amplifier
Dont have wire schematic to hook up american pro bass machine limited edition model 1406,need to know how?
You should go to www.the12volt.com they are very helpful and pretty much have a schematic for every single car audio situation and they give you all your options. If they have nothing go to crutchfield.com and go to the learning section then subwoofer and amp wiring. It all depends on the subs that u wanna hook up to it as well as the ohm impedence and the amount of voice coils and so forth they have all of that.
Jun 13, 2009 | American Pro VS1406 Car Audio Amplifier
American Pro VS1405
Sounds like the thermal protection on your amp is doing its job. You can put an external fan in to help in cooling, like the crossflow type shown here, or a couple of muffin fans like these (look familiar?). You may have fashion a bracket to mount the fan(s), but that shouldn't be too much of a problem. Many fans are shipped with mounting tabs attached.
Jan 27, 2009 | American Pro VS1405 Car Audio Amplifier
How to fix my amer.pro1000watt amp which has a burnt fuse an doesnt put out music
You blew the output transistors. They all need to be replaced. Check this for more info: http://www.techlore.com/article/14696/
Aug 14, 2006 | American Pro VS-2043 Car Audio Amplifier
Car Audio & Video Logo
229 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
